It would seem logical to just draw gas from the lowest point of the
tank into a fuel line leading to the engine. But contrary to a car, an airplane can experience negative gs, and especially in aerobatics, for prolonged periods of time. So a pump connected to the lowest point of the tank would only draw fumes at some point. How is this problem solved? Thanks (again) for enlightening me, Oliver |
On Nov 25, 9:23*am, Oliver Arend wrote:
an airplane can experience negative gs... During which times the engines of most airplanes just sputter. Aerobatic airplanes usually have at least one tank with the fuel pickup on a flexible hose that follows the fuel. That's usually called a "flop tube." Thanks, Bob K. |
"Bob Kuykendall" wrote in message ... On Nov 25, 9:23 am, Oliver Arend wrote: an airplane can experience negative gs... During which times the engines of most airplanes just sputter. Aerobatic airplanes usually have at least one tank with the fuel pickup on a flexible hose that follows the fuel. That's usually called a "flop tube." Thanks, Bob K. Do any of the experimental aircraft designs use just a simple hose with a weight that follows the fuel. It's very successful in modeling. You just stick a weighted fitting on the end of the hose called a "clunk". |
On Nov 25, 2:53*pm, "Maxwell" #$$9#@%%%.^^^ wrote:
Do any of the experimental aircraft designs use just a simple hose with a weight that follows the fuel... Yes. It's called a "flop tube." Thanks, Bob K. |
On Tue, 25 Nov 2008 15:11:12 -0800 (PST), Bob Kuykendall
wrote: On Nov 25, 2:53*pm, "Maxwell" #$$9#@%%%.^^^ wrote: Do any of the experimental aircraft designs use just a simple hose with a weight that follows the fuel... Yes. It's called a "flop tube." Thanks, Bob K. They are getting a little pricey lately, around $55 at Aircraft Spruce |
"Bob Kuykendall" wrote in message ... On Nov 25, 2:53 pm, "Maxwell" #$$9#@%%%.^^^ wrote: Do any of the experimental aircraft designs use just a simple hose with a weight that follows the fuel... Yes. It's called a "flop tube." Thanks, Bob K. Duh? I misread your post. Although you described it as a hose, when you called it a flop "tube", I pictured a mechanical tube or arm. |
On Tue, 25 Nov 2008 20:24:38 -0600, "Maxwell" #$$9#@%%%.^^^ wrote:
"Bob Kuykendall" wrote in message ... On Nov 25, 2:53 pm, "Maxwell" #$$9#@%%%.^^^ wrote: Do any of the experimental aircraft designs use just a simple hose with a weight that follows the fuel... Yes. It's called a "flop tube." Thanks, Bob K. Duh? I misread your post. Although you described it as a hose, when you called it a flop "tube", I pictured a mechanical tube or arm. In aircraft use, generally it IS a tube, not a hose. |
On Nov 25, 8:22 pm, wrote:
On Tue, 25 Nov 2008 20:24:38 -0600, "Maxwell" #$$9#@%%%.^^^ wrote: "Bob Kuykendall" wrote in message news:e86e607e-2544-4029-814c-4d581e42e__BEGIN_MASK_n#9g02mG7!__...__END_MASK_i ... On Nov 25, 2:53 pm, "Maxwell" #$$9#@%%%.^^^ wrote: Do any of the experimental aircraft designs use just a simple hose with a weight that follows the fuel... Yes. It's called a "flop tube." Thanks, Bob K. Duh? I misread your post. Although you described it as a hose, when you called it a flop "tube", I pictured a mechanical tube or arm. In aircraft use, generally it IS a tube, not a hose. One also needs to perform similar magic with the oil system if inversion longer than a few seconds is contemplated. Actually, its surprising how long the engine will keep running after forgetting to switch to the acro tank. I've made halfway into an acro routine before being surprised by the sudden silence. ;-) K l e i n |
| Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg | [email protected] | Aviation Photos | 0 | April 12th 07 02:33 AM |
| Fuel tank balance | Mxsmanic | Piloting | 101 | October 3rd 06 08:56 AM |
| Engine driven fuel pump necessary with gravity feed tank?? Lycoming | RonLee | Home Built | 2 | May 8th 05 07:10 PM |
| fuel tank plumbing | pwm | Home Built | 18 | January 27th 05 05:54 AM |
| Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 03:57 AM |
