Clouds
Old December 19th 08, 03:07 AM posted to rec.aviation.soaring
bildan
Default Clouds
Interesting read.
http://www.sciencedaily.com/releases...1208114258.htm
Old December 19th 08, 01:10 PM posted to rec.aviation.soaring
Default Clouds
Interesting, but is there anything new there? Soaring books published
twenty years ago have drawings depicting the sinking air around
thermals as well as the idea that thermals are streams of bubbles vs
columns. Maybe its just that now they are taking this into account in
the models?
Mike
Old December 19th 08, 07:50 PM posted to rec.aviation.soaring
Default Clouds
the models?
Mike
Yes, there's a lot here because now they have a mathematical model for
it.
We've always known it as lore, intuition, etc., but for weather and
climate
models fair weather clouds are just fudge factors. Now (at least on
fine scale) they can accurately model them.
Old December 20th 08, 12:49 AM posted to rec.aviation.soaring
Rudy Allemann 7Y
Default Clouds
What I got from the article is that the new model predicts sinking air
around the edge of the CLOUD. But most of our soaring is done below
the cloud so concentrated sinking air is not predicted in those
surroundings because the evaporation mechanism is not present there.
Old December 20th 08, 01:13 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
snip-
Heus continues, All around the cloud, air sinks downward in compensation for the upward movement.
-snip
What bunk
Hues should perhaps remind himself of gravity, and that his models dont seem to take it into account
bagger
Old December 20th 08, 01:15 AM posted to rec.aviation.soaring
Martin Gregorie[_4_]
Default Clouds
On Fri, 19 Dec 2008 16:49:07 -0800, Rudy Allemann 7Y wrote:
around the edge of the CLOUD. But most of our soaring is done below the
cloud so concentrated sinking air is not predicted in those surroundings
Reading between the lines I'm guessing that up to now climate models have
taken account of the effect of clouds on the earth's albedo and
(possibly) reducing heat loss by trapping long wavelength IR radiation
beneath them, but ignored or fudged thermal mixing effects under cu. Now
they know enough about the mixing effect to incorporate it in their
models.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 20th 08, 01:49 AM posted to rec.aviation.soaring
bildan
Default Clouds
Actually, I've encountered sharp edged sink as I passed the cloud edge
when leaving a good Cu. Sometimes, this caused negative G. I suspect
the evaporation caused cool air downdraft extends well below cloud
base. I plan to pay closer attention in the future.
Old December 20th 08, 10:00 AM posted to rec.aviation.soaring
Peter Purdie[_4_]
Default Clouds
All the models do incorporate gravity (otherwise less dense air would stay
exactly where it is, and no convection).
They are of course 'models' - a mathemetical description of behaviour if
a variety of assumptions are correct. When I was involved in Met. research
in the 1970's it was clear that the models used then for meso scale (the
scale on which usable convection occurs) gave very poor correlation with
reality. My understanding is that the models today are more refined, but
still are nowhere near matching the complex reality where topographic
effects and a mixture of airmass trajectories have large effects on the
behaviour. Trying to explain observed effects assuming a homogenous
airmass over a uniform surface (or even one varying regularly) are
interesting to mathematicians but almost totally irrelevant to soaring
pilots.
At 01:13 20 December 2008, bagmaker wrote:
snip-
-snip
What bunk
bagger
bagmaker
Old December 20th 08, 11:30 AM posted to rec.aviation.soaring
John Smith
Default Clouds
Bagger sould perhaps remind himself that there is probably more in the
whole study than is reflected in a magazine's headline.
Old December 20th 08, 09:08 PM posted to rec.aviation.soaring
Eric Greenwell
Default Clouds
pilots.
And yet, the Blipmap cumulus forecasts for cloud location, cloudbase,
and cumulus potential are relevant and useful to soaring pilots. Don't
these values come from the models?
* Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4
* New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more
Clouds and Class B Mxsmanic Piloting 162 June 9th 08 02:27 PM
PH-GRD breaking through the clouds Tom Hayden Aviation Photos 0 October 2nd 07 08:40 PM
How clouds are made Glenn[_2_] Aviation Photos 1 October 2nd 07 05:28 AM
Blue Clouds Mark Cherry Simulators 0 September 21st 03 12:57 PM
