To A Few:
Yes, I think what you're doing is funny, as in worth a laugh. Not in the building nor the rib-stitching but in that part of rib-stitching that you are finding so difficult. It's funny because IT ISN'T IMPORTANT. And you would know that for yourself if you'll just back away from it for a moment and think about it. The Load appears in the fabric. Okay so far. The load is transferred INTO the ribs by the stitching, for which it appears you have used a section of Anchor Cable good for about 60psi, or thereabouts. Which is where I started to smile. But the amount of load 'seen' by an individual rib-stitch is relatively small, and that's where I started to chuckle because you've failed to work-out that amount for yourself. So let's do that before you loose your kewl entirely and start sending Nasty Grams to guys like me who are really trying to HELP you, even if that does not appear to be the case. So here we go, working out the load as 'seen' by your stitches: First off, there's several ways to work it out. I'm interested in seeing which method you use but we can IGNORE any load that appears in the leading edge because for all practical purposes that particular load never makes it past the SPAR. I see a span of about 24 feet and a chord of about four feet, with very generous 'abouts' because the center-section has a nice big cut-out so you can get into the cockpit without surgery, and because your tips are not square. But for the purpose of this example let's call the span 24 feet. Using a 4-foot chord is fairly safe but here again, it is NOT precise becuase of the cut-out & curvey bits previously mentioned. And you want to pull SIX G's. Lemme ask you something... Have you ever done that? Seriously; have you ever strapped yourself into a flying machine and gone out and ACTUALLY PULLED SIX GEE's? Okay, I didn't think so. So let's come back to that later. Right now let's take your twenty-four feet of span and multiply it by four feet of chord and come up with our mythical 96 square feet of lifting surface. (Yeah, I know. Just work with me here for a minute.) Now lets take that mythical 800 pounds of gross weight and divide it by those 96 square feet and come up with the 8.33 pounds per square foot... which you'll note is about the same thing you got in your first message, okay? Now lets 'fit' that weight to one of your rib-bays. First off, we know that most of the lift -- about 65% of it -- is generated by the first third of the airfoil. Yeah, pitch has a lot to do with it but here again, let's just fiddle with the numbers for a while. See that 14" rib bay? The one between the 16" bay and the 12" bay? Let's use that one. Fourteen inches is 1.16 FEET, so we know that section of the wing 'sees' 8.33 pounds times 1.16 feet, or about 9.66 pounds. Now this is where I started to laugh, so follow me through here. All of the loads picked up by this rib bay get coupled into the spars. The leading edge -- the first ten inches of the chord-wise slice through your wing -- go directly into the main spar. The fourteen or so inches that extend beyond the rear spar will appear in that spar. The tricky bit is what happens to the loads that appear BETWEEN the two spars -- the two feet (24 inches) where you start rib- stitching. And keep right ON rib-stitching, all the way back to the trailing edge. Where you went astray, and the reason I got to laughing at those pictures -- is because the loads are INSIDE OF THE SPARS. You've no reason to start using that 80 lb braided fishing line. The load(s) that appear in the skins of your wings are ALWAYS about the same from root to tip. They don't get added together until they get INSIDE of your spars. So I hope you'll agree that it was a pretty good joke, seeing you graduate from regular rib-stitch cord to something heavier... and then heavier still. So how heavy a cord do you need? I think the stuff I use runs about forty pounds but it's awful heavy stuff. I 'm sure I could get with something of lighter weight. But I bought a whole spool of the stuff during the Eisenhower administration and it looks like I'll be using it until the cows come home. -R.S.Hoover |
wrote in message ... To A Few: Yes, I think what you're doing is funny, as in worth a laugh. Not in the building nor the rib-stitching but in that part of rib-stitching that you are finding so difficult. It's funny because IT ISN'T IMPORTANT. And you would know that for yourself if you'll just back away from it for a moment and think about it. The Load appears in the fabric. Okay so far. (Much snipped) What he says. German aircraft prior to V-E Day used sewing thread to stitch the fabric to fabric wrapped around or doped to the ribs. Even on the rocket-powered Me163. Bob |
On Dec 27, 8:23*pm, " wrote:
To A Few: Now lets take that mythical 800 pounds of gross weight and divide it by those 96 square feet and come up with the 8.33 pounds per square foot... which you'll note is about the same thing you got in your first message, okay? 8.33 lbs = weight of one gallon of water. Your plane will float upside down. Mark Starfleet Inspector |
Yo, Starfleet Inspector...
I STILL got yelled at, privately and in Excellent Grammar, properly spelled (rather than spelt) for my laughter at Another's Expense, but only because I failled to mention TAPES, which is where the load actually goes, rather than fabric, and he's right, in a way, but so am I and we both know he's just picking at an old, hard scab 'cause he was wrong once before on a correction and I sent him a zzinger and he had to admit he meant to say X instead of Y and thank you very much and what a Swell Fellow I was for not doing so publicly and I found the pre-packaged msg that sed 90% (mebbe more) of my mail is like that (which is still true) but now that I'm sort of dying-off, I've been making it sort of public/private because when you're feeling like S**t and your best Physician is not quite as old as your best pair of boots, it sort of changes your view of things and you become less of a Kind and Gentle Man and become more of the mean sonofabitch type who will light up a good cigar in front of a Bad painting because I know the difference even if I haven't had my ticket punched by one of those Ivy Leage schools (or any school at all, come to think of it... although one was very nice about offering me something for saying nice things about... I forget what... something they did... and 'ol Bucky Brewster was already dead and they tend to like his dry blood-letting as compared to my Riding into Town, reins in my teeth, shooting right & left and actually HITTING something, unlike Bucky, who didn't (and didn't believe I could until I showed him how). But seriously, after paying all tht money for that insignificant piece of paper to hang on their wall, you really owe it to them to find someone else to Bless them on their Way. (And besides, I've already got a D.Phil. and was sorta hoping for something more grandiose. ) Bob Hoover (No, I'm STILL the other one. And will always be.) |
On Sun, 28 Dec 2008 10:18:49 -0800 (PST), "
wrote: Yo, Starfleet Inspector... I STILL got yelled at, privately and in Excellent Grammar, properly spelled (rather than spelt) for my laughter at Another's Expense, but only because I failled to mention TAPES, which is where the load actually goes, rather than fabric, and he's right, in a way, but so am I and we both know he's just picking at an old, hard scab 'cause he was wrong once before on a correction and I sent him a zzinger and he had to admit he meant to say X instead of Y and thank you very much and what a Swell Fellow I was for not doing so publicly and I found the pre-packaged msg that sed 90% (mebbe more) of my mail is like that (which is still true) but now that I'm sort of dying-off, I've been making it sort of public/private because when you're feeling like S**t and your best Physician is not quite as old as your best pair of boots, it sort of changes your view of things and you become less of a Kind and Gentle Man and become more of the mean sonofabitch type who will light up a good cigar in front of a Bad painting because I know the difference even if I haven't had my ticket punched by one of those Ivy Leage schools (or any school at all, come to think of it... although one was very nice about offering me something for saying nice things about... I forget what... something they did... and 'ol Bucky Brewster was already dead and they tend to like his dry blood-letting as compared to my Riding into Town, reins in my teeth, shooting right & left and actually HITTING something, unlike Bucky, who didn't (and didn't believe I could until I showed him how). But seriously, after paying all tht money for that insignificant piece of paper to hang on their wall, you really owe it to them to find someone else to Bless them on their Way. (And besides, I've already got a D.Phil. and was sorta hoping for something more grandiose. ) Bob Hoover (No, I'm STILL the other one. And will always be.) I'm one of the few people in the world with a tractor but no PhD. I can see that you've made a mistake there. If you have a PhD I'd normally defer to your wisdom but my mate who has two PhD's is a bit insistent that I speaque up. you are correct that the rib stitching just sees the local air pressures and that the air pressures arent additive, the effect of their combined moments in the spars is accumulatve as you mention. where you come unstuque is that you have neglected the increased airflow in the slipstream behind the prop. this area doesnt need thicker rib stitching. the technique is to use the same rib stich string but make the loops closer together. in other words use more loops per foot of rib. ac43-13 has some good guidance and a table that gives the rib stitch distance as related to airpeed. you can find ac43-13 as a free download on the web. why did I use speaque instead of speak, unstuque instead of unstuck? I didnt want to be that hard nosed in correcting him :-) keep up the good work bob. oh PhD's make you so authoritative that you should strive for one. PhD = post hole digger. they go really well on the power takeoff of your average tractor :-) why my mate has two post hole diggers I'll never know. :-) Stealth Pilot |
"Stealth Pilot" wrote PhD = post hole digger. they go really well on the power takeoff of your average tractor :-) why my mate has two post hole diggers I'll never know. :-) You need two of them, for when one is at the doctor's office. You know, the PhD's office, for when it is broke! If it wasn't broke before it went, it will be when it gets the bill! g -- Jim in NC |
| Rib stitching vs glueing | [email protected] | Home Built | 30 | October 19th 05 04:25 AM |
| Any Info on Hipec? No Rib Stitching? | bling bling | Home Built | 5 | November 19th 03 10:24 PM |
| Sewing Needle Suitable for Hand-Stitching Heavy Stuff Like Canvas and Carpet | ThJester99 | Home Built | 4 | August 6th 03 08:26 PM |
| Sewing Needle Suitable for Hand-Stitching Heavy Stuff Like Canvas and Carpet | Larry Smith | Home Built | 0 | August 4th 03 02:31 PM |
| Sewing Needle Suitable for Hand-Stitching Heavy Stuff Like Canvasand Carpet | Shelly | Home Built | 0 | August 2nd 03 06:42 PM |
