PDA Recommendations
Old January 7th 09, 05:54 PM posted to rec.aviation.soaring
kd6veb
Default PDA Recommendations
Hi Gang
All the common PDAs are marginal at best in bright sunlight. I have
been running an Ipaq 5555 for a couple of years with GN11. Initially I
ran it as a self contained unit and touched the screen every time I
needed to turn the display on for 10 seconds to read info. Ultimately
I connected it through a USB power connect to the main glider battery
to keep the display permanently on at maximum brightness. This works
fine and the display is visible in bright sunlight. I have thought
about replacing the PDA with one of the newer much larger and brighter
systems now available and if I were to ever buy a new glider I would
design the instrument panel to accept one. However retrofitting into
an existing panel poses problems and I believe that the PDA format
will be with us for some time yet. One thing I would emphasize is that
if you are going to update your PDA the new one should be self
contained including the GPS.
Dave
Old January 7th 09, 06:53 PM posted to rec.aviation.soaring
bildan
On Jan 7, 3:15*am, Jim White
My 3970 that runs Winpilot has died and I need to replace it. I have a 3900
cradle fitted to the cockpit. What can you guys recommend that will run
Winpilot?
I believe the 5500 series IPAQ will fit in the same cradle. Can anyone
confirm this? What about other models?
The IPAQ 214 is more powerful but I would have to feed it by bluetooth.
Has anyone done this?
Which model has the brightest screen? I am getting older and the eyes
don't work as well as they did!
Will Winpilot run on the HP314? This has a big bright screen and is very
cheap.
Suggestions based on experience would be very welcome.
Thanks
Maybe there's help on the way,
See: http://blog.wired.com/gadgets/2009/0...ble-wrist.html
Various sources say these screens are good to excellent in direct
sunlight and they use far less power than an LCD.
See also: http://www.dailymotion.com/video/x5v...artok_creation
It's only black and white but the speed is plenty fast. The power
requirements are minimal.
The CES show in Las Vegas this week may have some interesting gadgets.
Bill Daniels
Old January 7th 09, 07:20 PM posted to rec.aviation.soaring
Tuno
snip if you are going to update your PDA the new one should be self
contained including the GPS. /snip
Dave, that would not work for me -- the PDA software I use (WinPilot,
GNII or SeeYou Mobile, depending on the coin toss) all use ASI,
pressure altitude, and vario sentences from the 302. Hence, WinPilot
ADV would work with only GPS/NMEA, but WinPilot PRO the others would
not.
-ted/2NO
Old January 7th 09, 08:52 PM posted to rec.aviation.soaring
Richard[_9_]
On Jan 7, 8:56*am, Mike wrote:
On Jan 7, 5:33*am, "Paul Remde" wrote:
Hi Jim,
Please see my notes below.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.http://www.cumulus-soaring.com
"Jim White" wrote in message
3900
Winpilot?
*- Your cradle will work with any iPAQ h3800, h3900 or h5000 series Pocket
PC. *Many glider pilots consider the h3800 to be the easiest of those to
read in sunlight. *You can probably find a good used one on eBay.
*- I have done testing with both a CF Card Serial Port and using the K6 Bt
BlueTooth Adapter in my iPAQ 210. *The serial port option is less "elegant"
looking, but works well for all communications and with all soaring
software. *The K6 Bt connection works well with software that has been
written to work with it. *I don't know if WinPilot supports the K6 Bt..
SeeYou Mobile does.
*- Unfortunately, no PDA is great in sunlight. *The iPAQ h3800 would be
slightly easier to see than your h3900. *The iPAQ hx4700 is bigger, higher
resolution and a little brighter and the iPAQ 210 is a the same size and
resolution as the hx4700 and a little brighter. *I think the iPAQ 310 is the
brightest option.
cheap.
*- The K6 Bt BlueTooth Adapter works great with the iPAQ 310/314, but I
Checking the XCSoar forum it seems that some folks using the HP 310
are not that impressed with the display in sunlight.
It turns out to be no better than a good IPAQ in comparison.
The HP38XX series seems to be best.
The link below will show photo comparisons and opinions from users.
http://www.nabble.com/Adding-a-seria...o20825419.html
Mike
*- If I were you I would first try to find a used h3800 on ebay.
*- If you want a "wired" connection I recommend the iPAQ 210 with a CF
Serial Card. *You can see details on that hehttp://www.cumulus-soaring.com/nimbus.htm
*- If you find the WinPilot will work with the K6 Bt BlueTooth Adapter then
you may want to consider the iPAQ 310/314. *You can see details on the K6 Bt
hehttp://www.cumulus-soaring.com/k6.htm
Thanks
Jim- Hide quoted text -
- Show quoted text -- Hide quoted text -
Mike,
I have compared the ipaq 310 side to side with the Ipaq 5555 and Ipaq
4700 and I also not impressed the difference in my opinoin is slight.
During the design of the Craggy Aero Ultimate. I found that many
problems with visibitiy are due to the touchscreen overlay. If you
want to ruin a display put a touchsceen overlay on it.
Luminisity, Contrast Ratio, and Brightness are also important factors
and the ipaqs do not have high enough values. I designed the Ultimate
so Sunlight does not effect the visibilty.
Richard
www.craggyaero.com
Old January 7th 09, 09:58 PM posted to rec.aviation.soaring
Hi Jim,
Good Soaring,
Paul Remde
3900
Winpilot?
Old January 8th 09, 08:13 PM posted to rec.aviation.soaring
Richard[_9_]
Hi Jim,
Good Soaring,
Paul Remde
3900
Winpilot?
SeeYou Mobile does.
brightest option.
cheap.
Mike
Thanks
Mike,
problems with visibitiy are due to the touchscreen overlay. *If you
Luminisity, Contrast Ratio, and *Brightness are also important factors
so *Sunlight does not effect the visibilty.
Richardwww.craggyaero.com
Owning both I can't agree that the difference between the visibility
of 4700 and 310/314 is slight. *The data says that the 314 display
puts out about 4 times the light but subjectively I would say that the
314 is about twice as readable in bright sunlight *- that is comparing
with identical SeeYouMobile map displays on both units. *Nothing to
match the Ultimate I am sure but well worth the cost of a discounted
314 (around £90-100 in the UK). *The 314 does not need an additional
anti-reflective overlay that might reduce visibility.
To digress: the main problem with visibility for any display that is
mounted above the panel is that all are almost invisible when the sun
is low and in front of the pilot - the contrast is too great for the
eyes to deal with irrespective of the luminosity of the display - even
a map is barely readable in that situation. *I think that is one of
the reasons that lower, in-panel mounted, LCD displays are so much
better for visibility. *It seems to have been accepted wisdom that
PDAs should be mounted high for look-out safety reasons but I doubt
that the benefits of that positioning are outweighed by the amount of
time peering at the display to make it out.
John Galloway- Hide quoted text -
John,
I guess we really do disagree. I am not using any screen protectors
on the 4700, I have found it is best without one. Maybe the sun in
you part of the world is different or maybe a 310 is different from a
314 or maybe I have a really poor 310. I just made a comparison
outside in direct sunlight between a 310 and a 4700 with no screen
protector. running SeeYou Mobile both on full backlight both with the
same map. With the sun directly shining on the screens the 4700 was
readable the 310 was not readable and I could barly distinguish the
map or labels for turnpoints. The anitglare on the 310 totally washed
out the screen. I do agree with the sun in your eyes both are very
hard to read but the 4700 was still better. Also inside, out of the
sun the 310 was brighter but that does not seem to equate to
readability in the sun.
Richard
www.craggyaero.com
Old January 8th 09, 09:29 PM posted to rec.aviation.soaring
Hi Jim,
Good Soaring,
Paul Remde
3900
Winpilot?
SeeYou Mobile does.
brightest option.
cheap.
Mike
*- If I were you I would first try to find a used h3800 on ebay..
Thanks
Mike,
John,
I guess we really do disagree. *I am not using any screen protectors
on the 4700, I have found it is best without one. *Maybe the sun in
314 or maybe I have a really poor 310. * *I just made a comparison
same map. * With the sun *directly shining on the screens the 4700 was
readable the 310 was not readable and *I could barly distinguish the
map or labels for turnpoints. *The anitglare on the 310 totally washed
out the screen. * I do agree with the sun in your eyes both are very
hard to read but the 4700 was still better. *Also inside, out of the
The transflectve display in the 4700 certainly responds well to sun
directly on the screen - in fact the backlight is not needed in that
situation - whereas the transmissive display in the 314 needs maximum
backlight. Most of the time, for me, the problem with the 4700 is
that in general ambient bright light from most sun directions other
than directly over the shoulder onto the screen, the screen is barely
visible. I resorted to flip-up sun specs so that I could view the
4700 screen through clear lenses and use the flipped up lenses as a
sort of sun-visor.
Happily it looks as if this may all be moot as I see that yesterday
there was launched a netbook computer with a 5 inch 800x480 OLED touch
screen, so one hopes that properly sunlight useable low power screens
in simpler devices may soon follow:
http://www.dynamism.com/?gclid=COWbw...oduct=oqo2plus
http://www.oqo.com/intl/
John Galloway
DME recommendations mindenpilot Owning 27 April 11th 05 05:23 PM
Recommendations - near FLL Hilton Piloting 2 March 16th 05 06:04 AM
CHT recommendations Dude Owning 3 December 26th 04 05:07 PM
MFD recommendations Richard Kaplan Owning 13 January 27th 04 04:04 PM
Kit recommendations another fool Home Built 9 November 10th 03 03:29 PM
