SeeYou Flight Display
Old January 11th 09, 07:26 AM posted to rec.aviation.soaring
Greg Arnold[_2_]
Default SeeYou Flight Display
Bruce wrote:
Darryl
I do not know the Cambridge 302 - but on the LX loggers you can add a
long list of optional data to the B record. It does consume memory, but
that is no problem with the LX toys...
No idea where / how / if you even can set this on a 302 - but it is
certainly worth exploring.
No way to put this info in the 302 record.
Old January 11th 09, 07:33 AM posted to rec.aviation.soaring
Darryl Ramm
On Jan 10, 11:20*pm, Bruce wrote:
Darryl Ramm wrote:
On Jan 10, 8:34 pm, Papa3 wrote:
On Jan 10, 5:21 pm, Hal wrote:
I downloaded a flight yesterday from the Cambridge 302. *When
displaying with SeeYou there was no wind data. *The wind data was
there on a previous flight. *I assume the problem is with the 302
log. *Anyone seen this problem before?
Hal,
Others have answered, but just thought I'd clarify. *I'm assuming the
SeeYou you're talking about above is the desktop version and you were
using it for post-flight analysis (since you say "I downloaded", seems
pretty clear but just checking).
Anyway, if you look at the specs for the IGC log file, you'll see that
the only position data stored is location and time. * None of the
calculated data (such as wind) is stored. *Thus, whatever SeeYou
displays is based in post-flight calculation using only on position
and time data. * As others have pointed out, unless you have some
amount of drift in circling flight, it's impossible for a post-flight
analysis using only this position data to determine wind.
P3
Sory, this may be a common misconception, but it is not correct. IGC
files B records can contain more than position and time, including ENL
(engine noise) and the magic TAS data used for enhanced wind
calculations. And See You will use that to enhance wind calculations
just as SeeYou Mobile and WinPilog Pro uses. If your sample rate is
fast enough (1 sec?) you should get a fairly accurate replay of the
wind you PDA/computer told you existed during the flight. But yes it a
recalculation, nothing is writing pre-computed wind data to the IGC
file.
Darryl
Unfortunately you can't configure the data in the 302 IGC file B
records, at least not as far as I know. If it is doable it is very
well hidden. The thing to do is record a second IGC file through
WinPilot or SeeYou Mobile or other software that supports logging the
TAS data.
The table of IGC file data options that vendors can support goes on
for several pages in the IGC GNSS flight recorder spec. TAS is just
one of them.
Darryl
Old January 11th 09, 12:27 PM posted to rec.aviation.soaring
Papa3
Hal,
P3
file.
Darryl- Hide quoted text -
- Show quoted text -
Well, I guess that explains all those I and J records I'd been
ignoring all these years... :-)
Apologies for the mis-information. It seems like I've only ever
received for evaluation IGC files with the mandatory B record
information (aka basic data) for the last umpteen years. I had
assumed that these optional fields weren't implemented, but I stand
corrected.
Humbly,
P3
Seeyou NMEA to Winpilot/Seeyou Jean Soaring 4 June 3rd 06 11:38 AM
U.S. Cloud Images for flight display [email protected] Soaring 0 January 21st 06 07:37 PM
OLC 2006 flight uploads with SeeYou Ted Wagner Soaring 2 October 15th 05 05:31 AM
Dynamic Contest Flight Display Bob Soaring 0 August 8th 05 01:38 PM
OQO Handtop computer for flight display. Guy Byars Owning 2 June 28th 05 03:09 PM
