Zaon MRX causing radio interference
Old March 24th 09, 10:33 PM posted to rec.aviation.soaring
Eric Greenwell
Default Zaon MRX causing radio interference
jcarlyle wrote:
It was 300-400 feet off, sometimes above and sometimes below us - and
we were doing a normal tow, not boxing the wake. Vents were closed (it
was 35 degrees F on the ground before takeoff). Hopefully he and I
will be able to fly together within the next month. I've got a Becker
ATC4401 that reports the encoded altitude, so we'll be able to compare
that with his MRX in real time at different separation distances and
heights.
Does his glider have a transponder in it?
Do you know that the towplane encoder was working correctly?
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
* Sections on Mode S, TPAS, ADS-B, Flarm, more
Old March 24th 09, 11:06 PM posted to rec.aviation.soaring
Darryl Ramm
heights.
Lets play 20 questions... :-)
Since the temperature was cold. Was this the first tow of the day? Any
chance the transponder had just been turned on within a few minutes
earlier and was still warming up?
17 more questions to go.
Darryl
Old March 24th 09, 11:59 PM posted to rec.aviation.soaring
jcarlyle
Eric, the club G103 we were in does not have a transpondert. The
towplane encoder is working properly according to ATC.
Darryl, it wasn't the first tow of the day, so yes, the encoder was
warmed up. Let's ask the other 17 questions after I fly my transponder
equipped glider with him and his MRX in his non-transponder equipped
glider.
-John
heights.
Darryl
Old March 25th 09, 02:43 AM posted to rec.aviation.soaring
Eric Greenwell
heights.
OK, then the MRX should be using it's internal altimeter, as Darryl
thought. If the encoder altitude output is a just a little erratic,
you'd be able to notice while ATC might not. They would not be able to
tell the difference between an unsteady climb and a slightly erratic
encoder, I'm guessing.
glider.
Or, you could fly with the MRX in your glider, which would make the MRX
use your encoder altitude instead of it's internal altimeter. That might
tell you if the problem is the internal altimeter.
Old March 26th 09, 02:00 PM posted to rec.aviation.soaring
Andy[_1_]
heights.
The MRX internal baro altitude is both displayable and adjustable. It
should not require any other equipment, except an accurate altimeter
set to 29.92, to determine if the problem is the MRX baro sensor.
Andy
Old March 26th 09, 03:22 PM posted to rec.aviation.soaring
jcarlyle
Do you know if this function is available in older MRX versions? The
manual which came with my unit (bought August 2006) does not mention
such a capability. I see that the latest manual on the Zaon web site
does explain how to access this function, though. I'll see if my unit
allows me to get to the altimeter calibration menu when I'm next at
the airport.
-John
Andy
Old March 26th 09, 06:49 PM posted to rec.aviation.soaring
Andy[_1_]
the airport.
Don't know when this feature was included. I would suspect it has
always been there but maybe not documented in the user manual. I have
a fairly early unit but I had it upgraded to the latest firmware last
year as I needed the new function that distinguishes whether the
internal baro sensor, or the host aircraft transponder, is being used
for reference altitude. I had not attempted the baro calibration
before the firmware update.
If you have no host aircraft transponder, pressing the multifunction
switch left will report the internal pressure alt being used. If you
do this several times and always see the same pressure altitude it
would suggest that the internal baro sensor is not erratic. If you
find it is constant but not correct, then try the calibration
procedure.
I have found Zaon customer service to be excellent so don't hesitate
to contact them if you need to.
Andy
Flight computer - radio interference cernauta Soaring 3 August 1st 08 02:37 PM
FM radio interference from planes rb Piloting 34 July 19th 06 05:53 PM
GPS / radio interference Cub Driver Piloting 2 October 31st 04 10:57 PM
radio / vario interference - HELP! Chris Davison Soaring 13 November 3rd 03 06:09 AM
Radio Interference Information Ross Richardson Piloting 0 October 17th 03 02:06 PM
