What to use to make a mold?
Old March 25th 09, 03:03 PM posted to rec.aviation.soaring
The Real Doctor
Default What to use to make a mold?
On 24 Mar, 23:05, AK wrote:
Ian, I create a mold first then I pour lead into the mold. Later I
break the mold up and I use fiberglass to cover the lead so it is
trapped and I am not exposed to lead dust.
I don't think you need worry about lead dust. I used to fly a Club
Libelle (not a Libelle owned by a club) which had a 1/4" sheet of lead
under the pilot's seat - if that's the sort of thing you need then why
not glue a thin layer of energy absorbing foam to each side and make
yourself a very heavy cushion?
Ian
Old March 26th 09, 06:15 AM posted to rec.aviation.soaring
Z Goudie[_2_]
At 15:03 25 March 2009, The Real Doctor wrote:
why
And have it hit you hard in the back of the legs under high g if you plant
the glider?
Always a good idea to have any necessary forward of CG ballast in front of
the pilot.
Old March 26th 09, 02:21 PM posted to rec.aviation.soaring
Andy[_1_]
the pilot.
That may depend on whether the objective is to adjust CG, or to
increase flying weight.
Andy
Old March 26th 09, 02:35 PM posted to rec.aviation.soaring
The Real Doctor
why
the glider?
He has said elsewhere, I think, that this is for placing under him.
And he could fasten the cushion down.
the pilot.
In general yes, but surely it depends entirely on the glider's weight,
balance and limits?
Ian
Old March 26th 09, 06:38 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
On Tue, 24 Mar 2009 19:20:32 -0700, AK wrote:
Is this for a private glider of for use in a club glider?
IOW, what are your options for placing the weight and for securing it?
- if you have to sit on it then sheet bent to match the seat pan
would minimize its effect on your headroom, but securing it
properly could be difficult.
- putting a block of lead in the nose is safest (its on the scene of
the crash before you get there), and securing it may be somewhat easier,
particularly if you use sheet lead and the securing bolts also hold
the sheets together. Last but not least the forces you need to
anchor it against would be less (launch acceleration, sliding back
during a winch launch)
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 26th 09, 09:00 PM posted to rec.aviation.soaring
Z Goudie[_2_]
I would be worried about the design strength of any fastenings to flimsy
seat pans during high g impact decelerations.
balance and limits?
If it's for C of G positioning then the further forward the less mass
needed. You may exceed the all up weight limit with sufficient mass at
the seat lever arm for CG positioning; also I'd not be particularly happy
about speed performance ballast I couldn't get rid of in the air if I
ended up low and scratchy!
Old March 27th 09, 10:17 AM posted to rec.aviation.soaring
The Real Doctor
I'd be concerned about doing them right...
balance and limits?
... I'd not be particularly happy
Having spent 5 hours 4 minutes sitting on a 1/4" lead sheet in a Club
Libelle below 2000' in France, I can assure you that "low and
scratchy" takes on a whole new meaning.
Ian
Lyc IO-540 won't make RPM. [email protected] Owning 12 December 14th 06 10:21 PM
How did he make this joint? Michael Horowitz Home Built 4 September 16th 05 06:14 PM
Fiberglass / Mold release advice requested Mark Zivley Home Built 10 April 2nd 04 11:15 PM
How much does a CFI make? Peter Gibbons Piloting 27 August 17th 03 02:48 AM
$$$'s make right? Sydney Hoeltzli Piloting 9 July 15th 03 04:54 AM
