Parachute option
Old April 1st 09, 12:43 AM posted to rec.aviation.soaring
Fred Blair
Default Parachute option
What is the lightest, smallest parachute that will support a 200 lb. pilot?
Fred
Old April 1st 09, 02:06 AM posted to rec.aviation.soaring
5Z
On Mar 31, 4:43*pm, "Fred Blair"
Fred
Take a look at http://www.butlerparachutes.com/
Mine is quite small.
-Tom
Old April 1st 09, 02:50 AM posted to rec.aviation.soaring
Mike the Strike
It depends - what speed do you want to hit the ground?
Mike
Old April 1st 09, 04:42 PM
tomcatvf51 tomcatvf51 is offline
Junior Member
First recorded activity by AviationBanter: Oct 2006
Fred Blair;688425]What is the lightest, smallest parachute that will support a 200 lb. pilot?
Where do you live? Your choice of parachutes will be different if most of your soaring was done in the UK versus Colorado.
- Barry Muhlenberg
Old April 1st 09, 05:32 PM posted to rec.aviation.soaring
Berry[_2_]
Fred
Nationals are/used to be the lightest of the parachutes available in the
U.S.
My National 360 is not very comfortable in my Libelle, but I bought it
primarily for use in power plane with a very small cockpit. I like my
Strong 305 for glider use.
Old April 1st 09, 08:54 PM posted to rec.aviation.soaring
Fred Blair
Texas mostly
"tomcatvf51" wrote in message
- Barry Muhlenberg
tomcatvf51
Old April 2nd 09, 07:21 AM posted to rec.aviation.soaring
On Mar 31, 3:43*pm, "Fred Blair"
Fred
Here you go: http://www.youtube.com/watch?v=92bkf1mg24Q
You can just keep it in your shirt pocket.
Old April 2nd 09, 02:54 PM posted to rec.aviation.soaring
Fred Blair
Looks a little bulky for my Libelle.
On Mar 31, 3:43 pm, "Fred Blair"
pilot?
Fred
Old April 3rd 09, 04:10 PM posted to rec.aviation.soaring
On Mar 31, 6:43*pm, "Fred Blair"
"Small" isn't precise enough. If you're tall, it also depends on your
ratio of torso height to leg length. For me (6'3"), the critical
factor is where the point of maximum thickness is. I need a chute
that's thicker in the lumbar area but very thin behind the shoulders
so I can sit back ALL the way in the cockpit and close the canopy.
Most chutes are uniformly thick or a little thicker behind the
shoulders and don't work at all for me. That said, I flew a 201
Libelle for years with an old Navy backpack that wasn't thin (or
light) at all. From the specs and photos, the best solution (in the
US) seemed to be a Softie Wedge. I bought a used one with a new canopy
and it came packed just like a regular Softie; i.e., not nearly thin
enough behind the shoulders. I sent it back to the rigger with
instructions to pack it like the photo. When it was returned, it was
better--and usable--but still much thicker behind the shoulders than I
wanted. I talked to the factory and they told me to send it to them
for repacking and they'd make sure it was done right. Haven't done
that yet so I'm hopeful.
Which brings up a good point: if you buy a chute like this, don't
assume the rigger will pack it the same way. I've had to deal with
this for years. Include the owner's manual but also a note regarding
where you want the maximum thickness.
Chip Bearden
ASW 24 "JB"
USA
Old April 4th 09, 01:57 AM posted to rec.aviation.soaring
Papa3
wrote: What is the lightest, smallest parachute that will support a 200 lb. pilot?
Chip Bearden
ASW 24 "JB"
USA
Absolutely - there's a lot of lattitude in the packing. I have a
National 425 which I can have packed with a uniform thickness or with
a "reverse taper" that puts more material at the lower (lumbar) area
and less at the top. I think you should have a conversation with the
dealer/manufacturer and describe your specific needs. You may be
pleasantly surprised.
2K Paint Option on S-H Ventus? V1 Soaring 4 February 5th 07 03:53 AM
FS; ASG29 option pat Soaring 2 August 31st 06 11:30 PM
Where is the 4th option? JohnH Piloting 0 May 13th 05 06:07 PM
DG goes the sustainer option. Paul Soaring 25 June 4th 04 01:16 AM
Lease with option to buy Jim Burns Owning 1 May 3rd 04 03:16 PM
