Some improvements to my Airport Information website
Old May 2nd 09, 01:52 AM posted to rec.aviation.soaring
2KA
Default Some improvements to my Airport Information website
As I previously announced (see my posting on April 1), I have built a
little website that publishes US airport information that has been
extracted from the FAA's National Airspace System Resource
subscription files. The site supports several different output
formats including SeeYou .CUP, Cambridge Aero .DAT, and .NDB for the
SN-10. You can also find some hints there for using the data in
Volksloggers and generic Garmin GPS units.
You can access my site at http://www.xmission.com/~lalley/aviation.
Since I did the original implementation, I've made several
improvements:
1. User-selectable lengths for short names in the output file. This
should be especially useful for Garmin GPS devices, different models
of which support different turnpoint name lengths.
2. A proximity search, so that you can use an input turnpoint file
that doesn't contain the IATA ID codes. If an airport turnpoint in
the input file is very close to one in the FAA's database, they are
assumed to be the same.
3. Support for tab-delimited input files that don't contain the full
complement of columns. As long as the input file follows the correct
tab-delimited format and specifies at least the names and geographic
coordinates of the turnpoints, it should work.
4. More explicit error handling when an input file of the incorrect
format is used.
The most common error I have seen so far is the use of an input
turnpoint file of the incorrect type, hence #4 above. I currently
support only SeeYou (.CUP) and tab-delimited.
Since the information on the site is unlicensed, it is free and freely
redistributable. Happy downloading!
Lynn Alley
"2KA"
Old May 2nd 09, 08:45 PM posted to rec.aviation.soaring
Eric Greenwell
I like the AWOS frequencies in the comments - that's useful. Some of the
other details about the runways may help, too.
I suggest another choice for airport area selection: "Entire USA". I
travel with the glider to other areas so I use airports from many area,
and I sometimes look at IGC flights from around the USA, so that's what
I use in SeeYou. In the meantime, I could make a task file with a
turnpoints in Washington state, Maine, Florida, and California, and
accomplish almost the same thing.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
* Sections on Mode S, TPAS, ADS-B, Flarm, more
Old May 3rd 09, 11:30 PM posted to rec.aviation.soaring
2KA
Eric,
Thanks for the suggestion. Actually, tne option for the entire USA
already exists -- if you simply don't specify bounding information,
that's what you get. Both bounding information and input task files
are completely optional. See the help text by following the "Specify
bounding information" and "Upload a task/turnpoint file" links for
more information.
Best,
Lynn
Old May 4th 09, 07:05 AM posted to rec.aviation.soaring
subscription files. *The site supports several different output
SN-10. *You can also find some hints there for using the data in
You can access my site athttp://www.xmission.com/~lalley/aviation.
improvements:
1. *User-selectable lengths for short names in the output file. *This
2. *A proximity search, so that you can use an input turnpoint file
that doesn't contain the IATA ID codes. *If an airport turnpoint in
3. *Support for tab-delimited input files that don't contain the full
complement of columns. *As long as the input file follows the correct
4. *More explicit error handling when an input file of the incorrect
format is used.
turnpoint file of the incorrect type, *hence #4 above. *I currently
redistributable. *Happy downloading!
Lynn Alley
"2KA"
Nice resource!
I like #2 since I often combine files. One question: if i use an
input turnpoint file does the result use the original turnpoint
location or the location from the FAA database. I'd hate to hook a
turnpoint in a contest later to find that i missed because I was using
a relocated turnpoint.
9B
Old May 4th 09, 06:22 PM posted to rec.aviation.soaring
2KA
Hi 9B,
Oooh, that's a good point. It currently uses the location from the
FAA database. I'll change that to use the coordinates from the
turnpoint file. I'll post here when the change is made.
Lynn
"2KA"
Old June 2nd 09, 12:39 AM posted to rec.aviation.soaring
2KA
I've finally gotten around to resolving the issue 9B brought up last
month. My site now uses the geographical coordinates given in the in
an input turnpoint file (if there is one) in preference to those
listed in the FAA database. This was done so that the locations given
in an official contest turnpoint list will not be altered.
I've also corrected a couple of bugs:
1. Turnpoint numbers again appear as part of the long turnpoint names
(CUP files only) for numbered tunpoints. I broke this accidentally
sometime in late April.
2. Turnpoint options (such as A, L, T, etc.) again appear correctly
in output NDB files.
All in all, these changes should make my site a bit more contest
friendly. If you are planning on flying in a contest, I recommend
obtaining the official contest turnpoint list (in tab-delimited form)
from the Worldwide Turnpoint Exchange, and then using it as the input
turnpoint file for my site. The result will be an integrated list
containing the contest turnpoints together with surrounding non-
turnpoint airports. The output file will contain runway widths,
lenghts, surface types, communication frequencies, and contact phone
numbers for all the airports.
Lynn Alley
"2KA"
Yet another source for US Airport Information 2KA Soaring 1 April 5th 09 09:41 PM
Bush Proposes To Cut Funding For Airport Improvements. Larry Dighera Piloting 0 March 11th 08 05:00 PM
INFORMATION TO INCREASE SALES OR TRAFFIC TO YOUR WEBSITE/BUSINESS!! xSoldier Aviation Marketplace 0 January 19th 06 12:58 AM
Website Mltry.- Your Information, Customized for You, Family Communication, Chat, Please Help by Visiting and Signing Gues Wolf Naval Aviation 0 January 8th 05 07:16 AM
Airport Screener Information John Military Aviation 3 September 26th 03 01:46 AM
