Bamboo Propellers
Old May 22nd 09, 08:32 PM posted to rec.aviation.homebuilt
Bob
Default Bamboo Propellers
In a related post I asked if anyone had heard of such a thing. So far
the only response indicates a misunderstanding of how bamboo is used
for such things.
In the tropics -- with Vietnam being a fair example -- bamboo often
has a diameter of several inches. When split AND STEAMED you're left
with a PLANK having remarkable characteristics with regard to strength
& grain.
I assumed any propeller fabricated from bamboo would use such planks,
probably glued in a steam- or water-heated clamp that would impregnate
the grain of the planks with epoxy or something having similar
characteristics. A further assumption on my part was that the airfoil
shape would be routed -- or even MOLDED -- from the section of the
planks that were fully impregnated with the epoxy, which would then
receive a finishing coat.
Perhaps we would be lucky enough to make use of a FURNITURE
MANUFACTURER or some other manufacturer who is already equipped for
dealing with bamboo.
Finally, perhaps someone can point me toward a Group that is more
familiar with Bamboo.
-R.S.Hoover
Old May 22nd 09, 08:57 PM posted to rec.aviation.homebuilt
Philippe[_2_]
for such things.
Never hear obout that, but bamboo laminate for a slow, low power
prop... it seems possible
Regards
« Si tous les poètes voulaient se donner la main, ils toucheraient enfin
des doigts d'auteur! »
Philippe Vessaire Ò¿Ó¬
Old May 22nd 09, 11:52 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Bamboo floor company
http://www.ambientbp.com/index.htm
Old May 23rd 09, 12:35 AM posted to rec.aviation.homebuilt
Charlie[_2_]
for such things.
& grain.
-R.S.Hoover
You can buy flooring made from bamboo from lots of flooring dealers. I
wondered about whether it was available in long enough pieces, but it
looks like it is.
http://floorus.com/Bamboo6FPro.aspx
Question is, whether it's stiff enough to make a good prop.
It is an interesting idea, though. The grain should be very straight &
consistent.
Charlie
Old May 23rd 09, 02:27 AM posted to rec.aviation.homebuilt
Charlie[_2_]
for such things.
& grain.
-R.S.Hoover
looks like it is.
consistent.
Charlie
Video of manufacturing process:
http://www.youtube.com/watch?v=_V912q4rZSg
I think that they say urea formaldehyde is used to glue the pieces. Is
that the same stuff used in OSB panels?
Old May 23rd 09, 03:39 AM posted to rec.aviation.homebuilt
Ed
On Fri, 22 May 2009 19:27:18 -0500, Charlie
It is the same stuff used to stick Mosquito bombers together.
Old May 23rd 09, 05:13 AM posted to rec.aviation.homebuilt
cavelamb himself[_5_]
looks like it is.
consistent.
Charlie
The answer, of course, is another question.
What is the propeller being asked to do?
Old May 23rd 09, 03:59 PM posted to rec.aviation.homebuilt
On Fri, 22 May 2009 22:13:19 -0500, cavelamb himself
looks like it is.
consistent.
Charlie
Used to be able to buy Bamboo model aircraft props.
Old May 23rd 09, 10:25 PM posted to rec.aviation.homebuilt
Veeduber[_2_]
To All:
I believe we've made our point, albeit indirectly. Bamboo in the form
of planks is available. We still need more information with regard to
length and thickness. I will create a Bamboo Group to serve as an
archive for information as it is developed.
-R.S.Hoover
Old May 24th 09, 12:44 AM posted to rec.aviation.homebuilt
Veeduber[_2_]
On May 23, 1:25*pm, Veeduber wrote:
*I will create a Bamboo Group to serve as an
Or perhaps not.
The last step in creating a Group is for Yahoo to send a confirming
message to your email address. After a four hour wait, nothing has
appeared.
Perhaps they want only Yahoo email addresses.
If one of you uses Yahoo.com for email perhaps you would care to try
creating a Group specific to aviation & bamboo.
-R.S.Hoover
Pills & Propellers [email protected] Home Built 15 December 3rd 08 02:16 PM
Wooden Propellers Danny Deger Piloting 11 March 4th 07 11:17 AM
Propellers [email protected] Home Built 6 March 30th 06 02:41 PM
Bamboo bomber lost. JDupre5762 Military Aviation 4 May 10th 04 08:04 AM
AT-10 "Bamboo Bomber" Question [email protected] Military Aviation 4 March 18th 04 10:13 PM
