Inspiration for Homebuilders
Old May 26th 09, 12:57 AM posted to rec.aviation.homebuilt
Brian Whatcott
Default Inspiration for Homebuilders
This is a pointer to a home build 20 ft diam windmill on a 70 ft pole.
It features three 10 ft long laminated red cedar blades and nice looking
generator, tower couplings and gin....
http://www.otherpower.com/20page1.html
Brian W
(Thanks to Larry for the pointer on rec.boats)
Old May 26th 09, 04:06 AM posted to rec.aviation.homebuilt
Orval Fairbairn[_2_]
Brian W
I hope that you have good lightning suppression!
Remove _'s from email address to talk to me.
Old May 27th 09, 02:01 AM posted to rec.aviation.homebuilt
Brian Whatcott
Brian W
Ha! I noticed the maker specified a blade angle of 3 degrees at the
tips, increasing to (approaching) 9 degrees at the roots.
It took me a little while to get my head round this. The maker mentioned
the blades are set flat (undersurface) forward into the wind, and I
think he mentioned a target rotation rate of 65 rpm.
I imagine he was thinking of an AoA of 15 degrees at the rated wind. The
tips do a revolution in pi x 20 ft = 63 ft per rev - so the rotation
rate at 65 rpm would give a tip speed of 65rpm X 63ft/rev X 60 min/hr /
5280 ft/mile or 47 mph.
I guess the pitch angle for zero AoA at the starting windspeed 16 mph
would be atan 16/47 = 19 degrees from the plane of revolution, so for 15
deg AoA the pitch angle might be 4 degrees from the plane of revolution
at the tips.
And he mentions 3 degrees. But getting up to speed with stalled blades
would be an issue...
What's your take, Orville?
Regards
Brian W
Old May 27th 09, 02:53 AM posted to rec.aviation.homebuilt
Brian Whatcott
What's your take,
Orval
XXXOrville?XXX
(sorry 'bout that!)
Regards
Brian W
Old May 27th 09, 03:26 AM posted to rec.aviation.homebuilt
Brian W
at the tips.
Regards
Brian W
My first take is that you misspelled my name.
We had a big windmill on our farm when I was growing up. The plane of
rotation was parallel to the wind, rather than at a right angle. The fan
acted more as a wind turbine than a propeller. IIRC, the fan had about a
dozen curved steel blades. It also had a brake on it for when the winds
got too high.
Old May 27th 09, 05:16 AM posted to rec.aviation.homebuilt
jerry wass
Brian W
at the tips.
Regards
Brian W
got too high.
The blades were turned sideways (parallel to the tail) if they didn't
want it to pump any water---If you needed water you operated the lever
that placed the blades perpendicular to the rudder, tail,
whatever,-pointing into the wind, then you got some POWER..---OR--
did you have one of those weird looking things where the blades were
raked back severely at an angle about like the back 2/3 of a snowcone
cup? Jerry
Old May 27th 09, 05:13 PM posted to rec.aviation.homebuilt
Brian W
at the tips.
Regards
Brian W
got too high.
cup? Jerry
Neither. The fan was 10-12 ft diameter, fixed so the wind would always
turn the fan. Since the blades were curved (cambered), the advancing
blade had less drag than the receding blade. I think it was a
Fairbanks-Morse product, but don't hold me to that, and it was built
about 1910.
A lot of windmills in our area (Northern Illinois) were of similar
design.
Old May 28th 09, 01:01 AM posted to rec.aviation.homebuilt
Charlie[_2_]
Brian W
at the tips.
Regards
Brian W
got too high.
cup? Jerry
about 1910.
design.
Sounds like a pelton wheel.
http://www.google.com/search?hl=en&q...on+w&aqi=g 10
Old May 28th 09, 04:07 AM posted to rec.aviation.homebuilt
looking
Brian W
at the tips.
Regards
Brian W
got too high.
cup? Jerry
about 1910.
design.
Nope -- it wasn't a Pelton Wheel!
As I posted earlier, I thought it was a Fairbanks-Morse model.
See the picture at: http://www.agwt.org/store/FairbanksWindmill.htm
The fan disc was parallel to the wind direction. This raises the
question: Could we dispense with the directional pivot and mount the fan
horizontal to the ground? It should be able to rotate with any direction
of wind.
Of course, good lightning protection is a MUST!
Old May 28th 09, 05:54 AM posted to rec.aviation.homebuilt
Dan[_12_]
looking
Brian W
at the tips.
Regards
Brian W
got too high.
cup? Jerry
about 1910.
design.
of wind.
If memory serves the vane's angle could be manually changed as
needed for variations wind speed.
Dan, U.S. Air Force, retired
AN ENGINE FOR HOMEBUILDERS Bob Home Built 65 June 5th 09 07:45 PM
A Camcorder for Homebuilders [email protected] Home Built 3 June 1st 08 03:27 PM
Inspiration by friends - mutal interest and motivation to get the PPL Gary G Piloting 1 October 29th 04 09:19 PM
Best Homebuilders Books? [email protected] Home Built 5 January 21st 04 01:06 AM
"Big" Jon Johanson --- an Inspiration Larry Smith Home Built 0 December 17th 03 05:01 PM
