			#51
			 "Bill Phillips" wrote in message ... "ArtKramr" wrote in message ... ubject: Area bombing is not a dirty word. From: "Bill Phillips" Date: 1/5/04 11:44 AM Pacific Standard Time o you are saying that ALL the bombs dropped during that period were dropped on oil targets! I would love to here your source for that. I never said that, You said that. You said "we stopped bombing production facilites and switched to oil" Which is a LONG way from saying ALL the bombs dropped during the period were dropped on oil targets. Keith  |
			#52
They lied about the effectiveness of German
	bombing at the start of WW2, to justify a counter offensive. Wrong. The USAAF part of the CBO was born out of AWPD-1, first drafted in 1938. The only thing the USAAF can be accused of was too easily dismissing the German failure in the Battle of Britain when they revised AWPD-1 in late 1940. According to most air power experts of that time period, Germany failed because their bombers were ill equipped to the task. They were correct in that regard, but they let that explain away everything and literally learned no lessons from the Battle of Britain. Throughout WW2 they lied about the effectiveness of their bombing to justify throwing good resources after bad. Wrong again. They had a real time intelligence problem with attempting to analyze exactly the results of their bombing. They had excellent photo recon and excellent SIGINT due to Ultra, but a hard time correlating the 2. 60 years later, we are still struggling with this, albeit not nearly as bad. BUFDRVR "Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips everyone on Bear Creek"  |
			#53
    The impact the CBO had
	prior to 1944 was to draw manpower to defend Germany from the front. Every guy manning a AAA piece or fueling a fighter would have been carrying a Mauser-98 on either the eastern or western front if it wasn't for the CBO. Just like all the effort being put into bombing as not available to help the allied armies. Nor could it have been, at least not effectively (see below). At least they kept the Luftwaffe largely in check while also makiong the POL and transportation situations within Germany a nightmare (all three of which were very good things for the "allied armies"). Also the flack units could and did turn their guns on ground targets in the later stages of the war. Great. Imagine how much MORE succesful they would have been had they not had to concentrate all of those resources on defending the homeland and instead had been putting them on more mobile armored platforms. How long would a Kar-98 carrying soldier last if the allies put all that effort into the battlefield?' And pray tell just HOW would you put all of that effort "onto the battlefield"? We know that level bombing was of mixed, at best, tactical value when applied "to the battlefield" (witness COBRA). The allied ground forces in France in late 1944 were about as big as you could manage given logistics constraints (and no, having all of the bombers play transport would not have appreciably changed that picture), so you would not have been reorienting the bombing resources into the ground fight very easily. Sounds like your plan is not very workable. OTOH, having the CBO ongoing prevented what was left of the Luftwaffe in late 44 from being able to effectively focus on supporting their own ground forces opposing the oncoming allied ground juggernaut. It did indeed make the POL situation a critical one for German forces, including those on the ground facing Ike's troops. I just can't see how we could have substantially improved upon the situation by reorienting the resources applied to the CBO--as Buffdrvr points out, we could have better *focused* them to be more effective, given the benefit of hindsight, but in the end the combined weight of *all* of the resources brought to bear, from the CBO to the ground soldiers and TACAIR, working simultaneously to apply pressure to the Germans from all directions and forcing them to try to defend *everywhere* versus concentrating solely upon the ground equation, was the optimal solution to be had. It depends on when you divert the resources. Once you have built bombers you are restricted in what you can do with them. However change early enough and you can build almost anything instead, such as a tank that could take on Tigers and Panthers 1 to 1. Note: resources are a quality issue as well as a quantity one, better equipment could have actually reduced the logistic burden by achieving a given effect with less equipment. Even if it was put into air power then it could have won the battle of the Atlantic earlier and some more CAS and air transport would have been useful for the advance across Europe. For example a little more air power would have turned Operation Market Garden into a victory. Much the same is true of the German efforts.  |
			#54
			 "Keith Willshaw" wrote in message ... "Bill Phillips" wrote in message ... "ArtKramr" wrote in message ... ubject: Area bombing is not a dirty word. From: "Bill Phillips" Date: 1/5/04 11:44 AM Pacific Standard Time o you are saying that ALL the bombs dropped during that period were dropped on oil targets! I would love to here your source for that. I never said that, You said that. You said "we stopped bombing production facilites and switched to oil" Which is a LONG way from saying ALL the bombs dropped during the period were dropped on oil targets. OK there is scope for dropping bombs on things that are neither production or oil. However, STOPPED means that NO bombs were dropped on production facilities, which does not fit what I have heard.  |
			#55
			 "Bill Phillips" wrote in message ... The impact the CBO had prior to 1944 was to draw manpower to defend Germany from the front. Every guy manning a AAA piece or fueling a fighter would have been carrying a Mauser-98 on either the eastern or western front if it wasn't for the CBO. Just like all the effort being put into bombing as not available to help the allied armies. Nor could it have been, at least not effectively (see below). At least they kept the Luftwaffe largely in check while also makiong the POL and transportation situations within Germany a nightmare (all three of which were very good things for the "allied armies"). Also the flack units could and did turn their guns on ground targets in the later stages of the war. Great. Imagine how much MORE succesful they would have been had they not had to concentrate all of those resources on defending the homeland and instead had been putting them on more mobile armored platforms. How long would a Kar-98 carrying soldier last if the allies put all that effort into the battlefield?' And pray tell just HOW would you put all of that effort "onto the battlefield"? We know that level bombing was of mixed, at best, tactical value when applied "to the battlefield" (witness COBRA). The allied ground forces in France in late 1944 were about as big as you could manage given logistics constraints (and no, having all of the bombers play transport would not have appreciably changed that picture), so you would not have been reorienting the bombing resources into the ground fight very easily. Sounds like your plan is not very workable. OTOH, having the CBO ongoing prevented what was left of the Luftwaffe in late 44 from being able to effectively focus on supporting their own ground forces opposing the oncoming allied ground juggernaut. It did indeed make the POL situation a critical one for German forces, including those on the ground facing Ike's troops. I just can't see how we could have substantially improved upon the situation by reorienting the resources applied to the CBO--as Buffdrvr points out, we could have better *focused* them to be more effective, given the benefit of hindsight, but in the end the combined weight of *all* of the resources brought to bear, from the CBO to the ground soldiers and TACAIR, working simultaneously to apply pressure to the Germans from all directions and forcing them to try to defend *everywhere* versus concentrating solely upon the ground equation, was the optimal solution to be had. It depends on when you divert the resources. Once you have built bombers you are restricted in what you can do with them. However change early enough and you can build almost anything instead, such as a tank that could take on Tigers and Panthers 1 to 1. Note: resources are a quality issue as well as a quantity one, better equipment could have actually reduced the logistic burden by achieving a given effect with less equipment. Then you would have had to scrap the entire US military production strategy, which was based upon getting a LOT of "good enough" stuff produced as opposed to the German approach of building a few really good items--we know which side lost, so I would side with the winning strategy. Even if it was put into air power then it could have won the battle of the Atlantic earlier That is not assured. merely tossing a few hundred more aircraft over the ocean was not going to stop the German subs; it took a combination of aircraft and emerging technology (i.e., small radars capable of seeing the surfaced little buggers). Then you would have had to factor in that the germans, not being subjected to any kind of CBO, would have produced even *m ore* boats ata faster pace, and trained them more effectively since there was not the additional effect on their POL supplies, not to mention the fact that all of those flak crews and resources would have been reprogrammed to face your other threats, and their Luftwaffe would have been better able to support operations on *both* fronts, etc, ad nauseum. and some more CAS and air transport would have been useful for the advance across Europe. For example a little more air power would have turned Operation Market Garden into a victory. No freakin' way. The weather shut out air support almost altogether during a critical window of that operation, and a few more C-47's would NOT have affected the outcome at Arnhem. Brooks Much the same is true of the German efforts.  |
			#56
			 "Bill Phillips" wrote in message ... OK there is scope for dropping bombs on things that are neither production or oil. However, STOPPED means that NO bombs were dropped on production facilities, which does not fit what I have heard. In fact there was a switch of emphasis in strategic bombing from industrial towns to oil targets in 1944. The first bomber command raid was that on the synthetic-oil plant at Gelsenkirchen on the night of June 12/13 1944. Indeed the major raids from this point on were directed at military targets (Kiel, Le Havre etc), communications targets, V1/V2 sites and oil targets. It was only in October that raids were once more made on general production targets when raids were made on Dortmund and Duisburg. Keith  |
			#57
			#58
			#59
Subject:  Area bombing is not a dirty word.
	From: (Drazen Kramaric) Date: 1/9/04 4:08 AM Pacific As the war progressed, the AA personnel was largely comprised of people unfit for the front: high school teenagers, girls, WW1 veterans, Soviet POWs etc. They were called the FLAK KINDER and were mostly young men of high school age. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer  |
			#60
			 It depends on when you divert the resources. Once you have built bombers you are restricted in what you can do with them. However change early enough and you can build almost anything instead, such as a tank that could take on Tigers and Panthers 1 to 1. Note: resources are a quality issue as well as a quantity one, better equipment could have actually reduced the logistic burden by achieving a given effect with less equipment. Then you would have had to scrap the entire US military production strategy, which was based upon getting a LOT of "good enough" stuff produced as opposed to the German approach of building a few really good items--we know which side lost, so I would side with the winning strategy. I can't find any evidence that the USAAF were pursuing this strategy; on average its aircraft were as good or better than the enemy's. Much the same can be said of rifles, artillery, ships, etc. So it appears that this "entire" strategy was only applied to tanks. Even if it was put into air power then it could have won the battle of the Atlantic earlier That is not assured. merely tossing a few hundred more aircraft over the ocean was not going to stop the German subs; it took a combination of aircraft and emerging technology (i.e., small radars capable of seeing the surfaced little buggers). I am well aware of the need for technology, I am also aware that the first airborne radars went to the bombers, so that they could bomb through cloud. Then you would have had to factor in that the germans, not being subjected to any kind of CBO, would have produced even *m ore* boats ata faster pace, and trained them more effectively since there was not the additional effect on their POL supplies, not to mention the fact that all of those flak crews and resources would have been reprogrammed to face your other threats, and their Luftwaffe would have been better able to support operations on *both* fronts, etc, ad nauseum. Given that German war production went up under bombing, I doubt that the extra effort going to the front line would be anything like as large as the effort freed from our bombing offensive. and some more CAS and air transport would have been useful for the advance across Europe. For example a little more air power would have turned Operation Market Garden into a victory. No freakin' way. The weather shut out air support almost altogether during a critical window of that operation, and a few more C-47's would NOT have affected the outcome at Arnhem. The biggest single problem at Arnhem was that the RAF took 3 lifts to drop the British airborne div and the Polish Bde. If they had all been dropped on the first lift then they would have quickly seized the bridges, and established a strong defensive position around them. Add a supply drop on D+1 and some CAS to weaken the Germans and they could have easily held during the bad weather, and weeks after.  |
| Thread Tools | |
| Display Modes | |
| AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 07:12 PM |
| ILS Critical Area signage: Localizer or Glideslope? | Adam K. | Instrument Flight Rules | 4 | October 30th 03 11:09 PM |
| Soviet Submarines Losses - WWII | Mike Yared | Military Aviation | 4 | October 30th 03 04:09 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| Patrick AFB Area Log, Monday 30 June 2003 | AllanStern | Military Aviation | 0 | July 1st 03 07:37 AM |
