one man assembly
Old June 7th 09, 11:29 PM posted to rec.aviation.soaring
Default one man assembly
Which one-man assembly dolly is the preferred for 15m?? What dolly
works best if two(older) people are assembling/disassembling and on a
hard surface? Jim
Old June 8th 09, 12:14 AM posted to rec.aviation.soaring
Mike the Strike
On Jun 7, 3:29*pm, wrote:
Which one-man assembly dolly is the preferred for 15m?? * What dolly
works best if *two(older) people are assembling/disassembling and on a
hard surface? *Jim
Many of us in the USA and some overseas have the Wing Rigger built by
our buddy Steve Koerner here in the Phoenix area. Designed to work on
rough surfaces, it's a doddle on a hard surface, like concrete or
asphalt. It has some nice design improvements over some of the others
out there, but I especially like the gas-spring that makes height
adjustment easy.
Mike
Old June 8th 09, 02:59 AM posted to rec.aviation.soaring
hard surface? *Jim
our buddy Steve Koerner here in the Phoenix area. *Designed to work on
asphalt. *It has some nice design improvements over some of the others
adjustment easy.
Mike
Wing Rigger is what I use for my Pik 20D.I used to stress out that the
wings are too heavy for my helper and that it takes too long to
assemble. Now I do it all by my self - no stress and no sweat.I love
it!
Old June 8th 09, 03:46 AM posted to rec.aviation.soaring
bildan
hard surface? *Jim
Whatever you get, it needs to be strong and stable on rough surfaces
if you think you'll use it in a landout.
A few weekends ago I saw what appeared to be and expensive European
unit with electric vertical motion, twist, collapse and dump a glider
wing and it's owner on the ground. Fortunately, neither the wing nor
owner appeared to suffer any lasting damage. The one-man assembly
dolly suffered some trauma, however. Scary.
Old June 8th 09, 03:48 AM posted to rec.aviation.soaring
Tuno
Jim this is a no-brainer these days. Steve Koerner's product is
superior in all aspects, he supports it well, and improves it with
every one he makes.
http://www.wingrigger.com/
Old June 8th 09, 03:51 AM posted to rec.aviation.soaring
Andy[_1_]
hard surface? *Jim
If you have 2 people you don't need a one man assembly dolly, unless
one is a spectator.
I bought an early model Wing Rigger. It's not perfect and there have
been several improvements since I bought mine, but I can rig solo with
less back strain than with a helper and it only takes a couple of
minutes longer than with an experienced person on the tip. It is
quicker and far less risk of damage than having an inexperienced
person on the tip. I also find I am in less of a hurry to clean and
grease the spar bushings as no one has to hold anything.
I still find it quicker and more convenient to de-rig with an
experienced helper but using Wing Rigger to derig is not a problem.
It's just a preferance.
BTW in my opinion the gas spring is completely unnecessary as height
adjustments are easier made with the fuselage dolly jack while
watching the spar bushing alignment (Cobra hydraulic jack). I set the
height of the wing saddle the same every time and very very seldom
have to change it.
Lateral positioning of the wing is done by pulling on a strap to drag
the main dolly wheels sideways. That is actually much easier to do on
dirt than on a paved surface. Getting the alignment right first
attempt is best. I once got both wings on with no lateral adjustment
of either wing but it's seldom I'm that good. With experience you
should only have to shift the dolly a few inches after inserting each
spar.
If you go for a used Wing Rigger be sure to get the right size saddle
for your wings, there have been some changes.
Andy
Old June 8th 09, 04:06 AM posted to rec.aviation.soaring
I do not have direct experience with the Wing Rigger. I have been
using the Cobra one man rigger with a Grob Speed Astir, an LS-8-18,
and an SZD-59 with total karmic harmony. I prefer using a one man
rigger for many of the previously discussed reasons: less damage to
plane from assistant's good intentions, more time to lube pins and
fittings since another person is not risking a hernia while holding
the wing, more freedom at the soaring site because I don't need
another person to rig or de-rig.
I use the Cobra system on gravel, dirt, and pavement. Works very well
in all situations. I have watched other people use the Wing RIgger
and have to say that i prefer the manual crank for elevation control
that the Cobra has over the gas spring system in the Wing RIgger.
However, that is only a matter of taste. Both work great.
Guy
Old June 8th 09, 01:53 PM posted to rec.aviation.soaring
bildan
On Jun 7, 9:06*pm, wrote:
I do not have direct experience with the Wing Rigger. *I have been
and an SZD-59 with total karmic harmony. *I prefer using a one man
rigger for many of the previously discussed reasons: *less damage to
I use the Cobra system on gravel, dirt, and pavement. *Works very well
in all situations. *I have watched other people use the Wing RIgger
However, that is only a matter of taste. *Both work great.
Guy
One of the good things you seldom hear about one-man riggers is the
ease with which the wing spigot pins go in. With the wing balanced on
the rigger, there's little weight on the root so the spar and pins
just sort of float/slide in. Otherwise, there's a lot of weight
riding on those pins as you try to slide them in. That has to mean
less wear.
Old June 11th 09, 04:06 AM posted to rec.aviation.soaring
Frank[_12_]
hard surface? *Jim
My single-rig system consists of a second wing stand and a 8" diameter
by 36" long roll of carpet scrap. Works great on any surface, can't
fall down, and its a LOT cheaper/smaller/lighter than a $1000 assembly
dolly
TA
Old June 11th 09, 04:10 AM posted to rec.aviation.soaring
Tuno
I'd like to see some photos of that!
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6973027.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility (MAF) 6973448.jpg [email protected] Aviation Photos 0 April 11th 07 02:43 AM
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6973447.jpg [email protected] Aviation Photos 0 April 11th 07 02:43 AM
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6522687.jpg [email protected] Aviation Photos 0 April 11th 07 02:43 AM
