I am in a quest to troubleshoot an oil temp that has crept up a bit in the
last 100 hours or so. Checked all the baffling and"usual stuff". I was going to check the accuracy of the gauge via testing. 2 things that I cannot find: the part number of the oil temp sending unit and a supplier. This part does not appear either in the engine parts list or the airplane parts list. Engine is a 150hp E-3D. Any info would be appreciated. Thanks, Mike |
On Sep 5, 3:00 pm, "Mike Spera" wrote:
I am in a quest to troubleshoot an oil temp that has crept up a bit in the last 100 hours or so. Checked all the baffling and"usual stuff". I was going to check the accuracy of the gauge via testing. 2 things that I cannot find: the part number of the oil temp sending unit and a supplier. This part does not appear either in the engine parts list or the airplane parts list. Engine is a 150hp E-3D. Any info would be appreciated. Thanks, Mike Spiking oil temp can sometimes be blamed on poor engine and/or alternator grounding. That little sender is a thermistor whose resistance drops as it gets warm, allowing the electrical system to draw more current out of the engine case, through the gauge and into the bus. Now, the alternator is generating electricity. It charges the battery and powers the bus by "pulling" electrons from the bus and dumping them into the crankcase to which it is bolted and into the firewall, to which it should be grounded by a separate cable. If the cable connections are bad, or if the crankcase-to-engine mount strap connections are bad, or if the engine mount's interface with the firewall is bad, those electrons look for other ways to get to the airframe. They'll travel along control cables, wire shielding, and yes, through the oil temp sender and through the gauge, having a boosting effect and making the gauge read higher. You might get alternator noise in your headset, too. Cessna had a similar problem and now they recommend a separate, small ground wire from the case near the sender to the gauge frame itself. That keeps the potential as close to ground as possible and improves accuracy. But if engine grounding is poor, hard starting will show up and some of those little ground wires and engine control cables will get hot. I'd start by cleaning all the ground connections. Then see if the temp is still too high. Sometimes oil coolers get sludged up and internally coated with varnish and crud, insulating the hot oil from the cooling airflow. Dan |
On Sep 5, 6:58*pm, wrote:
On Sep 5, 3:00 pm, "Mike Spera" wrote: I am in a quest to troubleshoot an oil temp that has crept up a bit in the last 100 hours or so. Checked all the baffling and"usual stuff". I was going to check the accuracy of the gauge via testing. 2 things that I cannot find: the part number of the oil temp sending unit and a supplier. This part does not appear either in the engine parts list or the airplane parts list. Engine is a 150hp E-3D. Any info would be appreciated. Thanks, Mike Spiking oil temp can sometimes be blamed on poor engine and/or alternator grounding. That little sender is a thermistor whose resistance drops as it gets warm, allowing the electrical system to draw more current out of the engine case, through the gauge and into the bus. Now, the alternator is generating electricity. It charges the battery and powers the bus by "pulling" electrons from the bus and dumping them into the crankcase to which it is bolted and into the firewall, to which it should be grounded by a separate cable. If the cable connections are bad, or if the crankcase-to-engine mount strap connections are bad, or if the engine mount's interface with the firewall is bad, those electrons look for other ways to get to the airframe. They'll travel along control cables, wire shielding, and yes, through the oil temp sender and through the gauge, having a boosting effect and making the gauge read higher. You might get alternator noise in your headset, too. Cessna had a similar problem and now they recommend a separate, small ground wire from the case near the sender to the gauge frame itself. That keeps the potential as close to ground as possible and improves accuracy. But if engine grounding is poor, hard starting will show up and some of those little ground wires and engine control cables will get hot. I'd start by cleaning all the ground connections. Then see if the temp is still too high. Sometimes oil coolers get sludged up and internally coated with varnish and crud, insulating the hot oil from the cooling airflow. Dan Should have pointed out one more possibility: The Vernatherm, which controls the oil cooler bypass. As the oil warms up the vernatherm pushes a valve into a port so that the oil has to go through the cooler instead of bypassing it. If the Vernatherm is shot, the oil will get hot. If your engine has an oil screen, the vernatherm is the big nut on the back of the screen housing right next to the temp pickup. If it has a spin-on filter, it's in the bottom of the filter adapter, opposite the temp sender which is on top. Dan |
Mike Spera wrote:
/snip/ 2 things that I cannot find: the part number of the oil temp sending unit and a supplier. This part does not appear either in the engine parts list or the airplane parts list. Engine is a 150hp E-3D. Any info would be appreciated. Thanks, Mike Mike, My Feb. 1995 Cherokee parts catalog shows the sending unit on Figure 68, "Electrical System Installation", item #63: "Gauge-Engine Unit, Oil Temperature" Depending on your Serial # ( 20550, or 20550 ), it shows Piper part # 462-046, or 550-487 (mfg's part #'s 1514976, or 362-EW). Bear in mind all of those #'s have probably been superceded by now, but perhaps a Piper dealer or Lycoming distributor can take you from there. Happy Flying! Scott Skylane |
Scott, That's the gauge you are looking at, not the sending unit. I don't need the gauge. Thanks, Mike Mike, My Feb. 1995 Cherokee parts catalog shows the sending unit on Figure 68, "Electrical System Installation", item #63: "Gauge-Engine Unit, Oil Temperature" Depending on your Serial # ( 20550, or 20550 ), it shows Piper part # 462-046, or 550-487 (mfg's part #'s 1514976, or 362-EW). Bear in mind all of those #'s have probably been superceded by now, but perhaps a Piper dealer or Lycoming distributor can take you from there. Happy Flying! Scott Skylane |
Dan,
When I said I checked the "usual stuff", I meant that I already did all the things you suggested. Oil cooler and Vernatherm replaced with new units, all connections checked, alternator running properly, gauge and sending unit properly grounded, baffles sealing, etc. I am looking for the part number of the sending unit and a source. If it is cheap enough I may get one and swap it. Getting an immersion heater in a vessel with the sending unit and a thermometer is a lot of stuff to juggle, especiall once the heater starts heating up the water.. Done it before. For a 10 buck sender, I would just replace it. However, if the thing is $50 then I'll bite the bullet and do the test. Thanks for the clues, Mike wrote in message ... On Sep 5, 6:58 pm, wrote: On Sep 5, 3:00 pm, "Mike Spera" wrote: I am in a quest to troubleshoot an oil temp that has crept up a bit in the last 100 hours or so. Checked all the baffling and"usual stuff". I was going to check the accuracy of the gauge via testing. 2 things that I cannot find: the part number of the oil temp sending unit and a supplier. This part does not appear either in the engine parts list or the airplane parts list. Engine is a 150hp E-3D. Any info would be appreciated. Thanks, Mike Spiking oil temp can sometimes be blamed on poor engine and/or alternator grounding. That little sender is a thermistor whose resistance drops as it gets warm, allowing the electrical system to draw more current out of the engine case, through the gauge and into the bus. Now, the alternator is generating electricity. It charges the battery and powers the bus by "pulling" electrons from the bus and dumping them into the crankcase to which it is bolted and into the firewall, to which it should be grounded by a separate cable. If the cable connections are bad, or if the crankcase-to-engine mount strap connections are bad, or if the engine mount's interface with the firewall is bad, those electrons look for other ways to get to the airframe. They'll travel along control cables, wire shielding, and yes, through the oil temp sender and through the gauge, having a boosting effect and making the gauge read higher. You might get alternator noise in your headset, too. Cessna had a similar problem and now they recommend a separate, small ground wire from the case near the sender to the gauge frame itself. That keeps the potential as close to ground as possible and improves accuracy. But if engine grounding is poor, hard starting will show up and some of those little ground wires and engine control cables will get hot. I'd start by cleaning all the ground connections. Then see if the temp is still too high. Sometimes oil coolers get sludged up and internally coated with varnish and crud, insulating the hot oil from the cooling airflow. Dan Should have pointed out one more possibility: The Vernatherm, which controls the oil cooler bypass. As the oil warms up the vernatherm pushes a valve into a port so that the oil has to go through the cooler instead of bypassing it. If the Vernatherm is shot, the oil will get hot. If your engine has an oil screen, the vernatherm is the big nut on the back of the screen housing right next to the temp pickup. If it has a spin-on filter, it's in the bottom of the filter adapter, opposite the temp sender which is on top. Dan |
Mike Spera wrote:
Scott, That's the gauge you are looking at, not the sending unit. I don't need the gauge. Thanks, Mike Mike, My Feb. 1995 Cherokee parts catalog shows the sending unit on Figure 68, "Electrical System Installation", item #63: "Gauge-Engine Unit, Oil Temperature" Depending on your Serial # ( 20550, or 20550 ), it shows Piper part # 462-046, or 550-487 (mfg's part #'s 1514976, or 362-EW). Bear in mind all of those #'s have probably been superceded by now, but perhaps a Piper dealer or Lycoming distributor can take you from there. Happy Flying! Scott Skylane Mike, I believe the part #'s I gave you are the correct ones. If you have access to the drawing, you will see it clearly indicates the sending unit, which screws in to the accessory case. Notice they call it "Gauge, *Engine Unit*, Oil Temp". The actual gauge, that you see in the cockpit, is listed in Figure 16 & 17, "Instrument Panel Installation", under items # 28 & 35, respectively: "Instrument - Oil Temperature", again, depending on serial no. Happy Flying! Scott Skylane |
Mike Spera wrote:
Dan, When I said I checked the "usual stuff", I meant that I already did all the things you suggested. Oil cooler and Vernatherm replaced with new units, all connections checked, alternator running properly, gauge and sending unit properly grounded, baffles sealing, etc. I am looking for the part number of the sending unit and a source. If it is cheap enough I may get one and swap it. Getting an immersion heater in a vessel with the sending unit and a thermometer is a lot of stuff to juggle, especiall once the heater starts heating up the water.. Done it before. For a 10 buck sender, I would just replace it. However, if the thing is $50 then I'll bite the bullet and do the test. Thanks for the clues, Mike wrote in message ... On Sep 5, 6:58 pm, wrote: On Sep 5, 3:00 pm, "Mike Spera" wrote: I am in a quest to troubleshoot an oil temp that has crept up a bit in the last 100 hours or so. Checked all the baffling and"usual stuff". I was going to check the accuracy of the gauge via testing. 2 things that I cannot find: the part number of the oil temp sending unit and a supplier. This part does not appear either in the engine parts list or the airplane parts list. Engine is a 150hp E-3D. Any info would be appreciated. Thanks, Mike Spiking oil temp can sometimes be blamed on poor engine and/or alternator grounding. That little sender is a thermistor whose resistance drops as it gets warm, allowing the electrical system to draw more current out of the engine case, through the gauge and into the bus. Now, the alternator is generating electricity. It charges the battery and powers the bus by "pulling" electrons from the bus and dumping them into the crankcase to which it is bolted and into the firewall, to which it should be grounded by a separate cable. If the cable connections are bad, or if the crankcase-to-engine mount strap connections are bad, or if the engine mount's interface with the firewall is bad, those electrons look for other ways to get to the airframe. They'll travel along control cables, wire shielding, and yes, through the oil temp sender and through the gauge, having a boosting effect and making the gauge read higher. You might get alternator noise in your headset, too. Cessna had a similar problem and now they recommend a separate, small ground wire from the case near the sender to the gauge frame itself. That keeps the potential as close to ground as possible and improves accuracy. But if engine grounding is poor, hard starting will show up and some of those little ground wires and engine control cables will get hot. I'd start by cleaning all the ground connections. Then see if the temp is still too high. Sometimes oil coolers get sludged up and internally coated with varnish and crud, insulating the hot oil from the cooling airflow. Dan Should have pointed out one more possibility: The Vernatherm, which controls the oil cooler bypass. As the oil warms up the vernatherm pushes a valve into a port so that the oil has to go through the cooler instead of bypassing it. If the Vernatherm is shot, the oil will get hot. If your engine has an oil screen, the vernatherm is the big nut on the back of the screen housing right next to the temp pickup. If it has a spin-on filter, it's in the bottom of the filter adapter, opposite the temp sender which is on top. Dan It's not that hard to calibrate the system. I put the sending unit and a calibrated temperature probe on a DMM in a cup of oil and heated it to 180F and marked the gauge on the panel so I would know exactly where that magic number occurred. It did take three folks, two to work the heated oil and one in the plane to mark the gauge with a small piece of tape. -- Regards, Ross C-172F 180HP Sold ![]() KSWI |
"Scott Braddock" wrote in message Mike, I believe the part #'s I gave you are the correct ones. Happy Flying! Scott Skylane This Piper Forum post agrees with those numbers: http://forums.piperowner.org/read/4/5724/5725/quote=1 |
On Sep 5, 2:00*pm, "Mike Spera" wrote:
I am in a quest to troubleshoot an oil temp that has crept up a bit in the last 100 hours or so. Checked all the baffling and"usual stuff". I was going to check the accuracy of the gauge via testing. 2 things that I cannot find: the part number of the oil temp sending unit and a supplier. This part does not appear either in the engine parts list or the airplane parts list. Engine is a 150hp E-3D. Any info would be appreciated. Thanks, Mike Not to be too obvious but have you looked at the oil cooler? They require periodic "rod outs", about every 10 years. There are places you can send it to that will clear out all the channels and return it yellow taged. Just did mine about 8 years ago and will probably plan to do it again in the next couple years on my IO-360. -Robert |
| Thread Tools | |
| Display Modes | |
| Cherokee 140 Oil Temp Creeping Up | Mike Spera | Owning | 9 | June 12th 09 10:02 PM |
| Cherokee fuel sending units | Mike Spera | Owning | 6 | June 27th 06 12:07 AM |
| Fuel Sending Unit? | Bill Adams | Home Built | 0 | April 12th 05 03:46 PM |
| Cherokee fuel tank sender unit "float" -- anybody know where to get these??? | Chuck | Owning | 5 | January 27th 05 04:18 PM |
| Oil Temperature sending unit | Corky Scott | Home Built | 2 | October 19th 04 01:58 AM |
