Master contactor question
Old November 2nd 09, 06:58 PM posted to rec.aviation.homebuilt
Nathan-Annie Dridiger
Default Master contactor question
On Nov 1, 5:47 pm, wrote:
If the starter solenoid is at the battery the only time the high
current conductor is live is when cranking - and virtually all the
rest of the loads can be handled by a "main switch".
Except that you still have a substantial live cable coming into the
cockpit, a hazard that can't be disconnected in flight if something
goes wrong. And that substantial cable and its substantial switch
could also end up costing and weighing more than a $25 contactor and
$3 master switch.
The charging circuit is the only part of the wiring that can get
tricky - and there are ways around that too.
Yeah, but you have no control over it if it's wired directly to
the battery as in an automobile. Regulators are known to fail and get
the alternator working overtime (I've had it happen in a boat) and
burn things out. An alternator switch (actually, a regulator controls
switch) and alt output breaker make things much safer.
There are ways to save cost and weight, but the electrical system is
not a good place to do it.
Dan
  #32
Old November 3rd 09, 12:08 AM posted to rec.aviation.homebuilt
Peter Dohm
"Nathan-Annie Dridiger" wrote in message
$3 master switch.
A lot of that can be true or false with nearly equal ease.
First, assuming that we are only talking about light single engine aircraft
with the battery mounted in the fusalage, rather than in one of the wings,
then a little depends on whether the battery is at the same end of the
fuselage as the engine. Personally, I would be inclined to protect the
starting circuit with a cartridge fuse as need the battery as practical.
The next question is what loads need to be protected in what manner, and the
only one that really needs a hefty contactor is the starting motor. After
that is the main output of the alternator/generator which sould be greater
than the combination of all loads other than the starter.
Personally, I would be inclined to protect the starting circuit with a
cartridge fuse, sized to protect the CABLE and placed as near the battery as
practical. I would also do the same thing for the cable from the battery to
the master switch/breaker/contactor and would further protect the main
output cable from the alternator/generator with an in-line or cartridge fuse
as near the alternator/generator as practical. Those three fuses should be
sufficient to protect the main cabling from the power sources to the
distribution points, where the breakers could provide the specific circuit
protection.
Protection, and switching, of the field circuit is a great idea--if the type
of regulator in use makes it practical. Otherwise, it might be necessary to
switch the output with a switch or contactor.
Dan
Very good point, and this thread started with a discussion of a master
contactor that would supposedly draw nearly an amp for its own coil
current--which seemed like an outrageously large power and heat dissipation!
So, it the starter uses the Bendix type inertial engagement mechanism, I
would be inclined to use a remote contactor near the battery and splurge for
a more efficient main contactor sized for the non-starting loads.
Peter
  #33
Old November 3rd 09, 06:08 AM posted to rec.aviation.homebuilt
On Mon, 2 Nov 2009 10:58:26 -0800 (PST), Nathan-Annie Dridiger
$3 master switch.
Dan
Define "substantial" and a fuse or breaker WILL disconnect it if
something goes wrong.
  #34
Old November 3rd 09, 06:46 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
If the solenoid is hooked directly to the battery, then it will
be energized by applying a ground to the control terminal.
That's just the coil current - an amp?
I must be missing something about the high current cable coming
into the cockpit.
  #35
Old November 3rd 09, 12:24 PM posted to rec.aviation.homebuilt
Brian Whatcott
Jim Logajan wrote:
Ron Wanttaja wrote:
http://www.bowersflybaby.com/tech/hhrad2.JPG
Even at zero knots the FUN meter appears to be on high - that's quite an
aeroplane!
Ron has been commemorating his Flybaby in (internet) print
for twenty years to my positive knowledge. What a marriage made in Heaven!
Brian W
  #36
Old November 3rd 09, 01:50 PM posted to rec.aviation.homebuilt
Stealth Pilot[_3_]
On Tue, 03 Nov 2009 06:24:33 -0600, brian whatcott
aeroplane!
Brian W
who could forget N500F's annual maintenance :-)
priceless.
Stealth Pilot
  #37
Old November 3rd 09, 02:55 PM posted to rec.aviation.homebuilt
And if that fuse or breaker is in the cockpit, you still have
a live feed to it even if it trips. If it's next to the battery
somewhere else, you can't shut it off, reset it or replace it in
flight.
Dan
  #38
Old November 3rd 09, 02:59 PM posted to rec.aviation.homebuilt
into the cockpit.
If you had no contactor and had instead a big switch on the panel,
you have a large wire coming into the cockpit. That large wire goes
directly to the battery and if a short develops anywhere along it,
you're in big trouble.
The coil current is an amp or so. We could use a relay that could
handle the large current flows with a coil that uses much less
current, but then the spring that releases the contacts would be
really light and any fusion at all at the contacts would keep it
closed, defeating its whole purpose.
One end of the contactor coil is typically connected at the
contactor's battery terminal, and the other goes to the master switch
that grounds it when we want the contactor closed. This limits the max
current on this one "always-hot" wire
to one amp. A short will close the contactor, not cause a fire.
Dan
  #39
Old November 3rd 09, 04:01 PM posted to rec.aviation.homebuilt
et
* If you had no contactor and had instead a big switch on the panel,
I have a 30Amp fuse mounted on the battery box, #8 wire to the
mechanical master switch on the dash, extra jacket on wire, smaller
fuses for accessories.
Starter solenoid mounted on battery box, cable with firesleeve jacket,
pushbutton starter switch.
I'd rather blow a fuse than heat the wire, either way, no power.
What do you think?
Ed
Master cylinders [email protected] Home Built 25 July 29th 08 02:08 AM
Battery Contactor Diode? Skrud Home Built 25 September 11th 06 06:17 PM
PA28-180 Power Contactor Relay source? Mike Noel Owning 5 August 10th 05 04:40 AM
Master Switch Lakeview Bill Piloting 23 July 20th 05 01:46 AM
RC Plane Master Steve Simulators 0 December 20th 03 02:40 PM
