Cessna 150 Door Latch.
Old November 8th 09, 04:29 PM posted to rec.aviation.owning
Brian Whatcott
Default Cessna 150 Door Latch.
The exterior door latch paddle is spring loaded to
close - it opens in the "suicide" i.e. blow open direction.
The two coil springs holding the paddle closed were
made of regular steel, so they corrode and finally break.
Stainless springs are better.
It is a regular performance to remove the interior panel etc.,
to get at the latch assembly.
A NEW replacement latch assembly from a Cessna source
costs $1200 (yes you did read that right)
so you need to handle it like gold and rubies.
A hinge pin holds the paddle in place.
The pin is secured by a split pin.
The pin may freeze on the assembly casting.
If you drive it out, the paddle may be cracked.
Fortunately, Chief etc., offers a chrome die cast
approved replacement for under $20.
Placing the two springs in position needs plenty
of patience.
Finally, perhaps with a little smoothing of the lock
hooks on the paddle, the door shuts and locks and
the latch doesn't blow out into the breeze.
Brian Whatcott
Old November 9th 09, 03:55 AM posted to rec.aviation.owning
of patience.
No, it doesn't. It requires LOTS of patience. Grrr. I hate that setup
and wonder who had the job of assembling them in the factory? How much
did they pay him to keep at it?
Dan
Old November 12th 09, 12:48 AM posted to rec.aviation.owning
Dan D[_2_]
"brian whatcott" wrote in message ...
The 150 doesn't go fast enough for that to happen...
Old November 12th 09, 04:22 PM posted to rec.aviation.owning
Glenn[_3_]
LOL
"Dan D" wrote in message
Old November 13th 09, 12:37 PM posted to rec.aviation.owning
Brian Whatcott
Ain't THAT a fact!
B
Door stop/latch for C172A... Dan D[_2_] Owning 1 August 6th 09 05:10 PM
Cessna window latch karl gruber Owning 1 September 27th 05 06:14 PM
Need Cessna Door Dale General Aviation 0 December 15th 04 01:20 AM
'50s Cessna Door Handles Jim Weir Owning 8 July 16th 03 11:01 PM
Need door handle for 1959 Cessna 175 Paul Millner Owning 0 July 4th 03 07:36 PM
