LS8 Panel in AutoCAD?
Old January 30th 10, 06:08 PM posted to rec.aviation.soaring
jcarlyle
Default LS8 Panel in AutoCAD?
I've got an LS8, whose panel outline looks similar to these three on
the top of this site:
http://www.solairecanada.com/index2.htm
Would anyone have an AutoCAD file for this panel outline shape that
they'd be willing to share? I've tried DG and the LS group, with no
luck. I'm trying to see if I could fit a ClearNav in before I buy a
new blank.
Thanks,
John
Old January 30th 10, 06:23 PM posted to rec.aviation.soaring
jcarlyle
Darn. To see the panels, after you click on the link go to the left
side and click on Cockpits.
-John
Old January 30th 10, 08:45 PM posted to rec.aviation.soaring
brianDG303[_2_]
-John
Here is a suggestion- go to:
http://www.dg-flugzeugbau.de/instrument-panel-e.html
and select the LS8 panel file, that may be enough for your use. If
not, convert it to an image file (with free software MWSnap) and
import that into AutoCad. Then draw on a layer over the image file. I
did the same thing for a DG300 and clearnav was just never going to
fit.
Brian
Old January 30th 10, 09:20 PM posted to rec.aviation.soaring
jcarlyle
Good suggestion, Brian, but there are two problems. First, you can't
get the panel size very accurately off DG's drawing in order to scale
it properly in AutoCAD. Second, there's no ClearNav thingy offered by
DG, and the scale problem arises getting one into their drawing.
Still, it may be good enough for a first approximation - I'll play
around with it.
If anyone has a dimensioned LS8 panel outline in AutoCAD, though, I'd
be grateful for a copy. R14 dwg format would work best.
-John
fit.
Old January 30th 10, 10:22 PM posted to rec.aviation.soaring
brianDG303[_2_]
around with it.
-John
fit.
John,
Many of the instruments are dimensioned, so you could just scale up or
down until they measured correctly, and then you could draw a clearnav
or paste in an image file and scale that until it matched as well.
But of course if you can get the DWG file from someone all the
better.
good luck,
Brian
Old January 31st 10, 12:02 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
I've done that with another CAD package (TrueCAD for Windows, a medium
priced 2-D CAD package). My method should work with any 2-D CAD system of
at least equal capability to TrueCAD, so ACAD should do it easily. Here
are the steps:
- pick a pair of measurement points, which must show up really clearly
and be as sharp as possible. The further apart they are the better
the final accuracy will be.
- measure between the points as accurately as possible
- make a photo of the panel.
- pull the image of the panel into your CAD system
- start a new layer and draw round the significant lines etc on the photo
using a cubic spline and enough points to give smooth curves. Avoid
using polygons because these need lots of points to approximate smooth.
Draw 3 point circles where possible.
- delete the photo layer
- adjust the scale of the drawing until the CAD measurement tool givess
the correct measurement. TrueCAD lets you select the points and
specify the distance you want, which sets the correct drawing scale,
and then adjust the zoom factor to fill the window, so ACAD will
probably do the same.
I use this trick when designing free flight models. I can generate a
scaleless wing section with a section plotting program, pull it into
TrueCAD and adjust it to match the required wing chord. Getting the chord
right within 0.05mm was trivial, so the main limitation on your accuracy
will be that of picking suitable points on the panel and of getting an
accurate measurement. I think I'd use a metric ruler to place masking
tape patches with their edges parallel and an exact number of mm apart
before making the photo. I'd also mark the exact measurement places with
pencil lines at right angles to the edges.
Its my experience that some ways of using CAD are not all that obvious,
so I hope I'm not telling you stuff you already know.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 31st 10, 02:13 AM posted to rec.aviation.soaring
jcarlyle
Trouble is, PowerPoint doesn't hold the scale properly. If you
investigate you'll find that if you scale a 57 mm line off of the 80
mm instruments, that line won't match the 57 mm instrument circle. And
vice versa for the 57 mm to 80 mm instruments. So getting the correct
dimensions for the panel from the PowerPoint drawing is really a non-
starter.
-John
Old January 31st 10, 02:28 AM posted to rec.aviation.soaring
jcarlyle
Thanks for the detailed approach, Martin. I use AutoCAD once every
couple of years, and it's not an easy program to use in such an
intermittent mode (especially when you're self taught).
The problem right now is your 4th step 'make a photo of the panel'.
The glider is not accessible, and I don't have a new blank panel
available. Thus I'm stuck for a few months, if I can't locate a R14
dwg of the panel outline.
-John
On Jan 30, 7:02 pm, Martin Gregorie
are the steps:
Old January 31st 10, 08:07 PM posted to rec.aviation.soaring
I know the problem well (and not just with CAD packages).
The problem right now is your 4th step 'make a photo of the panel'. The
glider is not accessible, and I don't have a new blank panel available.
Thus I'm stuck for a few months, if I can't locate a R14 dwg of the
panel outline.
I didn't realise that - sorry.
Maybe somebody with an LS8 that's not put away for the northern winter
could be prevailed on to apply masking tape, measure, photograph and peel
off the tape? It seems to me its the sort of job that takes almost more
time to describe than do.
org |
Old February 1st 10, 04:17 PM posted to rec.aviation.soaring
Morgan[_2_]
Another tool to consider looking at is Google Sketchup.
http://sketchup.google.com/
I have found it very easy and powerful to use, especially for a task
like this that requires the creation of some new shapes like a box to
represent your clearNav. It takes a little practice and following of
tutorials (online videos make it nice) to understand how to create
precise models, but you can do really detailed and accurate 3D
renderings.
This doesn't solve your issue of getting an LS-8 panel starting point,
but you may find it easier than Autocad if you aren't using Autocad on
a regular basis.
On Jan 31, 12:07*pm, Martin Gregorie
panel outline.
Maybe somebody with an LS8 that's not put away for the northern winter *
martin@ * | Martin Gregorie
org * * * |
20B Panel jcarlyle Soaring 21 April 1st 09 10:57 PM
ASW-19 instrument panel - AutoCad?? Gary Emerson Soaring 1 February 9th 09 07:02 PM
AutoCad [email protected] Soaring 5 January 9th 09 05:56 PM
IFR PANEL Flyhighdave Home Built 4 January 18th 05 04:24 AM
IFR PANEL Flyhighdave Home Built 4 January 17th 05 07:15 PM
