#11
On Feb 1, 8:32*am, GARY BOGGS wrote:
When are we going to quit loosing sailplanes to poor tie downs? http://bit.ly/cgioFc Last year my super cub's left wing and struts were destroyed in a wind storm, the double tiedowns held the airplane in place for the wind to twist the wing. Would have been nice if it had been in the hangar but then a lot of very nice gliders were lost in the Barstow hangar fire a while ago. Jim |
On Feb 2, 7:59*am, Jim wrote:
On Feb 1, 8:32*am, GARY BOGGS wrote: When are we going to quit loosing sailplanes to poor tie downs? http://bit.ly/cgioFc Last year my super cub's left wing and struts were destroyed in a wind storm, the double tiedowns held the airplane in place for the wind to twist the wing. Would have been nice if it had been in the hangar but then a lot of very nice gliders were lost in the Barstow hangar fire a while ago. Jim There's a lot to be learned from the experience at Boulder, CO where high-wind events often exceed 100 MPH for many hours. The technique is 6 deeply buried concrete tie down anchors per glider - nose, tail and two on each wing - one inboard and one outboard. On flex-winged composite gliders, wing stands are used. The gliders are oriented 90 degrees to the high-wind direction. Ropes are at least 1/2" (13mm) high-strength climbing ropes or nylon straps. The knots are multiple half hitches drawn up tight against the glider. These knots are so simple anyone can tie them with one demonstration - and they'll come loose when you want them to. As long as there is no slack, they won't work loose on their own. |
On Feb 2, 9:33*am, bildan wrote:
On Feb 2, 7:59*am, Jim wrote: On Feb 1, 8:32*am, GARY BOGGS wrote: When are we going to quit loosing sailplanes to poor tie downs? http://bit.ly/cgioFc Last year my super cub's left wing and struts were destroyed in a wind storm, the double tiedowns held the airplane in place for the wind to twist the wing. Would have been nice if it had been in the hangar but then a lot of very nice gliders were lost in the Barstow hangar fire a while ago. Jim There's a lot to be learned from the experience at Boulder, CO where high-wind events often exceed 100 MPH for many hours. The technique is 6 deeply buried concrete tie down anchors per glider - nose, tail and two on each wing - one inboard and one outboard. *On flex-winged composite gliders, wing stands are used. *The gliders are oriented 90 degrees to the high-wind direction. Ropes are at least 1/2" (13mm) high-strength climbing ropes or nylon straps. *The knots are multiple half hitches drawn up tight against the glider. *These knots are so simple anyone can tie them with one demonstration - and they'll come loose when you want them to. *As long as there is no slack, they won't work loose on their own. I believe the slats inserted into the cyclone fencing surrounding the Boulder parking bays has also paid an important part. |
On Feb 2, 9:40*am, Frank Whiteley wrote:
On Feb 2, 9:33*am, bildan wrote: On Feb 2, 7:59*am, Jim wrote: On Feb 1, 8:32*am, GARY BOGGS wrote: When are we going to quit loosing sailplanes to poor tie downs? http://bit.ly/cgioFc Last year my super cub's left wing and struts were destroyed in a wind storm, the double tiedowns held the airplane in place for the wind to twist the wing. Would have been nice if it had been in the hangar but then a lot of very nice gliders were lost in the Barstow hangar fire a while ago. Jim There's a lot to be learned from the experience at Boulder, CO where high-wind events often exceed 100 MPH for many hours. The technique is 6 deeply buried concrete tie down anchors per glider - nose, tail and two on each wing - one inboard and one outboard. *On flex-winged composite gliders, wing stands are used. *The gliders are oriented 90 degrees to the high-wind direction. Ropes are at least 1/2" (13mm) high-strength climbing ropes or nylon straps. *The knots are multiple half hitches drawn up tight against the glider. *These knots are so simple anyone can tie them with one demonstration - and they'll come loose when you want them to. *As long as there is no slack, they won't work loose on their own. I believe the slats inserted into the cyclone fencing surrounding the Boulder parking bays has also paid an important part. Yeah, the cyclone fencing helps a lot. They strain out flying debris and slow the wind a bit. I've been out there when wind borne golf ball sized rocks were hitting me at knee level. |
- nose, tail and two on each wing - one inboard and one outboard. On flex-winged composite gliders, wing stands are used. The gliders are oriented 90 degrees to the high-wind direction. I'll never understand how somebody would tie down a plastic glider outside rather than put it in the trailer. Rigging a modern glider is a matter of 10 minutes but possibly worth a couple of thousand dollars. |
Bugger. Was hoping you'd cough them up!
Another interesting short flight was a friend towing his 1-26 to the hangar with the technique a lot of Schweizer pilots use: A short rope attached to the tow release that has a T-handle on the end. Nothing much you can do once the glider tries to leave the ground but let go and run upwind. In this case it did no damage to anything else. The Tonopah launch out of the tiedowns was lucky, only putting a blue stripe on Charlie Westerinen's winglet. A close shave, as Martin Feeg would write in Soaring Australia. Jim On Feb 2, 8:56*am, GARY BOGGS wrote: I never saw any of the pictures taken of me in the wrecked 1-26. *If you have any could you email them to me? |
On Feb 2, 11:34*am, John Smith wrote:
The technique is 6 deeply buried concrete tie down anchors per glider - nose, tail and two on each wing - one inboard and one outboard. *On flex-winged composite gliders, wing stands are used. *The gliders are oriented 90 degrees to the high-wind direction. I'll never understand how somebody would tie down a plastic glider outside rather than put it in the trailer. Rigging a modern glider is a matter of 10 minutes but possibly worth a couple of thousand dollars. I have to agree that putting it in the trailer would be the most prudent thing to do. I'd like to be the kind of guy that would actually do it, but I'm not. After a 5 - 8 hour flight, all I want is a beer, something to eat, an access point to upload my flight, and bed. The 1/2 hour required to pull the trailer to the glider, de-rig and box it, then park the trailer and disconnect it from the truck seems like a monumental task at the end of the day, especially when it will be flown the next day, and the next..... |
On Feb 2, 12:34*pm, John Smith wrote:
The technique is 6 deeply buried concrete tie down anchors per glider - nose, tail and two on each wing - one inboard and one outboard. *On flex-winged composite gliders, wing stands are used. *The gliders are oriented 90 degrees to the high-wind direction. I'll never understand how somebody would tie down a plastic glider outside rather than put it in the trailer. Rigging a modern glider is a matter of 10 minutes but possibly worth a couple of thousand dollars. Interesting question. If the glider is flown every day, as many at Boulder are, the wear and tear of daily rig/derig cycles would add up plus there's the possibility that someone would eventually drop a wing or worse. That said, rigging with the best aids is not all that much harder than working with full covers and 6 ropes. I'm inclined to think putting the most expensive glass birds back in their trailer each day is the better choice. Of course, hangars are the optimum answer. At Boulder, hangars aren't an option. |
prudent thing to do. I'd like to be the kind of guy that would actually do it, but I'm not. *After a 5 - 8 hour flight, all I want is a beer, something to eat, an access point to upload my flight, and bed. The 1/2 hour required to pull the trailer to the glider, de-rig and box it, then park the trailer and disconnect it from the truck seems like a monumental task at the end of the day, especially when it will be flown the next day, and the next..... force your hand. do the safe thing. land out more often. |
The FAA has just lost it | HilldaBeast | Piloting | 1 | November 15th 07 02:49 AM |
Lost stories here | Danny Deger | Piloting | 68 | January 12th 07 12:43 AM |
Lost stories here | Larry Dighera | Instrument Flight Rules | 3 | January 12th 07 12:43 AM |
We lost in Nam. But not Rasimus | Lisakbernacchia | Military Aviation | 12 | June 12th 04 06:30 AM |
fw-200 not "lost" | old hoodoo | Military Aviation | 0 | December 22nd 03 07:16 PM |
