Reverse NACA duct
Old October 24th 03, 07:28 PM
Chris W
Default Reverse NACA duct
Can someone tell me where I can find more information on the design of a
reverse NACA duct?
Chris W
"They that can give up essential liberty
to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin, 1759 Historical Review of Pennsylvania
Old October 24th 03, 08:24 PM
Corky Scott
reverse NACA duct?
Chris W
Chris, what's a reverse NACA duct? My understanding is that they were
designed to work in one direction only, to bring in air with a minimum
of drag.
They don't work well, or at all, when placed on the fuselage or cowl
in a negative pressure area.
Thanks, Corky Scott
Old October 25th 03, 01:08 AM
Chris W
of drag.
I had heard once that on some planes, a reverse or backwards NACA duct would
be installed in the aft part of the cockpit to improve ventilation by helping
suck air out of the plane. I also think I remember something about the
design being somewhat different.
Chris W
Old October 25th 03, 02:22 AM
Morgans
"Chris W" wrote in message
of drag.
would
helping
Chris W
As I recall, it was shaped rather like a raindrop, but with about 1/3rd of
the surface raised above the craft. The pointy end was pointed into the
wind, with the outlet in the downwind, rounded side. The object was to
create a low pressure area, then use it to get the bad air out. If only I
could remember where I read about it!
Jim in NC
Old October 25th 03, 02:58 AM
Robert Little
Would a couple of NACA ducts work on the bootcowl of a Taylorcraft BC-12D to
bring in fresh cabin air? I understand a 337 would be required but would it
do the job better than have to fly with the windows slide back? Just
thinking of better ways of freezing my feet off this winter. RTL
This mailbox protected from junk email by Matador
from MailFrontier, Inc. http://info.mailfrontier.com
reverse NACA duct?
Chris W
Old October 25th 03, 03:04 AM
RobertR237
In article , Chris W writes:
reverse NACA duct?
Chris W
I don't know of a specific design for one but I am simply mounting one on the
outside of the fuselage with the small end pointing into the airstream. The
air will flow around and over the duct and should result in a negative pressure
at the opening. Another option was one done by the guy who designed the
VISION. It was a small extending bulb with holes on the back side. Again, the
negative pressure on the down wind side results in a reverse flow.
Bob Reed
www.kisbuild.r-a-reed-assoc.com (KIS Builders Site)
KIS Cruiser in progress...Slow but steady progress....
"Ladies and Gentlemen, take my advice,
pull down your pants and Slide on the Ice!"
(M.A.S.H. Sidney Freedman)
Old October 25th 03, 03:14 AM
RobertR237
In article , "Morgans"
writes:
would
helping
Chris W
Jim in NC
I believe the guy who designed the Vision Aircraft did some work on this
several years ago and had some information on his web site at one time. I
don't know if it is still there or no.
Bob Reed
Old October 25th 03, 03:19 AM
Larry Smith
"Robert Little" wrote in message
to
it
Oh, blasphemy and sacrilege! You would do that to the boot cowl of your
classic Taylorcraft?
Somebody's going to get this sooner or later and googling "inverted naca
duct" might bring something up. But my understanding is that the device
helps keep the boundary layer attached.
reverse NACA duct?
Chris W
Old October 25th 03, 11:52 AM
R&R Sherwood
Reverse NACA duct ... Bad Idea!
Several years ago I read about someone installing a NACA scoop, pointed end
aft, to remove air from the cabin. I thought I would do the same for my
plane but first decided to test the idea. I built a NACA scoop and ran
high speed water through it in both forward and reverse directions. In
forward the water flowed as expected. In reverse the water exited at
nearly 90 degrees to the slip stream.
I believe a NACA scoop will just add drag, especially to fast
planes....Better to just use a ramped exit.
Russell Sherwood
Houston, TX
reverse NACA duct?
Chris W
