This time of year is good for repairing things that you just haven't
got around to. Amongst my other winter projects is refurbishing an older Udo rigger. The Bilstein screw jack was not working smoothly, and produced clicks while raising or lowering. When it clicked, the jack was not raising or lowering. Sounds terminal, but it isn't necessarily. If you have a similar problem with a screw jack, remove it (on the Udo rigger, 3 bolts) and clean the threads. I found that there were pieces of gravel stuck in the grease in the threads of the screw jack. These forced the spring-loaded teeth of the carriage which rides on the screw to come out of the threads and click back in. Cleaning the threads out with a screwdriver eliminated the gravel. A little WD40 along the screw and the whole thing runs smoothly. Using heavy grease which will pick up dirt is a recipe for more trouble. Takes half an hour on a rainy day. (unlikely to happen on a sunny day) Jim |
On Sat, 27 Feb 2010 13:53:10 -0800, JS wrote:
A little WD40 along the screw and the whole thing runs smoothly. Be careful where you use that stuff. It doesn't cause problems with that machinery of that size and weight, but can be a nuisance on small precision items. The problem is that it dries out and becomes sticky enough to cause problems. The only real cure is disassembly and cleaning. If WD40 gets into instruments or a baro it could cause real problems. I know this from model flying: the timers we use on free flight power models get covered in oil and then pick up grit if you're flying in dusty places. This stops them working, so a common flying field trick is to give the timer a good squirt with WD40 to blow the grit out before the next flight. That solves the problem - until the next competition day, by which time the WD40 has dried out and prevents the timer from running. The solution on the field? More WD40, but it does build up through the season until it gets cleaned out as part of the winter overhaul. This isn't a a major problem provided you know about it. Now you do: so consider yourselves warned. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Feb 27, 2:53*pm, JS wrote:
* This time of year is good for repairing things that you just haven't got around to. Amongst my other winter projects is refurbishing an older Udo rigger. * The Bilstein screw jack was not working smoothly, and produced clicks while raising or lowering. When it clicked, the jack was not raising or lowering. Sounds terminal, but it isn't necessarily. * If you have a similar problem with a screw jack, remove it (on the Udo rigger, 3 bolts) and clean the threads. I found that there were pieces of gravel stuck in the grease in the threads of the screw jack. These forced the spring-loaded teeth of the carriage which rides on the screw to come out of the threads and click back in. Cleaning the threads out with a screwdriver eliminated the gravel. A little WD40 along the screw and the whole thing runs smoothly. Using heavy grease which will pick up dirt is a recipe for more trouble. * Takes half an hour on a rainy day. (unlikely to happen on a sunny day) Jim Jim, I would use a thin lube like LPS-2 rather than WD40, it will be better in the long run and maintaining lubrication. |
Thanks Martin and Tim, I forgot the final stage... I used bicycle
chain lube! Tri-Flow works on the bike pretty well without picking up half the desert. LPS make great products, I think there are three cans of their stuff in the garage. The WD40 cleans out all the old shrapnel pretty well. Jim |
On Feb 27, 4:59*pm, Tim Taylor wrote:
I would use a thin lube like LPS-2 rather than WD40, it will be better in the long run and maintaining lubrication. LPS-2 is a thin lube out of the can but over time it dries to a waxy consistency. It can make some things almost seize up in cold weather. I have leaned the hard way not to use in on control cables. A flush with kerosene or Jet A seems to fix things for a while. Andy |
On Feb 27, 8:05*pm, Andy wrote:
On Feb 27, 4:59*pm, Tim Taylor wrote: I would use a thin lube like LPS-2 rather than WD40, it will be better in the long run and maintaining lubrication. LPS-2 is a thin lube out of the can but over time it dries to a *waxy consistency. *It can make some things almost seize up in cold weather. *I have leaned the hard way not to use in on control cables. A flush with kerosene or Jet A seems to fix things for a while. Andy I vote for all the above except WD-40 which, after some bad experiences, I restrict to its original purpose - Water Displacement. To the list I would add an old standard - auto parts store white molybdenum grease. It seems to last forever on door hinges so it should be great on jacks. |
"JS" wrote in message ... Thanks Martin and Tim, I forgot the final stage... I used bicycle chain lube! Tri-Flow works on the bike pretty well without picking up half the desert. LPS make great products, I think there are three cans of their stuff in the garage. The WD40 cleans out all the old shrapnel pretty well. Jim So what would everyone recommend on cables? the post about LS2 getting stiff. In the LS-4 (9B) I always have the rudder pedals close for control on takeoff and braking if needed Last summer at JABOG (Tonopah) after 3 hours at 17,000ft, on descent for landing I was unable to move (pull the rudder pedal adjust cable) to pull the rudder pedals back into a position for effective heel braking. I had to fly around down lower for about 15 minutes to warm things up before I could adjust the pedals. BT |
Errrrr.........
When I went to A&P school (oh so many years ago) they told us that aircraft cables should NOT be lubercated. Lube only the pulleys with WD-40. As for not being able move your rudder pedals back, you need to clean the sliding tubes and then lube with WD-40.................lubing the cable has nothing to do with fixing the problem.. JJ BT wrote: "JS" wrote in message ... Thanks Martin and Tim, I forgot the final stage... I used bicycle chain lube! Tri-Flow works on the bike pretty well without picking up half the desert. LPS make great products, I think there are three cans of their stuff in the garage. The WD40 cleans out all the old shrapnel pretty well. Jim So what would everyone recommend on cables? the post about LS2 getting stiff. In the LS-4 (9B) I always have the rudder pedals close for control on takeoff and braking if needed Last summer at JABOG (Tonopah) after 3 hours at 17,000ft, on descent for landing I was unable to move (pull the rudder pedal adjust cable) to pull the rudder pedals back into a position for effective heel braking. I had to fly around down lower for about 15 minutes to warm things up before I could adjust the pedals. BT |
thanx JJ
"JJ Sinclair" wrote in message ... Errrrr......... When I went to A&P school (oh so many years ago) they told us that aircraft cables should NOT be lubercated. Lube only the pulleys with WD-40. As for not being able move your rudder pedals back, you need to clean the sliding tubes and then lube with WD-40.................lubing the cable has nothing to do with fixing the problem.. JJ BT wrote: "JS" wrote in message ... Thanks Martin and Tim, I forgot the final stage... I used bicycle chain lube! Tri-Flow works on the bike pretty well without picking up half the desert. LPS make great products, I think there are three cans of their stuff in the garage. The WD40 cleans out all the old shrapnel pretty well. Jim So what would everyone recommend on cables? the post about LS2 getting stiff. In the LS-4 (9B) I always have the rudder pedals close for control on takeoff and braking if needed Last summer at JABOG (Tonopah) after 3 hours at 17,000ft, on descent for landing I was unable to move (pull the rudder pedal adjust cable) to pull the rudder pedals back into a position for effective heel braking. I had to fly around down lower for about 15 minutes to warm things up before I could adjust the pedals. BT |
Water soluble marine grease works great on the pins for the spars when
rigging. It cleans up with a wet rag and saves a trip to the clubhouse to get the grease off of your hands. MS |
| FS: Cobra one man rigger- | Devin Bargainnier | Soaring | 0 | February 24th 10 06:09 AM |
| Wanted: One-man wing rigger | Bastoune | Soaring | 4 | February 21st 10 05:48 PM |
| Winter project, tow out gear - wing wheel | bildan | Soaring | 39 | November 14th 08 01:27 AM |
| Used Cobra Wing Rigger For Sale | Jeremy Zawodny | Soaring | 2 | May 8th 06 06:26 PM |
| Winter project | [email protected] | Soaring | 10 | January 2nd 05 02:11 PM |
