I did my first oil change, had an oil analysis done and got back the
results. Two figures were flagged: 20ppm for AL and 99ppm for Iron with the following comments: Wear Metals Appear Slightly High for Oil Time, and Possible Corrosion if Aircraft Not Flown Regularly. It concluded with the recommendation to sample next oil change to check wear trend. Is it time to panic or just note the figures with interest? - Mike |
"Michael Horowitz" wrote in message
... I did my first oil change, had an oil analysis done and got back the results. Two figures were flagged: 20ppm for AL and 99ppm for Iron with the following comments: Wear Metals Appear Slightly High for Oil Time, and Possible Corrosion if Aircraft Not Flown Regularly. It concluded with the recommendation to sample next oil change to check wear trend. Is it time to panic or just note the figures with interest? - Mike Mike.......... I'm not the resident expert on oil analysis, but - I like to think - an informed user. I had a 34' Trawler with a Ford-Lehman diesel on which I kept an oil analysis chart. Numbers for oil analysis, unless way off the chart are best looked at as trends. Much like battery electrolyte specific gravity readings, each battery and each engine are slightly different. One reading doesn't tell a hell of a lot by itself. "Slightly" and "Possible" notations mean that you should keep an eye on the numbers. Were it mine, I wouldn't panic. Mebbe you're just not using enough of "Henderson Jones' Magic Engine Elixir" to "Prevent all Wear and Corrosion Forever". ;-) Rich Shankland |
"Rich S." wrote:
"Slightly" and "Possible" notations mean that you should keep an eye on the numbers. Were it mine, I wouldn't panic. Mebbe you're just not using enough of "Henderson Jones' Magic Engine Elixir" to "Prevent all Wear and Corrosion Forever". ;-) Rich Shankland OK - Point me to Diagon Alley, The'll have it G - Mike |
On Sat, 25 Oct 2003 17:27:06 -0400, Michael Horowitz
wrote: "Rich S." wrote: "Slightly" and "Possible" notations mean that you should keep an eye on the numbers. Were it mine, I wouldn't panic. Mebbe you're just not using enough of "Henderson Jones' Magic Engine Elixir" to "Prevent all Wear and Corrosion Forever". ;-) Rich Shankland OK - Point me to Diagon Alley, The'll have it G - Mike Just remember to pronounce it clearly when you use the flue powder :-) -- dillon The pen may be mightier than the sword, but a .sig never beat a SIG |
Mike
You didn't give much data for anyone to make valid comments on. 1. Type and age of engine.(Including hours) 2. Type flying it has been doing (acrobatics, XC , training in pattern, etc.) 3. Cylinder compression. 4. Type oil and how often it has been changed. 5. How often flown and whether hangered or tied down and part of country you are in. .Any other things you can think of. Oil analysis is basically a trend monitoring system. After establishing a trend and you then come to a knee, you know to do something about it before you have a major failure I read the report recommendation "to sample next oil change to check wear trend" as that they didn't find any incipient failure and to check next oil change for any change in the analysis trend. Anyone else want to add to these comments? The Air Force started oil analysis many years ago and used to pull an engine when the analysis showed excessive wear inside. Big John On Sat, 25 Oct 2003 15:45:54 -0400, Michael Horowitz wrote: I did my first oil change, had an oil analysis done and got back the results. Two figures were flagged: 20ppm for AL and 99ppm for Iron with the following comments: Wear Metals Appear Slightly High for Oil Time, and Possible Corrosion if Aircraft Not Flown Regularly. It concluded with the recommendation to sample next oil change to check wear trend. Is it time to panic or just note the figures with interest? - Mike |
engine when the analysis showed excessive wear inside. Naval Aviation does the same. Watch the trend. Larry AECS (AW/SW/MTS) Disabled Combat Veteran USN Retired 20 years of Navy in my rear view mirror and getting further away every day ;-) "Big John" wrote in message ... Mike You didn't give much data for anyone to make valid comments on. 1. Type and age of engine.(Including hours) 2. Type flying it has been doing (acrobatics, XC , training in pattern, etc.) 3. Cylinder compression. 4. Type oil and how often it has been changed. 5. How often flown and whether hangered or tied down and part of country you are in. .Any other things you can think of. Oil analysis is basically a trend monitoring system. After establishing a trend and you then come to a knee, you know to do something about it before you have a major failure I read the report recommendation "to sample next oil change to check wear trend" as that they didn't find any incipient failure and to check next oil change for any change in the analysis trend. Anyone else want to add to these comments? The Air Force started oil analysis many years ago and used to pull an engine when the analysis showed excessive wear inside. Big John On Sat, 25 Oct 2003 15:45:54 -0400, Michael Horowitz wrote: I did my first oil change, had an oil analysis done and got back the results. Two figures were flagged: 20ppm for AL and 99ppm for Iron with the following comments: Wear Metals Appear Slightly High for Oil Time, and Possible Corrosion if Aircraft Not Flown Regularly. It concluded with the recommendation to sample next oil change to check wear trend. Is it time to panic or just note the figures with interest? - Mike |
Michael Horowitz wrote in message . ..
I did my first oil change, had an oil analysis done and got back the results. Two figures were flagged: 20ppm for AL and 99ppm for Iron with the following comments: Wear Metals Appear Slightly High for Oil Time, and Possible Corrosion if Aircraft Not Flown Regularly. It concluded with the recommendation to sample next oil change to check wear trend. Is it time to panic or just note the figures with interest? - Mike Don't panic. Were the analysts aware that this was a first oil change? Wear is normally slightly higher during and just after 'break in` and that might account for the numbers. Best of luck - Pragmatist - Is there anything else I can be of no help with? |
Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 04:46 AM |
Ford V-6 engine work | Corky Scott | Home Built | 19 | August 21st 03 12:04 PM |
1710 allison v-12 engine WWII p 38 engine | Holger Stephan | Home Built | 9 | August 21st 03 08:53 AM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 08:06 AM |
