Glider accident near Altoona... interview with pilot
Old May 14th 10, 08:30 PM posted to rec.aviation.soaring
[email protected][_2_]
Default Glider accident near Altoona... interview with pilot
PLB brings speedy rescue to pilot trapped in trees
By Mike Collins, AOPA
A Pennsylvania pilot is crediting his personal locator beacon (PLB)
with his rescue only two hours after his glider crashed in rugged
mountains near Altoona, Pa., May 9.
http://www.aopa.org/aircraft/article...raccident.html
Old May 15th 10, 12:28 AM posted to rec.aviation.soaring
ContestID67[_2_]
What seems really strange is the the rescurers didn't have a simple,
inexpensive, GPS so that they could zero in on the pilot quickly. The
narrative indicates that the pilot had to guide them in via sound.
Even cell phones now have GPS. This should be required equipment.
Old May 15th 10, 04:51 AM posted to rec.aviation.soaring
Darryl Ramm
inexpensive, GPS so that they could zero in on the pilot quickly. *The
Even cell phones now have GPS. *This should be required equipment.
1. Did the PLB have a GPS?
2. Did the PLB have a GPS fix?
Foliage or other could mean a PLB with GPS is unable to get a fix.
That or if the PLB does not have a GPS then then SARSAT relies on
(significantly less precise) doppler location. It is also at least
plausible that an alert process can be started before a triangulation
fix established.
If the ground SAR crew had 121.1 direction finder that may also have
helped triangulate on the PLB 121.5 Mhz beacon (all 406 Mhz ELTs and
PLBs also have 121.5 Mhz homing beacons), but with heavy foliage/steep
terrain that may have been more work/slower than the airhorns.
Darryl
Old May 15th 10, 06:43 AM posted to rec.aviation.soaring
“Our sport, like many others, has become very technology heavy,” he
said. “With the personal devices, I made the decision that the couple
of hundred dollars that you spend could really pay off.” Dutka said he
“absolutely” felt that investment paid off Sunday.
Money well spent. Hopefully he'll spend some on recurrent training
too in order to avoid getting into the same unfortunate fix again.
Old May 15th 10, 10:11 AM posted to rec.aviation.soaring
nimbus
Poor weather conditions, close to the mountains ridges, no outlanding
fileds and still having water ballasts full of water?
Strange........
Old May 15th 10, 11:43 AM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
Foliage or other *could mean a PLB with GPS is unable to get a fix.
fix established.
Darryl
Les’s comments in the AOPA web article are consistent with the
experiences with both the Peter Masak and Dale Kramer searches.
Although very high quality information (e.g. coordinates, elt signal,
knowledge of route being flown) may be available, there is a gap in
the ability of local non-aviation rescue (and even CAP) to accept and/
or use it effectively. Had Les not been able to respond to the sounds
made by the rescue team over his cellphone, it would have probably
taken much longer to find him as there is no indication that his
coordinates were either communicated to the rescue team or that they
had the capability to use them. However, I do not know whether SARSAT
actually got GPS coordinates from his PLB or they just estimated
coordinates from the PLB signal (a 406 Mhz elt signal without GPS
determines a search area of about 2 miles radius).
This reinforces the advantages of having something with you that makes
noise (elt, whistle, bike horn etc.) that is either automatically
activated or on the front of your chute.
Old May 15th 10, 03:01 PM posted to rec.aviation.soaring
Dave Nadler
Strange........
Excellent weather conditions.
Look at OLC flights for this day in the region.
At least one landing field in reach.
Old May 16th 10, 06:21 PM posted to rec.aviation.soaring
jim archer
"Poor weather conditions, close to the mountains ridges, no
outlanding
fileds and still having water ballasts full of water? " was not in
the article anywhere
Strange? Not when you consider the pilots actual comments...
"winds were pretty strong" "skies were overcast" "He said he was
ridge soaring when his glider stalled and spun into the side of a
mountain" were some of the pilots and authors comments, so I'm not
sure what people are getting at here. Sounds like he is genuinely
grateful and amazed to be alive after an admitted stall/spin.
Old May 16th 10, 07:42 PM posted to rec.aviation.soaring
nimbus
outlanding
fileds and still having water ballasts full of water? " *was not in
Strange? *Not when you consider the pilots actual comments...
"winds were pretty strong" "skies were overcast" * "He said he was
mountain" *were some of the pilots and authors comments, so I'm not
sure what people are getting at here. *Sounds like he is genuinely
Extract out of the provided link :
"He was flying lower and lower, without finding lift, and had not
dropped his water ballast—which increases stall speed. "
Old May 17th 10, 04:15 PM posted to rec.aviation.soaring
brianDG303[_2_]
outlanding
The question I have about this is the effectiveness of the different
alert devices while upside down. Would the SPOT get a message out,
would the PLB? Where I fly there would be no cellphone coverage and no
way to get a fire truck with an airhorn, so it would be SPOT or PLB
and a very long wait.
Brian
Glider accident in France claims two zurchman Soaring 1 July 9th 09 01:53 AM
Reno Newspaper Defends Reporting on Glider Accident SoarPoint Soaring 15 September 1st 06 07:49 AM
Glider accident near San Antonio Duster Soaring 0 June 26th 06 08:43 PM
TV Interview With Pilot From ADIZ Incident Jay Beckman Piloting 64 May 27th 05 11:38 AM
Interview of Finnish Curtiss Hawk 75 pilot Jarl Arnkil Jukka O. Kauppinen Military Aviation 0 January 31st 04 05:42 PM
