#11
On 6/1/2010 9:45 PM, sisu1a wrote:
LT tires are a good match for trailers (better than P type - passenger car tires - for the same size and speed rating) Why are they better? stiffer sidewalls = less sway... -p Given similar sizes, the tires on a passenger car that will be subject to high cornering loads will flex more side to side than the tires on a truck or trailer that need not handle high cornering loads? That seems counter intuitive to me. |
car tires - for the same size and speed rating) Why are they better? stiffer sidewalls = less sway... -p Given similar sizes, the tires on a passenger car that will be subject to high cornering loads will flex more side to side than the tires on a truck or trailer that need not handle high cornering loads? *That seems counter intuitive to me. Trucks and trailers are generally designed to handle higher loads loads than passenger vehicles, hence stiffer tires which apparently aren't as comfy a ride. LT- light truck tires- will most often are on similar sized but heavier vehicles driving the same roads at similar speeds as lighter loaded cars, corner loads and all. -Paul |
A couple of years ago, I struggled with trying to understand trailer
tires and ratings. I still do not understand them, but took Ray's advice and have been very happy with these tires on my Cobra trailer with a heavy 2 place sailplane. =============== The tires on my Cobra trailer from the factory are marked 185R14C8PF (102/100N)LT They appear to be GT Radial Max Miler X Load Range D 1875 lb at 450KPA 65# cold Try tirerack.com - they have Kumho trailer tires that match what you have. I've used their semi trailer tires and found them to be acceptable, but I don't have any experience with the smaller ones. They list them for $ 80.00 each plus shipping. Ray Warshaw ============== |
![]() "sisu1a" wrote Trucks and trailers are generally designed to handle higher loads loads than passenger vehicles, hence stiffer tires which apparently aren't as comfy a ride. LT- light truck tires- will most often are on similar sized but heavier vehicles driving the same roads at similar speeds as lighter loaded cars, corner loads and all. -Paul Add to that that light truck tires generally (always?) have a much higher maximum pressure rating, so if you pump them up to max allowed pressure, they will get really stiff. A couple weeks back, my 3/4 ton full sized van needed tires. I generally carry about a thousand pounds of tools ALL the time. I was not paying close attention to the tires I selected to put on, so they went with the tire I told them, which was a P rated tire. The guy that put them on came out and got me after they were mounted so I could see how they looked. In short, they looked like they were about 15 pounds low on pressure, but they were at max rated pressure. I told the guy that these will never do. I don't have all the load on that they will often see, and they are almost flat. I appreciated him giving me the chance to change my mind. He went with a LT tire that I then chose, and all was well. Instead of being rated at 36 pounds, they were rated at 55 pounds. They are indeed much stiffer, and most of that is in the flexibility of the sidewall. I a\have no doubt that it would be a better trailer tire than a P rated tire. I'll tell you all what to try. Go to a tire store and pick out a certain sized tire in a P rating. Push down on the unmounted tire, hard enough so that it really deflects a lot. Now get a LT tire of the same size and press it down the same amount. You will be surprised. -- Jim in NC |
On 6/1/2010 8:56 PM, Greg Arnold wrote:
On 6/1/2010 8:46 PM, Eric Greenwell wrote: On 6/1/2010 9:29 AM, Andy wrote: On May 31, 8:47 pm, Eric wrote: The Yokohama tire you list is a LT (light truck) tire. Does Yokohama have a trailer rating for it in addition to the LT rating? Don't know. Maybe the dealer lied to me. I asked for trailer rated tires and he told me they were. They were not a stock item he needed to move, they were ordered from the Yokohama warehouse. Normally I do a lot of research on something like this but I was distracted by other things and just needed to get it done.. Anyway they seem to work just fine so far. LT tires are a good match for trailers (better than P type - passenger car tires - for the same size and speed rating) Why are they better? Here's what I wrote for the ASH 26 E owners "tech site": Commonly available tire types are P (passenger car), LT (light truck) and ST (special trailer). While each tire series shares basic construction methods, the details vary meaningfully among the three. There are other differences: 1. P tires use a load rating system that is different from ST and LT tires; generally, you have to discount their rating 10% to get the equivalent ST or LT rating. 2. ST tires speed rating is 65 mph. The speed rating increases to 75 mph IF you increase the tire pressure to 10 psi above the pressure required for your load at 65 mph. These are not the tires for folks that like to drive 80 mph across the Nevada highways in 100 deg F temperatures. 3. ST tires come in both bias-belted and radial construction. The only advantage to a bias-belted trailer tire is it's cheaper. 4. LT tires are a bit "stiffer" than either P or ST tires, and are available in speed ratings to at least 118 mph. Suggestions: 1. P tires might work fine, but I don't know what speed and load ratings would ensure this. If I decided to use P tires, I'd use them at the pressure that gave a load rating of ~40% more load rating than the load they has to carry. I'd choose a speed rating at least 20 mph higher than the speed rating on my tow vehicles tires. 2. If you like the way the trailer tows, staying with the same make and model of tire means no surprises. The same type and size tire from an equally trusted manufacturer is probably good, too. 3. If you like to tow faster than 70, don't use ST tires; instead, get an LT tire rated at least 20 mph more than your intended tow speed. This web page has more information on trailer tire safety, written by Tom Wilson for Trailer Life magazine in 2002: https://www.subaru.com/my-subaru/tire-safety.html http://www.google.com/url?q=https%3A%2F%2Fwww.subaru.com%2Fmy-subaru%2Ftire-safety.html&sa=D&sntz=1&usg=AFrqEzfNgJTx0_JddUB7NR 7ejOvGSR2NYw -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On 6/7/2010 10:28 PM, Eric Greenwell wrote:
This web page has more information on trailer tire safety, written by Tom Wilson for Trailer Life magazine in 2002: https://www.subaru.com/my-subaru/tire-safety.html http://www.google.com/url?q=https%3A%2F%2Fwww.subaru.com%2Fmy-subaru%2Ftire-safety.html&sa=D&sntz=1&usg=AFrqEzfNgJTx0_JddUB7NR 7ejOvGSR2NYw Besides the damage Google Sites does to the link, the page isn't there anymore, anyway! This link goes to an article by the same author that is nearly the same as the one that was on the Subaru site: http://www.carlisletire.com/product_...ety_031505.pdf -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
Cobra Trailer Spare Tire mount failure | Barny | Soaring | 29 | July 23rd 15 12:52 AM |
Tire Size for 8 Year Old Komet Trailer | Papa3 | Soaring | 4 | October 24th 08 12:22 AM |
Tire Size for 8 Year Old Komet Trailer | Uncle Fuzzy | Soaring | 0 | October 23rd 08 10:39 PM |
Trailer tire rims | Gary Carter | Soaring | 7 | January 21st 05 03:15 PM |
Tire Stiffness & trailer swaying | chris | Soaring | 42 | October 22nd 03 03:51 AM |
