Hercules Engines
Old January 23rd 04, 07:43 PM
Tarver Engineering
"Gord Beaman" wrote in message
Jim Yanik wrote:
You certainly couldn't parallel two different voltage sources IF
they were 'hard' because huge currents would flow. So on a T-56
engine they do indeed parallel many thermocouples. (I forget how
many now, but there's a bunch) Half are used for the FCU and half
for the Temperature Datum System.
Did you know that the major failure mode for a theromocouple is a short?
Yes John...
Consider, Gord, that making your little friends look less foolish is only
making you look foolish.
Yes John...
Even if you were to make an "average", you would need a "total" first.
Yes John...
Yes John.. (oops)
OK then.
  #195
Old January 24th 04, 03:01 PM
Scet
Jim Yanik wrote:
(B2431) wrote in
Jim Yanik wrote:
"Well,then it violates basic physics.If you have two voltage sources
of
slightly different voltages,currents DO flow between them.That's a
basic principle. And bimetal TCs are simply millivolt voltage
sources."
Yes Jim, what you say is true but it's 'allowed' in this (and
other) cases because the voltage output, although in the
millivolt range, is 'soft'. so the current is extremely low, they
merely 'average' themselves.
-Gord.
18 thermocouples, 3 in each can, each thermocouple has 4 wires connected to
it, 2 white, 2 green. 2 wires send signals to the TD amp, the other 2 to the
TIT gauge in the flight station via a terminal block.
Scet
  #196
Old January 24th 04, 10:02 PM
Scet
Oops...sorry...half to the TD amp, half to the TIT gauge (not the
FCU) my bad.
-Gord.
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 11:14 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Hercules Engines Tarver Engineering Home Built 0 January 20th 04 12:05 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 06:36 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
