#61
This is about it as I remember it . It amounted to keeping it down to a low
roar, using the corridors and restricted areas when at all possible; not ****ing off the surrounding areas; the FAA; and not ****ing off Admiral Brown! :-) I'm not sure how the AF guys fared under AF 60.16. Probably about the same I would imagine. The whole idea was to allow for the performance of the airplanes while not abusing the regulation. It seemed to work well as long as everybody had their head screwed on straight. I'm pretty sure it's still this way, but there have been incidents. The Viper hitting that Cessna in Florida might have changed things a bit. Dudley "John R Weiss" wrote in message news:iHBQb.115054$nt4.462505@attbi_s51... "Ed Rasimus" wrote... Things have undoubtedly changed since my last military flight, but the applicable section of AFR 60-16 which was the governing regulation on flight operations was that the max airspeed below 10,000 feet MSL was 250 KIAS unless the aircraft operating manual required higher. "We don' need no steenkin' waivers." The Navy version is OPNAVINST 3710.7. The latest version I have is .7S, dated 15 Nov 2001: "1.2.3 Federal Aviation Regulations (FAR). "Naval aircraft shall be operated in accordance with applicable provisions of FAR, Part 91, except: . . . "b. Where exemptions or authorizations issued to the Department of the Navy/Department of Defense permit deviation from FAR. Exemptions/authorizations currently on file that allow deviation from FAR, Part 91. "(1) Section 91.117 (Aircraft Speed). Operation of naval aircraft at speeds in excess of limits imposed by section 91.117 shall be governed by paragraph 5.1.4 of this instruction." The pertinent section of 5.1.4 is: "5.1.4.2 Policy. In accordance with FAA authorization, flight operations below 10,000 feet MSL at an indicated airspeed in excess of 250 knots are authorized under the following conditions: "a. Within restricted areas. "b. Within military operations areas. "c. When operating on DOD/FAA mutually developed and published routes. "d. When operating on DOD-developed and DOD-published VR routes. Such routes shall be established for specific missions and used only by designated units when the provisions of a through c above will not accommodate the required national defense mission. Routes shall be developed and published in accordance with DOD/FAA mutually developed criteria. "e. When operating within large-scale exercises or on short-term special missions approved by commanders listed in paragraph 5.1.4.3. Such exercises or missions may be authorized provided that coordination is effected to ensure awareness on the part of the nonparticipating flying public. "f. If the airspeed required or recommended in the aircraft NATOPS manual to maintain safe maneuverability is greater than the maximum speed described in FAR, Part 91.117, the aircraft may be operated at that speed. Where the required or recommended speed is given as a range, the lower part of the speed range consistent with good operating practice should be used. The primary purpose of this provision is to accommodate climbs, descents, and terminal area operations and shall not be used to circumvent the provisions of sub-paragraphs above. Under no circumstance will this safe maneuverability provision be construed as authorization for individual pilots or mission commanders to conduct other flights below 10,000 feet in excess of 250 knots." |
#62
"S. Sampson" wrote in message news:VkCQb.6584$ce2.3669@okepread03... "Steven P. McNicoll" wrote It would be waiving a rule that didn't have to be followed anyway. I see. You're trying to bring logic into a tort arena. Good for you... As long as Steve remains inside FAA Orders, he has no liability. |
#63
Yes, it is a rule here too as we follow the 7110.65 just like in the
U.S. But it is a rule we don't always strickly enforce unless we have to. I don't like them going that fast, but unless there is a reason for me to slow them down, I don't usually bother. Now I would never have one buz an airliner or civilian plane going that fast, but you get the idea. I'm sure it is different with the FAA boys working in a busy area, but for us over open water we don't care too much. Our airspace goes out to 50 miles around Okinawa, so it is 90% over water. Glenn On Sat, 24 Jan 2004 21:18:22 GMT, "John R Weiss" wrote: "Glenn Westfall" wrote... I'm an Air Force Air Traffic Controller and am currently working in Okinawa, Japan. We have F-15's here at Kadena and it is not uncommon for them to come back well above 400 Kts below 10,000. How far out over the water does the 250-below-10 limit extend in Japan? |
#64
"Steven P. McNicoll" wrote...
MTRs are established for the sole purpose of military training at airspeeds greater than 250 KIAS. According to a couple FAA and USAF sources, that is true for IR and VR routes, but not SR routes... From the Montgomery County AFSS web site at http://www.cxoafss.jccbi.gov/Military.htm, as well as the Buffalo AFSS site at http://www1.faa.gov/ats/bufafss/flig.../military.htm: SR (slow speed low altitude routes) - conducted VFR below 1,500 feet at 250 knots or less, without prior notice. From the Acronym list at http://www.afranges.net/Chapters/appendixes.pdf and Edwards AFB at http://www.edwards.af.mil/pim/PUBS/t...-1/atch7a.doc: SR Slow Speed Low Altitude Training Routes From the Dover AFB Mid-Air Collision Avoidance handbook at http://public.dover.amc.af.mil/org/w...Printable.pdf: Only VR routes are depicted on sectional charts. SR and IR Routes are not shown! |
#65
ATC cannot authorize or require deviation from the 250 KIAS speed limitation below 10,000 MSL, except within airspace delegated to Houston approach control, and then only for departing aircraft. ....and the Houston experiment is about to end: ALPA OPERATIONS BULLETIN 2004-01 SUBJECT: Houston (IAH) High Speed Departure Test Program BACKGROUND: In December 1997 the FAA began a field test at Houston Intercontinental Airport (IAH) to determine whether the 250-knot speed restriction for aircraft operating below 10,000 MSL within Class B airspace could be increased or eliminated. Shortly after this test began, ALPA identified to FAA and industry representatives numerous safety concerns including Class B Airspace excursions, increased mid-air collision risk, and increased potential for catastrophic bird strikes. Our concerns were highlighted by the damage sustained by a Delta 727 on departure from IAH on January 9, 1998. After lengthy discussions and some valid scientific analysis, FAA Flight Standards, in July 2003, determined that it couldn't quantify the risk presented by birds. Based on the data from the test, the FAA is unable to design a risk analysis that will prove the safety of the operation. The well-documented increase in the wildlife populations of large flocking birds was a determining factor in this finding. The FAA has decided to discontinue the test. Once internal FAA coordination is complete, ATC will no longer be authorized to allow aircraft to exceed 250 KIAS below 10,000 feet MSL. However, this internal coordination must not delay pilots from immediately discontinuing participation. RECOMMENDATION: Therefore, effective immediately, pilots should not accept an ATC clearance for, or request ATC authorization to, exceed 250 knots below 10,000 feet in Houston Class B Airspace. Contact the ALPA Engineering and Air Safety Department at 800-424-2470 with questions and comments. Captain John Cox Executive Air Safety Chairman January 16, 2004 |
#66
"Darkwing Duck" wrote...
So how fast is short final in a F-14 or whatever? Always wanted to know. 125 to 140 knots, depending on airplane and landing weight. |
#67
John Gaquin wrote, "... Loaded 747 would climb at about 273. ..."
Makes it all the more amazing that they seem to be standing still while climbing out! |
#68
Bingo, the first fully explained and correct answer. Thanks Darrell.
I'm surprised the Hustler flew so slow low level. I just always assumed since it was such a hotass machine that it flew faster. We planned/flew the Bone at 560 KTAS/.8Mach. For the original poster, the B-1B, for example, flies downwind in the pattern at 270 KIAS. That's the top of the range (IIRC) given in the "Dash One" and is what we always flew while I was flying from '86-'97. Cheers, JB "Darrell" wrote in message news:5vBQb.65145$XD5.52941@fed1read06... If the "Dash One" manual for the military airplane specifies a speed higher than 250 below 10,000' it's OK to fly that fast. In the B-58 Hustler, after takeoff we came out of afterburners at 350 KIAS and climbed at 425 KIAS until reaching Mach .90 for climb speed. That's why other aircraft try to stay clear of military climb corridors. We flew low level routes at 435 KIAS except for the high speed portion where we flew at 600 KIAS. (and that's back in the 1960s) -- B-58 Hustler History: http://members.cox.net/dschmidt1/ - "Tetsuji Rai" wrote in message s.com... Airspeed limitation below 10000ft is usually 250kts unless you have been authorized by the Administrator. However I guess it's a bit slow for military fighters. So I am curious how fast military fighters fly in the real world. I guess it's very dangerous military aircraft fly much fast among civilian planes. |
#69
"Darkwing Duck" wrote in message ... "Tetsuji Rai" wrote in message s.com... Airspeed limitation below 10000ft is usually 250kts unless you have been authorized by the Administrator. However I guess it's a bit slow for military fighters. So I am curious how fast military fighters fly in the real world. I guess it's very dangerous military aircraft fly much fast among civilian planes. So how fast is short final in a F-14 or whatever? Always wanted to know. B-1B final is approx 155 +/- depending on weight. JB |
#70
| Thread Tools | |
| Display Modes | |
| FA: Flying Aviation Videos - Concorde - Just Planes - Military - B-52, F/A-18, Etc | Robert | Aviation Marketplace | 0 | August 29th 04 09:27 PM |
| Updated List of Military Information-Exchange Forums | Otis Willie | Military Aviation | 0 | December 29th 03 03:20 AM |
| List of News, Discussion and Info Exchange forums | Otis Willie | Military Aviation | 0 | November 14th 03 06:01 AM |
| 08 Nov 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | November 9th 03 02:51 AM |
| RUSSIAN WAR PLANES IN ASIA | James | Military Aviation | 2 | October 2nd 03 12:25 AM |
