#31
On Jun 22, 3:53*pm, "Tim Mara" wrote:
Typical government bureaucracy I don't believe the FCC has thought this through very thoroughly...in "banning" the use of 121.5 they have also rendered almost all 406 Mhz ELT's currently on the market as "illegal" should this pass...almost every new 406MhZ ELT is Dual band, or triple band and transmits on 121.5/243.0 and 406.0 MHz). Unless they change the wording this issue is already dead in the water. tim Please visit the Wings & Wheels website atwww.wingsandwheels.com wrote in message ... On Jun 22, 11:43 am, Darryl Ramm wrote: On Jun 22, 7:32 am, jb92563 wrote: On Jun 21, 4:01 pm, brian whatcott wrote: Since satellite cover has been withdrawn for 121.5 (High false alert rate, poor localization) 406.0 and 406.1 ELTs will be needed, following a recent FCC determination. Brian W Since the bereaucrats love so many rules, why not make another and let Gliders and ballons use PLB's like SPOT since in our sport we often have support crews that will monitor our progress in any case, making SPOT a very convenient tool for us and our crews. Ray. First a SPOT is *not* a PLB. A PLB is a specific device regulated by the FCC that transmits on 406 MHz to COAPAS-SARSAT (and also a 121.5 homing becon). It is essentially a lower power, smaller, manually activated 406 MHz ELT. SPOT is a private service run by Globalstar. The (multi-)government service is COSPAS-SARSAT and that provides pretty impressive emergency notification service for marine (EPIRB), Aviation (ELT) and private (PLB) use. It makes no sense for he government to promote SPOT over SARSAT-COSPAS. There is no federal requirement for a glider to carry an ELT. There is an apparently well intended but badly outdated SSA contest rule that allows a CD to require gliders to carry an ELT. The issue I have with that is a 406 MHz PLB is likely a much better SAR alerting device than an old 121.5 MHz ELT even if you could properly mount one in the glider. ELTs in light aircraft have an abysmal activation failure record, and I suspect that will be much worse in gliders with many of them improperly mounted and the lower impact energy of many glider crashes. SPOT tracking is great, a 10 minute position report gives you a simple area of uncertainty roughly about the same as an old SARSAT 121.5 MHz Doppler fix, but because you can usually use the glider path to predict the flight direction it's actually better than that. At least it's a good start for a search operation. If the pilot can activate "911" on their SPOT and it gets a view of the Globalstar satellites and a GPS fix then their final position is know as well. I prefer the redundancy of havign both SPOT and a PLB and the technical advantages of a PLB for that ultimate distress situation, but if I am in distress can I'll be activating 911 on my SPOT and activating my PLB. At a minimum the old SSA contest rule for ELTs could be modified to allow a CD if they choose to require SPOT and/or "406 MHZ PLB or ELT carriage". Darryl SSA competition rules provide the option for contest organizers to require these types of devices. Currently, if a glider is impact ELT equipped, it will satisfy this requirement. Organizers may also permit SPOT as an alternative to impact activated ELT's , but currently can't require SPOT instead of impact actiaved ELT's. The rules continue to evolve as capabilities change. The Contest Committee is on record as strongly suggesting use of some kind of safety device by all participants. I currently have a 121.5 impact activated ELT, 406 PL, and SPOT. Something should work. UH SSA Competition Rules Committee Chair __________ Information from ESET NOD32 Antivirus, version of virus signature database 5219 (20100622) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 5219 (20100622) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com We'll have to see the final 47 CFR part 87 wording is but the FCC is well aware of ELT technology. People are reading too much into casual language used by the FCC in a notice of rule changes. They are essentially doing the same thing to 121.5 Mhz ELTs as they did to 121.5MHz marine EPIRBS. As much as it is easy to beleive at times that the Feds are incomepetent, the FCC clearly understand that a 406 MHz ELTs, PLBs and EPIRBs also transmit on 121.5 Mhz. Darryl |
#32
Peter Hermann wrote:
Scott wrote: to UHF, it will solve that problem. Until then, you'll either have to interesting solution. remains the question whether UHF has better physical characteristics of range and quality. ...and what about affordability. Ouch! That's the hot button: $600 but mostly $1200 on up.... Brian W |
#33
jb92563 wrote:
On Jun 21, 4:01 pm, brian whatcott wrote: Since satellite cover has been withdrawn for 121.5 (High false alert rate, poor localization) 406.0 and 406.1 ELTs will be needed, following a recent FCC determination. Brian W Since the bereaucrats love so many rules, why not make another and let Gliders and ballons use PLB's like SPOT since in our sport we often have support crews that will monitor our progress in any case, making SPOT a very convenient tool for us and our crews. Ray. Apparently glider pilots are not obliged to carry ELTs. A cell phone, spot, EPIRB, ADS-B, FLARM are some other options I have heard about... Brian W |
#34
Scott wrote:
5Z wrote: On Jun 22, 12:48 am, Peter Hermann wrote: How to test proper functioning of 406 MHz with 118 - 136 MHz radios? The 406 ELT's still transmit on 121.5 as well. So the FCC wants to get rid of 121.5 ONLY units. -Tom Phew! I dodged a bullet! My ELT transmits on 121.5 and 243, so I'm good ![]() Yours and all the other old 121.5 ELTs, I fancy.... :-) Brian W |
#35
they are not, but many do
"brian whatcott" wrote in message ... jb92563 wrote: On Jun 21, 4:01 pm, brian whatcott wrote: Since satellite cover has been withdrawn for 121.5 (High false alert rate, poor localization) 406.0 and 406.1 ELTs will be needed, following a recent FCC determination. Brian W Since the bereaucrats love so many rules, why not make another and let Gliders and ballons use PLB's like SPOT since in our sport we often have support crews that will monitor our progress in any case, making SPOT a very convenient tool for us and our crews. Ray. Apparently glider pilots are not obliged to carry ELTs. A cell phone, spot, EPIRB, ADS-B, FLARM are some other options I have heard about... Brian W |
#36
The rationale seems to go like this: the 406 spec is for 4 watts min on the UHF (Oh, alright = 17dBm) pulsed for nearly 1/2 second per 50 secs or so for the following 48 to 50 hours... Brian W Huh? +17 dBm is only 50 milliwatts??? |
#37
Scott wrote:
brian whatcott wrote: The rationale seems to go like this: the 406 spec is for 4 watts min on the UHF (Oh, alright = 17dBm) pulsed for nearly 1/2 second per 50 secs or so for the following 48 to 50 hours... Brian W Huh? +17 dBm is only 50 milliwatts??? Nice catch - 17dBm is apparently the 121.5 required component. Try 35dBm for the 406 component. Brian W |
Use of 121.5 ELTs to be illegal in U.S. in about 60 days. | Jim Logajan | Piloting | 15 | July 3rd 10 09:23 PM |
Anybody installing tri-band (406MHz) ELTs? | Michelle P | Instrument Flight Rules | 0 | July 4th 05 09:10 PM |
Anybody installing tri-band (406MHz) ELTs? | Michelle P | General Aviation | 0 | July 4th 05 09:10 PM |
406 ELTs: link featuring many models | [email protected] | Soaring | 0 | February 20th 05 09:36 PM |
Airshows should be banned...Now! | Tetherhorne P. Flutterblast | Military Aviation | 28 | June 15th 04 02:43 AM |
