Can anyone give me a list of forgiving sailplanes out there. I know some like the Schweizers, Rudolf Kaiser's designs(Schleicher K-series) and the Discus... Any other to list?
On Jul 20, 8:35*am, EvValentin808
wrote: Can anyone give me a list of forgiving sailplanes out there. I know some like the Schweizers, *Rudolf Kaiser's designs(Schleicher K-series) and the Discus... Any other to list? -- EvValentin808 No doubt this thread will have a long run. My view is that all gliders are 'forgiving' - if flown by a qualified pilot. OTOH, unqualified pilots can wreck any glider no matter how 'forgiving'. In any event, 'forgiving' handling qualities has little to do with the safety of the pilot. Any glider, no matter how 'forgiving' can be flown into a very unforgiving Earth. They will still collide with mountains and other gliders. Trees and other obstacles can still wreck them. The number of accidents with poor handling qualities as the primary cause is virtually non-existent. What's REALLY unforgiving is nature. Make enough mistakes and 'ol Mother Nature will kill or maim you. She's merciless. Her goal is just cleaning the gene pool. So, forget handling qualities and worry about flying skills. They're FAR more important. |
One aspect that "may" be considered as a "forgiving" item is a nose
hook vs. a CG hook for aero-towing. Wing drops, cross-winds, lousy piloting techinque, etc can be magnified to nasty trips into the closest runway light when aero- towing with a CG hook whereas a tow rope connected to a nose hook "may" have the ability to pull you straight and away from expensive trouble. Of course, your mileage may vary... Ray Lovinggood LS1-d with CG hook, but no runway lights |
On Jul 20, 12:24*pm, bildan wrote:
So, forget handling qualities and worry about flying skills. *They're FAR more important. Nevertheless some manufacturers have in the past put performance ahead of handling and others have put handling ahead of performance. While a skilled pilot can overcome handling defficiencies they can kill an inattentive or inexperienced pilot. Any pilot considering purchasing a glider should consider at least - Do I fit in it comfortably Do I have adequate rear quadrant visibility to fly safely with other gliders Are the handling characteristics (particularly stall/spin) benign, or am I skilled enough to cope with them if they are not. To answer the OP question - based on 1,500 hours in the ASW-19b I can say it has very pleasant handling and has no flight characterisitcs that make it unsuitable for low time piilots. Its only vice is a reluctance to go straight at the start of tow with a strong cross wind, but that can be overcome by pilot skill. Andy (GY) |
On 7/20/2010 12:24 PM, bildan wrote:
On Jul 20, 8:35 am, EvValentin808 wrote: Can anyone give me a list of forgiving sailplanes out there. I know some like the Schweizers, Rudolf Kaiser's designs(Schleicher K-series) and the Discus... Any other to list? -- EvValentin808 No doubt this thread will have a long run. My view is that all gliders are 'forgiving' - if flown by a qualified pilot. OTOH, unqualified pilots can wreck any glider no matter how 'forgiving'. In any event, 'forgiving' handling qualities has little to do with the safety of the pilot. Any glider, no matter how 'forgiving' can be flown into a very unforgiving Earth. They will still collide with mountains and other gliders. Trees and other obstacles can still wreck them. The number of accidents with poor handling qualities as the primary cause is virtually non-existent. I don't agree at all. A qualified pilot can compensate for "unforgiving" qualities, but that doesn't make the glider "forgiving". Some gliders have very poor glide path control, some spin easily, with little warning, and don't recover quickly. Put the CG too far aft, and most gliders are likely not "forgiving". Even a qualified pilot can be distracted, or tired, or hypoxic, or dehydrated, and the outcome is likely to be much better in a "forgiving" glider than one that isn't. The "forgiveness" difference between an early Std Cirrus and any LS4 is an important one, as an example. Or between an ASK 21 and a Nimbus 4D. What's REALLY unforgiving is nature. Make enough mistakes and 'ol Mother Nature will kill or maim you. She's merciless. Her goal is just cleaning the gene pool. I don't think the "Mother Nature" is the main factor in most glider accidents. Look at how many happen near the airport and in good weather. So, forget handling qualities and worry about flying skills. They're FAR more important. There is no reason at all to "forget about" something that you can buy and have it work for you every time you fly. Get a glider that won't surprise you, even if you make a mistake, get the flying skills you need to handle it, and work constantly on the judgment that will keep you out of bad situations. -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On Jul 20, 1:59*pm, Eric Greenwell wrote:
On 7/20/2010 12:24 PM, bildan wrote: On Jul 20, 8:35 am, EvValentin808 *wrote: Can anyone give me a list of forgiving sailplanes out there. I know some like the Schweizers, *Rudolf Kaiser's designs(Schleicher K-series) and the Discus... Any other to list? -- EvValentin808 No doubt this thread will have a long run. My view is that all gliders are 'forgiving' - if flown by a qualified pilot. *OTOH, unqualified pilots can wreck any glider no matter how 'forgiving'. In any event, 'forgiving' handling qualities has little to do with the safety of the pilot. *Any glider, no matter how 'forgiving' can be flown into a very unforgiving Earth. *They will still collide with mountains and other gliders. *Trees and other obstacles can still wreck them. *The number of accidents with poor handling qualities as the primary cause is virtually non-existent. I don't agree at all. A qualified pilot can compensate for "unforgiving" qualities, but that doesn't make the glider "forgiving". Some gliders have very poor glide path control, some spin easily, with little warning, and don't recover quickly. Put the CG too far aft, and most gliders are likely not "forgiving". Right, and the only thing that makes these gliders 'forgiving' is pilot skill. My experience is the difference between the worst and best handling glider is fairly small. After all, they have to go through the same certification process. (Experimental glider excluded, of course.) Even a qualified pilot can be distracted, or tired, or hypoxic, or dehydrated, and the outcome is likely to be much better in a "forgiving" glider than one that isn't. You really think mere benign handling qualities will save this guy? He's likely to fly his 'forgiving' glider into a tree. What's REALLY unforgiving is nature. *Make enough mistakes and 'ol Mother Nature will kill or maim you. *She's merciless. * Her goal is just cleaning the gene pool. I don't think the "Mother Nature" is the main factor in most glider accidents. Look at how many happen near the airport and in good weather. Mother nature = gravity. Gravity is involved in all accidents. So, forget handling qualities and worry about flying skills. *They're FAR more important. There is no reason at all to "forget about" something that you can buy and have it work for you every time you fly. Get a glider that won't surprise you, even if you make a mistake, get the flying skills you need to handle it, and work constantly on the judgment that will keep you out of bad situations. I don't think you can "buy" safety - (except by hiring a highly proficient pilot to fly you around in a two seater). A lot of pilots who have tried to buy it are dead. Safety is something you have to earn with training, practice and RESPECT for the danger. |
bildan wrote:
My experience is the difference between the worst and best handling glider is fairly small. No. Give a low-time student an ASK-21 and he will happily thermal away. Give the same student a Fox and he will kill himself. |
On 2010/07/20 10:44 PM, bildan wrote:
On Jul 20, 1:59 pm, Eric wrote: On 7/20/2010 12:24 PM, bildan wrote: On Jul 20, 8:35 am, EvValentin808 wrote: Can anyone give me a list of forgiving sailplanes out there. I know some like the Schweizers, Rudolf Kaiser's designs(Schleicher K-series) and the Discus... Any other to list? -- EvValentin808 No doubt this thread will have a long run. My view is that all gliders are 'forgiving' - if flown by a qualified pilot. OTOH, unqualified pilots can wreck any glider no matter how 'forgiving'. In any event, 'forgiving' handling qualities has little to do with the safety of the pilot. Any glider, no matter how 'forgiving' can be flown into a very unforgiving Earth. They will still collide with mountains and other gliders. Trees and other obstacles can still wreck them. The number of accidents with poor handling qualities as the primary cause is virtually non-existent. I don't agree at all. A qualified pilot can compensate for "unforgiving" qualities, but that doesn't make the glider "forgiving". Some gliders have very poor glide path control, some spin easily, with little warning, and don't recover quickly. Put the CG too far aft, and most gliders are likely not "forgiving". Right, and the only thing that makes these gliders 'forgiving' is pilot skill. My experience is the difference between the worst and best handling glider is fairly small. After all, they have to go through the same certification process. (Experimental glider excluded, of course.) Even a qualified pilot can be distracted, or tired, or hypoxic, or dehydrated, and the outcome is likely to be much better in a "forgiving" glider than one that isn't. You really think mere benign handling qualities will save this guy? He's likely to fly his 'forgiving' glider into a tree. What's REALLY unforgiving is nature. Make enough mistakes and 'ol Mother Nature will kill or maim you. She's merciless. Her goal is just cleaning the gene pool. I don't think the "Mother Nature" is the main factor in most glider accidents. Look at how many happen near the airport and in good weather. Mother nature = gravity. Gravity is involved in all accidents. So, forget handling qualities and worry about flying skills. They're FAR more important. There is no reason at all to "forget about" something that you can buy and have it work for you every time you fly. Get a glider that won't surprise you, even if you make a mistake, get the flying skills you need to handle it, and work constantly on the judgment that will keep you out of bad situations. I don't think you can "buy" safety - (except by hiring a highly proficient pilot to fly you around in a two seater). A lot of pilots who have tried to buy it are dead. Safety is something you have to earn with training, practice and RESPECT for the danger. Hi Bill I'm with Eric here. My first glass was (still is) a Std Cirrus. Nimble, responsive, fun to fly. Unforgiving of inattention. Easy to spin (and correct) Landings are always challenging with the pitch sensitivity, and low washout tips. Second is a Kestrel 19 - much heavier, more complex, big wings. I know which one I have to worry more in. Specifically about my performance - not the glider - About getting dehydrated or simply tired, about making a mistake at a critical point. And you do get more tired because you can never relax in the Cirrus. Skill is not everything. Attentiveness and luck also play a role, as do things like the relative effort required to safely conduct a flight. If you fly something with exemplary handling, like a (Duo)Discus or a K21 or a LS4 it is a lot easier to be safe. --- news://freenews.netfront.net/ - complaints: --- |
On 7/20/2010 1:24 PM, bildan wrote:
On Jul 20, 8:35 am, EvValentin808 wrote: Can anyone give me a list of forgiving sailplanes out there. I know some like the Schweizers, Rudolf Kaiser's designs(Schleicher K-series) and the Discus... Any other to list? -- EvValentin808 No doubt this thread will have a long run. My view is that all gliders are 'forgiving' - if flown by a qualified pilot. OTOH, unqualified pilots can wreck any glider no matter how 'forgiving'. In any event, 'forgiving' handling qualities has little to do with the safety of the pilot. Any glider, no matter how 'forgiving' can be flown into a very unforgiving Earth. They will still collide with mountains and other gliders. Trees and other obstacles can still wreck them. The number of accidents with poor handling qualities as the primary cause is virtually non-existent. What's REALLY unforgiving is nature. Make enough mistakes and 'ol Mother Nature will kill or maim you. She's merciless. Her goal is just cleaning the gene pool. So, forget handling qualities and worry about flying skills. They're FAR more important. Well between Bill D. and Eric G. it didn't take long to 'answerically' touch upon both ends of the philosophic spectrum to the initial question! FWIW, while I don't disagree with anything Eric wrote, neither do I disagree with Bill. (And, no, I am not a politician seeking agreement with everyone!) So how do I reconcile my wildly diverging viewpoints? Easy. If there really and truly exists a Joe Glider Pilot who opts to seriously believe that by buying a 'forgiving sailplane' to the exclusion of not also mentally and physically actively working the personal-skills-development side of their piloting, I'll bet real money they'll sooner or later have an 'absence-of-skills/judgment-related' accident of some kind. (To use a power-plane-related example, think 'Ercoupe'. In the glider world, think 'G-103', AS K-21' etc. Each type is immensely docile in many ways...and each routinely crunched.) Nor is the continuing development of flight/judgment skills inoculation against having accidents...but personally, I'd much rather ride with a pilot who continually works to hone such skills, than one complacent to the point of not recognizing their value. That said, I also happen to believe that the differences between 'world's most forgiving glider' and 'world's most treacherous' are 'talkworthy-small'. I write that, as a pilot who learned on Schweizers, and (with but 400 total hours) transitioned (safely and essentially uneventfully) to a glider many pilots would probably off-the-cuff conclude is a handful. (The 'handful' is a no-spoilers, side-sticked, 1st-generation, 15-meter fiberglass Zuni.) Prior to that I flew a homebuilt 55-foot-span, V-tailed, HP-14...again landing-flaps-only/no-spoilers...you don't have to search far to find all sorts of horror stories about the difficulties of flying Schreder gliders. At transition time(s) I didn't consider myself God's gift to the soaring world (still don't, chortle). Nor did I ever consider the HP-14 or the Zuni 'a handful'. (Both - within their limitations - are, in truth, pussycats.) Meanwhile, my longtime club has historically had one or another example of Schweizer 2-32. Now *there's* a Schweizer ready to bite the unskilled, unrespectful, unwary or non-listening!!! Am I badmouthing it? Heavens, no! It's a great ship. Further, nothing in our club checkout rules for it would lead a casual reader to distinguish the 2-32 from our G-103. Yet, they're completely different gliders, as any flight involving spin attempts would beautifully/'instantly' illustrate. Furthermore, *any* checkout flight could also be expected to clearly strongly hint at why entirely different pattern 'thinking' is taught for the two ship types, as well. Yet, non-instructor-me will happily ride with any of our recently-checked-out pilots in either ship...so long as i think they're seriously interested in continuing to develop their skills and judgment. Seriously, Bob - pilot-skill spectrum far exceeds 'glider-difficulty' spectrum - W. |
On Jul 20, 2:55*pm, John Smith wrote:
bildan wrote: My experience is the difference between the worst and best handling glider is fairly small. No. Give a low-time student an ASK-21 and he will happily thermal away. Give the same student a Fox and he will kill himself. Thanks for bringing up the Fox. Learn to fly one with a great instructor and every other glider will seem like a pussycat. THEN, you're a safe - at least from handling issues. A competent pilot (meaning one who has trained in the Fox with an expert) can fly a Fox safely AND fly the ASK-21 safely. The student thermalling happily in an ASK-21 is neither competent nor safe since he may have to land in a gusty crosswind among other things. The key here isn't the glider, it's the pilot's skill. No glider is so 'forgiving' that it will save a pilot from himself or from the inevitable flukes of nature and few, if any, gliders are so viscous a pilot can't be trained to fly them safely. Safety, to the extent that it exists, is in the skill set a pilot brings to the task. I learned to fly in an LK-10A - a glider whose spin characteristics make a 2-32 seem like a pussycat. We trained all sorts to fly it and, yes, there were a few accidents but they were the same kind students have with 2-33's. Pilots were afraid of the LK's spin characteristics so they were careful not to spin (a good thing). Instead of spinning, they hit fences. Let me repeat my key point - you can't buy safety, you have to earn it with training, practice and RESPECT. If a pilot is so concerned about his ability he's seeking to buy a 'safe'glider, he should spend his money on more training. |
| Please ID 3 sailplanes | Every time | Soaring | 4 | August 20th 08 10:34 PM |
| don't try to prepare potentially while you're forgiving with a rough string | [email protected] | Piloting | 0 | August 13th 07 05:01 AM |
| Repost from Feb. 2002: " forgiving training heli" by Bob Barbanes | [email protected] | Rotorcraft | 2 | January 30th 06 09:23 PM |
| New Products for Sailplanes. | [email protected] | Soaring | 6 | July 4th 05 10:27 AM |
| 50+:1 15m sailplanes | Paul T | Soaring | 92 | January 19th 04 02:59 AM |
