Self-launch two-seater
Old August 3rd 10, 10:31 AM posted to rec.aviation.soaring
TeetJ
Default Self-launch two-seater
Any suggestions for self-launch two-seater glider at 100 000 EUR
range?
My current list:
ASH-25M: ASH25 self launchers tend to start from EUR 160 000
unfortunately. Do you know how sophisticated is the engine operation?
Is there any flight manual available in the net? (my brief look at Duo
Discus T engine starting procedure was quite a bad surprise, is
ASH-25M the same?)
DG-1001M: looks like ideal bird, but brand new and probably very
expensive?
ASK-21 Mi: Trainer, I would like to get better XC performance. New
model and a bit expensive, too.
Nimbus 4DM: Looks quite expensive and non impressive. "No aerobatics,
even no intentional spins" in the documentation is not attractive at
all.
Janus CM: very rare species, does anybody suggest?
Grob G103 Twin III SL: Also no clue how good can it be
Stemme S10: quite expensive and I am not quite sure how good for
thermalling it really is. More for touring.
Thank you!
Teet
www.purilend.ee
Old August 3rd 10, 03:13 PM posted to rec.aviation.soaring
Mitch
http://www.desertaerospace.com/bonusjet.html
'nuff said. Motor gliders with pistons are pretty much outdated these
days. This is also in your price range. Starts with the flip of a
switch and flies great!
Old August 3rd 10, 05:03 PM posted to rec.aviation.soaring
Ron
'nuff said. *Motor gliders with pistons are pretty much outdated these
days. *This is also in your price range. *Starts with the flip of a
Happened to be in Moriaty and got to see the engine extention and
retraction. Nice piece of work. The ship does not
have retractable gear but that is not much of a limitation considering
the fun one would have with this thing.
Old August 3rd 10, 10:02 PM posted to rec.aviation.soaring
Gary Osoba[_3_]
Here is another observation, and I'll try to make it as objectively as
I know how. Bob Carrolton did the original flight testing of this
configuration in Arkansas then brought the prototype to Moriarity. I
observed his first flight with it in New Mexico, and many subsequent
flights- all at density altitudes in the 10,000'- 12,000' range. To
give perspective, the two place glider I was flying on those occasions
would often only average a few hundred feet a minute in climb behind a
Pawnee. On a couple of flights, we spent many minutes on tow under
400' and near the airport.
On every occasion, the turbine powered prototype climbed robustly and
very impressively. Much faster than any motorglider I have even seen.
I do not think that the published climb rate of 900 fpm is an
exaggeration, but this is only from my personal observation. It would
be reasonable to assume that as Bob and Mark Mocho continue to refine
and optimize the system, performance will improve. The implementation
is elegant, simple (read that fewer problems or failures), and
efficient for a turbine. The turbine which is utilized has a very
long history, a continuous production run, and a solid service
history.
If the Test (design) glider- which is very affordable- doesn't float
your boat for whatever reason, Bob can custom engineer a turbine
implementation on something that likely would.
I don't have any connection to this group, and only owned a
motorglider for a short period of time back in the 1980's. However, I
would love to have one of these turbines on something with high
performance. And I think that Bob's group is doing important
pioneering work in this field.
Best Regards,
Gary Osoba
Old August 3rd 10, 10:36 PM posted to rec.aviation.soaring
Brad[_2_]
I know how. *Bob Carrolton did the original flight testing of this
efficient for a turbine. *The turbine which is utilized has a very
history.
Best Regards,
Gary Osoba
It's been about 5 years now, but the last TST built glider I saw was
rather crude in many ways: The wing spar was wood, no automatic
hookups and there were other fit and finish issues that made me
somewhat adverse to owning a glider built by these folks.
Now.............don't get me wrong, if the reason they are
"affordable" is because of these issues than they are moot, but if the
reason is labor costs and a desire to offer an "affordable" glider is
part of the company philosophy then more power to them. I have not
seen the jet powered 2 seater, I hope to someday................I also
hope that the company has refined their manufacturing process to put
out a higher quality product.
I thought the concept of the TST-10 Atlas was pretty cool. A jet
powered 2 seater even cooler................and I do have an empty
engine bay in my Apis-13!
Brad
Old August 3rd 10, 11:45 PM posted to rec.aviation.soaring
Brian Whatcott
range?
My current list:
ASH-25M the same?)
expensive?
all.
Thank you!
Teet
www.purilend.ee
A 2 year old ad for a 40 year vold Fournier RF-5.
That's my idea of a 2 seat self launch! :-)
http://tinyurl.com/2fn9k5w
Brian W
Old August 4th 10, 06:08 AM posted to rec.aviation.soaring
JS
The DG500M should also fit your requirements.
Late C- model Janii aren't bad, the CM should all be the improved
fuselage (especially rear cockpit).
I have seen a Grob Twin 3M do surprisingly well in Club Class
competition.
Old August 4th 10, 06:18 AM posted to rec.aviation.soaring
Eric Greenwell
range?
My current list:
Add the Taurus to your list:
http://www.mcp.com.au/pipistrel-usa/models/taurus.html
Eric Greenwell - Washington State, USA (netto to net to email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz
Old August 6th 10, 12:07 PM posted to rec.aviation.soaring
TeetJ
On Aug 4, 8:18*am, Eric Greenwell wrote:
On 8/3/2010 2:31 AM, TeetJ wrote: Any suggestions for self-launch two-seater glider at 100 000 EUR
range?
My current list:
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl
True, I forgot about Taurus.
I was a bit scared because Taurus being UL. How good speed-gliding
performance you can realistically get from relatively light glider?
Does anyone have experience how this bird behaves in thermals?
Thanks
Old August 6th 10, 12:52 PM posted to rec.aviation.soaring
JC
Thanks
I flew in a contest last year where there was a Taurus and it seems to
have performance similar to a Cirrus. That would be less than the 40:1
claimed by the factory but still very respectable. The owner is not
experienced in competition flying so it would be interesting to see
how it performs in the hands of a seasoned pilot. I´m pretty sure it
would do very well.
It´s a really beautiful ship, very well built and with one of the best
engine pylon systems I´ve seen so far.
The cockpit is very modern and comfortable and it also has a ballistic
parachute. Bang for buck I think it´s probably one of the best deals
around and I would love to have one if I could afford it.
Klaus Ohlman has one and seems to be happy with it..
Regards,
Juan Carlos
F-16 Two Seater Canuck[_2_] Aviation Photos 0 September 3rd 08 03:40 PM
two seater BD5 Philippe Vessaire Home Built 6 October 28th 07 05:28 PM
WTB 2 seater L/S Nav Sleigh Soaring 0 June 11th 06 06:50 PM
WTB L/S Nav 2 Seater Sleigh Soaring 0 May 20th 06 08:28 PM
4-seater Nyal Williams Soaring 54 November 29th 04 10:53 AM
