I'm looking for sources of tow rope in the USA. Can you help?
Thanks, Doug |
On Aug 23, 7:38*pm, tazman wrote:
I'm looking for sources of tow rope in the USA. Can you help? Thanks, Doug Try wingsandwheels.com |
I'm partial to fisherman & marine supply stores for rope. They have an
abundance of styles, strengths, and composition. Also, they usually are reasonably priced. |
On Aug 23, 4:38*pm, tazman wrote:
I'm looking for sources of tow rope in the USA. Can you help? Thanks, Doug We get our rope from the local "rigging" store. 600ft spool of 5/8 3 ply ploy pro makes three 200ft tow ropes, we put an eye splice in each end and appropriate weak links. Each spool costs us about $84 and the three ropes last about 9 months, 3 months each rope. We operate off a paved runway, do not drop the rope on landing, but the end does get dragged across a gravel area before the pavement on landing. The "whip" end of the rope gets weaker and we normally trim about 10ft and redo the eye splice. Normally after 2 trimmings it is time to replace the rope. |
On Aug 23, 6:42*pm, BTiz wrote:
On Aug 23, 4:38*pm, tazman wrote: I'm looking for sources of tow rope in the USA. Can you help? Thanks, Doug We get our rope from the local "rigging" store. 600ft spool of 5/8 3 ply ploy pro makes three 200ft tow ropes, we put an eye splice in each end and appropriate weak links. Each spool costs us about $84 and the three ropes last about 9 months, 3 months each rope. We operate off a paved runway, do not drop the rope on landing, but the end does get dragged across a gravel area before the pavement on landing. *The "whip" end of the rope gets weaker and we normally trim about 10ft and redo the eye splice. Normally after 2 trimmings it is time to replace the rope. We use Samson Polytron Quiksplice: http://www.cbknot.com/QuikSplicePolytron.htm about $0.08 from many sources. It's something like spun olefin (Tyvek) and it is really good stuff. It is a UV resistant abraision resistant rigging line use in fishnet rigging applications. Brian |
"brianDG303" wrote in message ... On Aug 23, 6:42 pm, BTiz wrote: On Aug 23, 4:38 pm, tazman wrote: I'm looking for sources of tow rope in the USA. Can you help? Thanks, Doug We get our rope from the local "rigging" store. 600ft spool of 5/8 3 ply ploy pro makes three 200ft tow ropes, we put an eye splice in each end and appropriate weak links. Each spool costs us about $84 and the three ropes last about 9 months, 3 months each rope. We operate off a paved runway, do not drop the rope on landing, but the end does get dragged across a gravel area before the pavement on landing. The "whip" end of the rope gets weaker and we normally trim about 10ft and redo the eye splice. Normally after 2 trimmings it is time to replace the rope. We use Samson Polytron Quiksplice: http://www.cbknot.com/QuikSplicePolytron.htm about $0.08 from many sources. It's something like spun olefin (Tyvek) and it is really good stuff. It is a UV resistant abraision resistant rigging line use in fishnet rigging applications. Brian I can't tell from the catalogue. Is this a hollow braid rope? Thanks Hartley Falbaum |
On Aug 24, 5:23*am, "HL Falbaum" wrote:
"brianDG303" wrote in message ... On Aug 23, 6:42 pm, BTiz wrote: On Aug 23, 4:38 pm, tazman wrote: I'm looking for sources of tow rope in the USA. Can you help? Thanks, Doug We get our rope from the local "rigging" store. 600ft spool of 5/8 3 ply ploy pro makes three 200ft tow ropes, we put an eye splice in each end and appropriate weak links. Each spool costs us about $84 and the three ropes last about 9 months, 3 months each rope. We operate off a paved runway, do not drop the rope on landing, but the end does get dragged across a gravel area before the pavement on landing. The "whip" end of the rope gets weaker and we normally trim about 10ft and redo the eye splice. Normally after 2 trimmings it is time to replace the rope. We use Samson Polytron Quiksplice: http://www.cbknot.com/QuikSplicePolytron.htm about $0.08 from many sources. It's something like spun olefin (Tyvek) and it is really good stuff. It is a UV resistant abraision resistant rigging line use in fishnet rigging applications. Brian I can't tell from the catalogue. Is this a hollow braid rope? Thanks Hartley Falbaum This? 12-strand single braid description, but the image appears to be double braid. http://www.samsonrope.com/index.cfm?rope=66 |
On Aug 24, 7:39*am, Frank Whiteley wrote:
On Aug 24, 5:23*am, "HL Falbaum" wrote: "brianDG303" wrote in message .... On Aug 23, 6:42 pm, BTiz wrote: On Aug 23, 4:38 pm, tazman wrote: I'm looking for sources of tow rope in the USA. Can you help? Thanks, Doug We get our rope from the local "rigging" store. 600ft spool of 5/8 3 ply ploy pro makes three 200ft tow ropes, we put an eye splice in each end and appropriate weak links. Each spool costs us about $84 and the three ropes last about 9 months, 3 months each rope. We operate off a paved runway, do not drop the rope on landing, but the end does get dragged across a gravel area before the pavement on landing. The "whip" end of the rope gets weaker and we normally trim about 10ft and redo the eye splice. Normally after 2 trimmings it is time to replace the rope. We use Samson Polytron Quiksplice: http://www.cbknot.com/QuikSplicePolytron.htm about $0.08 from many sources. It's something like spun olefin (Tyvek) and it is really good stuff. It is a UV resistant abraision resistant rigging line use in fishnet rigging applications. Brian I can't tell from the catalogue. Is this a hollow braid rope? Thanks Hartley Falbaum This? *12-strand single braid description, but the image appears to be double braid. http://www.samsonrope.com/index.cfm?rope=66 That's the rope we use, in 6mm or 1/4". I'm not sure what hollow braid is exactly but we use a hollow braid splice to put the rings on, you loop it back on itself, shove about 18" up into the hollow core (through the braid) and you are good. Brian |
I have nearly every type of tow rope available......literally 100's of
spools in stock see my website page http://www.wingsandwheels.com/page30.htm thanks tim -- Please visit the Wings & Wheels website at www.wingsandwheels.com "tazman" wrote in message ... I'm looking for sources of tow rope in the USA. Can you help? Thanks, Doug __________ Information from ESET NOD32 Antivirus, version of virus signature database 5394 (20100824) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 5394 (20100824) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
On Aug 24, 5:23*am, "HL Falbaum" wrote: "brianDG303" wrote in message .... On Aug 23, 6:42 pm, BTiz wrote: On Aug 23, 4:38 pm, tazman wrote: I'm looking for sources of tow rope in the USA. Can you help? Thanks, Doug We get our rope from the local "rigging" store. 600ft spool of 5/8 3 ply ploy pro makes three 200ft tow ropes, we put an eye splice in each end and appropriate weak links. Each spool costs us about $84 and the three ropes last about 9 months, 3 months each rope. We operate off a paved runway, do not drop the rope on landing, but the end does get dragged across a gravel area before the pavement on landing. The "whip" end of the rope gets weaker and we normally trim about 10ft and redo the eye splice. Normally after 2 trimmings it is time to replace the rope. We use Samson Polytron Quiksplice: http://www.cbknot.com/QuikSplicePolytron.htm about $0.08 from many sources. It's something like spun olefin (Tyvek) and it is really good stuff. It is a UV resistant abraision resistant rigging line use in fishnet rigging applications. Brian I can't tell from the catalogue. Is this a hollow braid rope? Thanks Hartley Falbaum This? *12-strand single braid description, but the image appears to be double braid. http://www.samsonrope.com/index.cfm?rope=66- Hide quoted text - - Show quoted text - We tried the 12strand hollow braid out here in the desert. It did not last as long as the 3ply twisted poly pro. Bill |
| Tow rope reel | Don[_4_] | Soaring | 4 | October 31st 08 06:05 PM |
| Where to buy AmSteel tow rope? | [email protected] | Soaring | 2 | April 20th 06 03:45 AM |
| 11 on a Rope | Peter Seddon | Rotorcraft | 0 | May 27th 04 12:33 PM |
| Donuts on a rope | Big John | Piloting | 4 | May 2nd 04 05:53 AM |
| Tow Rope Take-Up Reels | Nyal Williams | Soaring | 1 | September 17th 03 05:11 PM |
