Anyone with any experience with LOM engines? I am considering the benefits
of a 170 HP LOM 332CE for use in a Mustang II which is rated for a powerplant in the O-320 to IO-360 range. LOM sounds like it might be "real airplane" without the other-worldly prices commanded by Lycoming, Superior Millenium etc. Any first hand experience here? |
"buckey" wrote: Anyone with any experience with LOM engines? I am considering the benefits of a 170 HP LOM 332CE for use in a Mustang II which is rated for a powerplant in the O-320 to IO-360 range. LOM sounds like it might be "real airplane" without the other-worldly prices commanded by Lycoming, Superior Millenium etc. Any first hand experience here? ++++++++++++++++++++++++++++ Nope. Just good used 2nd hand. Banryard BOb -- |
In article , Barnyard BOb -- says...
Hey Unka Bob Just curious,but what is a LOM 332 engine? I don't recall ever hearing of it. Thanks Chuck (I don't know everything) S "buckey" wrote: Anyone with any experience with LOM engines? I am considering the benefits of a 170 HP LOM 332CE for use in a Mustang II which is rated for a powerplant in the O-320 to IO-360 range. LOM sounds like it might be "real airplane" without the other-worldly prices commanded by Lycoming, Superior Millenium etc. Any first hand experience here? ++++++++++++++++++++++++++++ Nope. Just good used 2nd hand. Banryard BOb -- |
See Ayers RV-3:
http://www.aviator.cc/ayers.html buckey wrote: Anyone with any experience with LOM engines? I am considering the benefits of a 170 HP LOM 332CE for use in a Mustang II which is rated for a powerplant in the O-320 to IO-360 range. LOM sounds like it might be "real airplane" without the other-worldly prices commanded by Lycoming, Superior Millenium etc. Any first hand experience here? -- John Kimmel In the desert I saw a creature, naked, bestial, Who, squatting upon the ground, Held his heart in his hands, And ate of it. I said, "Is it good, friend?" "It is bitter -- bitter", he answered, "But I like it Because it is bitter, And because it is my heart." |
Try this link: http://www.eaa.org/benefits/sportavi...lastar0311.pdf It is an article from the current Sport Aviation. The subject aircraft is a LOM powered Glastar. According to the story, the owner is happy with the installation. KB |
Anyone with any experience with LOM engines? I am considering the benefits of a 170 HP LOM 332CE for use in a Mustang II which is rated for a powerplant in the O-320 to IO-360 range. LOM sounds like it might be "real airplane" without the other-worldly prices commanded by Lycoming, Superior Millenium etc. Any first hand experience here? ++++++++++++++++++++++++++++ Nope. Just good used 2nd hand. Banryard BOb -- Hey Unka Bob Just curious,but what is a LOM 332 engine? I don't recall ever hearing of it. Thanks Chuck (I don't know everything) S +++++++++++++++++++++++++++++++++ This is 2nd hand, but it's a start.... g http://www.weebeastie.com/hatzcb1/motorLOM.html http://www.lompraha.cz/services.htm http://mbarbee.home.mindspring.com/LOM%20history.htm http://sbeaver.tzo.com/bucker/engines1.htm Even in an RV-3..... http://www.aviator.cc/ayers.html Unka BOb -- RV3 driver |
Thanks Unka Bob I knew you'd know. It's a Walter engine I heard of Walter engines but I never heard the term LOM for them. Mary Carlson of Carlson Aviation has one in their Storch replica called a Cricket. I've seen it in their plane. See I just learned something. Just like Sister Mary Pontius Pilot used to say "keep your eyes open and your mouth shut and ya moght learn something" :-) Thanks Nefoo Chuck Hey Unka Bob Just curious,but what is a LOM 332 engine? I don't recall ever hearing of it. Thanks Chuck (I don't know everything) S +++++++++++++++++++++++++++++++++ This is 2nd hand, but it's a start.... g Unka BOb -- RV3 driver |
On 29 Oct 2003 05:31:19 -0800, ChuckSlusarczyk
wrote: In article , Barnyard BOb -- says... Thanks Unka Bob I knew you'd know. It's a Walter engine I heard of Walter engines but I never heard the term LOM for them. Mary Carlson of Carlson Aviation has one in their Storch replica called a Cricket. I've seen it in their plane. See I just learned something. Just like Sister Mary Pontius Pilot used to say "keep your eyes open and your mouth shut and ya moght learn something" :-) I wonder why they use such a low compression ratio? Even car engines running regular usually run 8:1. This one is 6.3:1. It would reduce the stress on the parts, allowing less expensive materials than a reliable high compression engine. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) Thanks Nefoo Chuck Hey Unka Bob Just curious,but what is a LOM 332 engine? I don't recall ever hearing of it. Thanks Chuck (I don't know everything) S +++++++++++++++++++++++++++++++++ This is 2nd hand, but it's a start.... g Unka BOb -- RV3 driver |
Thanks Unka Bob I knew you'd know. It's a Walter engine I heard of Walter engines but I never heard the term LOM for them. Mary Carlson of Carlson Aviation has one in their Storch replica called a Cricket. I've seen it in their plane. See I just learned something. Just like Sister Mary Pontius Pilot used to say "keep your eyes open and your mouth shut and ya moght learn something" :-) I wonder why they use such a low compression ratio? Even car engines running regular usually run 8:1. This one is 6.3:1. It would reduce the stress on the parts, allowing less expensive materials than a reliable high compression engine. Roger Halstead ++++++++++++++++++++++++++++++++++++ My normally aspirated 150 HP Lycoming is 7.0:1 for 80 octane while the 160 HP version is 8.5;1 requiring 100LL. I suspect the 6.3:1 is to prevent detonation when the turbo is at max boost at 100% power. Effective compression with turbo boost likely exceeds 7.3:1. Higher compression could require water injection and/or higher octane fuel to safely remain out of detonation range. Air cooled engines require a lower compression ratio than liquid cooled engines to insure detonation is never achieved under any condition. That's what I was told, anyway. Barnyard BOb -- 50 years of flight |
In article , Roger Halstead says...
I wonder why they use such a low compression ratio? Even car engines running regular usually run 8:1. This one is 6.3:1. It would reduce the stress on the parts, allowing less expensive materials than a reliable high compression engine. I guess they can also use lower octane fuel as well. Chuck |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 04:07 AM |
| Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 01:44 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
| LOM engines | Salem Farm & Garden | Home Built | 2 | July 23rd 03 12:30 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
