![]() "ChuckSlusarczyk" wrote in message ... In article , Roger Halstead says... I wonder why they use such a low compression ratio? Even car engines running regular usually run 8:1. This one is 6.3:1. It would reduce the stress on the parts, allowing less expensive materials than a reliable high compression engine. I guess they can also use lower octane fuel as well. Chuck 6.3 to 1 is the compression ratio for the Continental A-65, which loves 80 octane avgas when it can find it. |
Roger Halstead wrote: I wonder why they use such a low compression ratio? Even car engines running regular usually run 8:1. This one is 6.3:1. It would reduce the stress on the parts, allowing less expensive materials than a reliable high compression engine. They use such a low compression ratio so they can use Russian gasoline! |
On Thu, 30 Oct 2003 03:50:22 GMT, Orval Fairbairn
wrote: In article , Roger Halstead wrote: I wonder why they use such a low compression ratio? Even car engines running regular usually run 8:1. This one is 6.3:1. It would reduce the stress on the parts, allowing less expensive materials than a reliable high compression engine. They use such a low compression ratio so they can use Russian gasoline! No. They use the low compression ratio because the Walther LOM engine has a centrifugal engine driven supercharger. ANy higher CR would be dangerous under boost. |
Roger Halstead wrote in message I wonder why they use such a low
compression ratio? Even car engines running regular usually run 8:1. This one is 6.3:1. It would reduce the stress on the parts, allowing less expensive materials than a reliable high compression engine. Durability is one reason. Additionally, the typical bore and stroke in aircraft engines is much larger than automotive engines. I forget exactly why the larger bore and stroke is more susceptable to detonation, but I seem to recall it has something to do the ratio of quench area to fuel/air charge decreasing as the cylinder size increases. D. |
On Thu, 30 Oct 2003 03:59:54 GMT, clare @ snyder.on .ca wrote:
On Thu, 30 Oct 2003 03:50:22 GMT, Orval Fairbairn wrote: In article , Roger Halstead wrote: I wonder why they use such a low compression ratio? Even car engines running regular usually run 8:1. This one is 6.3:1. It would reduce the stress on the parts, allowing less expensive materials than a reliable high compression engine. They use such a low compression ratio so they can use Russian gasoline! No. They use the low compression ratio because the Walther LOM engine has a centrifugal engine driven supercharger. ANy higher CR would be dangerous under boost. US turbo'd engines use either 8 or 8.5:1 and my 300 HP IO540 uses 10:1 I'd think it would have a lot to do with the gas they are designed to use and well as durability and manufacturing cost. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2). |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 12:44 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
LOM engines | Salem Farm & Garden | Home Built | 2 | July 22nd 03 11:30 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
