I think the answer to everything is more complexity????? *Adding a 3rd collision avoidance technology is more complexity. *If I was running the the FAA, we'd have a single ADS-B technology period. *That's simplicity.. It seems that Darryl has consumed so much Koolaid that he's starting to hallucinate. -- Mike Schumann But you're not running the FAA, the FAA is running the FAA. And the way they are running it, if Flarm or similar devices were to add ADS-B out or operate through the ADS-B protocol rather than low-power direct radio, it would cost them thousands of more dollars, many more amps, plus interminable certification delays. It's not happening; Powerflarm is here and now -- you can see the jets, you get superb collision avoidance with other gliders and towplanes that install it, and if you add a mode-S transponder the jets can see you. It makes perfect sense to separate the "in" and glider-glider box (not certified) from the much more expensive and certified "out" and "jet sees you" box. I just can't understand the fuss. Who is drinking the koolaid here? John Cochrane |
On Oct 22, 10:58*am, John Cochrane
wrote: I think the answer to everything is more complexity????? *Adding a 3rd collision avoidance technology is more complexity. *If I was running the the FAA, we'd have a single ADS-B technology period. *That's simplicity. It seems that Darryl has consumed so much Koolaid that he's starting to hallucinate. -- Mike Schumann But you're not running the FAA, the FAA is running the FAA. And the way they are running it, if Flarm or similar devices were to add ADS-B out or operate through the ADS-B protocol rather than low-power direct radio, it would cost them thousands of more dollars, many more amps, plus interminable certification delays. It's not happening; Powerflarm is here and now -- you can see the jets, you get superb collision avoidance with other gliders and towplanes that install it, and if you add a mode-S transponder the jets can see you. It makes perfect sense to separate the "in" and glider-glider box (not certified) from the much more expensive and certified "out" and "jet sees you" box. I just can't understand the fuss. Who is drinking the koolaid here? John Cochrane I work with the FAA as a contractor, trust me NOTHING is ever simple with them.... |
On 10/22/2010 10:53 AM, Darryl Ramm wrote:
On Oct 22, 7:34 am, Mike wrote: On 10/22/2010 10:30 AM, Darryl Ramm wrote: On Oct 22, 6:55 am, Mike wrote: On 10/21/2010 1:36 PM, kirk.stant wrote: PowerFLARM is supposed to have the capability to detect and display Mode S 1090ES position data on its display. How many aircraft (Airliners, bizjets?) currently send out 1090ES data? This is for the US, of course. Kirk 66 If PowerFLARM was a full blown ADS-B IN/OUT system, you would be able to see all transponder equipped aircraft using the TIS-B data transmitted from your local ADS-B ground station. But...... -- Mike Schumann The question was about airliners and you will not need ADS-B data out to see the 1090ES data out from airliners or many of the other aircraft who (fly above FL180 and so) are all required to equip with 1090ES by 2020. PowerFLARM will do that just fine out of the box. For one I am glad that Flarm and Butterfly are not stupid enough to go down that rathole. If you want 1090ES data-out you add a Mode S transponder. There are many reasons to separate the functions in two boxes, starting with there is a large market worldwide already for stand alone Mode S transponders and by decoupling the highly regulated data-out functions from the data-in functions allows innovative companies to develop innovative products--just like PowerFLARM. And in most countries you do not need ADS-B data out to see other ADS-B data out equipped aircraft - only in the USA. Vendors are going to optimize products for a worldwide market? I seems Mike Schumann thinks the answer to everything is more complexity... and this is yet another awful suggestion. And if PowerFLARM had 1090ES data-out it would cost thousands of dollars more plus likely require a certified GPS (the FAA may have closed off any chance of not requiring this by forcing STC approval-experimental gliders might still get away eith this?) that currently costs thousands plus for the forseablefuture require an STC approval for each glider type it is installed in I think the answer to everything is more complexity????? Adding a 3rd collision avoidance technology is more complexity. If I was running the the FAA, we'd have a single ADS-B technology period. That's simplicity. It seems that Darryl has consumed so much Koolaid that he's starting to hallucinate. -- Mike Schumann Mike I focus here on trying to point out what technologies will do and what they won't and trying to help pilots navigate the reality of a complex mess of technology. You seem to spend a lot of time dreaming about what might be if only... Regardless of how impractical or unlikely for practical market reasons they might be. The collision concern for most glider pilots is I believe glider- glider risk. The clear, well proven and logical choice for helping reduce that risk is for pilots to deploy FLARM asap and stop dreaming about ADS-B UAT vaporware for glider-glider collision avoidance. I think folks here can look at the mess around ADS-B right now and realize that the minimal complexity path to solve that problem is PowerFLARM (which also provides PCAS and a future path to ADS-B). If airliners are a concern then add a transponder (right now-it also is simple, straightforward and just works). Darryl Amongst the glider pilots I fly with, glider / GA and glider / Airliner collision risks are at least as big a concern, if not bigger than glider / glider. Only 10% of US pilots fly in contests, where glider / glider collisions is obviously a very big problem. The FAA has obviously made a HUGE mess of ADS-B. However, the ground stations are rolling out. The Navworx ADS-B transceiver is shipping, and could easily be interfaced to Clear Nav, See You Mobile, etc... if we could get the soaring community to help get the parties to cooperate. Obviously the cost of the Navworx unit is higher than we would like, so the commercial viability of this unit in the glider world remains to be seen. Your dismissive attitude towards ADS-B is not helping to get vendors interested in providing solutions for the glider community. If this is your intent, then you are doing a great job. I hope you are getting a nice fat commission check from the FLARM boys. -- Mike Schumann |
Mike, you are way out of line for your uncalled for insult to Darryl.
I would also remind you that an ADS-B transceiver was in the cockpit of a glider involved in a recent mid-air with another glider. Unfortunately, it didn't help. Like FLARM itself, one needs ADS-B devices in both cockpits. In my opinion, the cheaper PowerFLARM and 1090 Mode S combination has a much better chance of being adopted than the Navwork solution you tout. -John On Oct 22, 3:59 pm, Mike Schumann wrote: Amongst the glider pilots I fly with, glider / GA and glider / Airliner collision risks are at least as big a concern, if not bigger than glider / glider. Only 10% of US pilots fly in contests, where glider / glider collisions is obviously a very big problem. The FAA has obviously made a HUGE mess of ADS-B. However, the ground stations are rolling out. The Navworx ADS-B transceiver is shipping, and could easily be interfaced to Clear Nav, See You Mobile, etc... if we could get the soaring community to help get the parties to cooperate. Obviously the cost of the Navworx unit is higher than we would like, so the commercial viability of this unit in the glider world remains to be seen. Your dismissive attitude towards ADS-B is not helping to get vendors interested in providing solutions for the glider community. If this is your intent, then you are doing a great job. I hope you are getting a nice fat commission check from the FLARM boys. -- Mike Schumann |
On Oct 21, 10:36*am, "kirk.stant" wrote:
PowerFLARM is supposed to have the capability to detect and display Mode S 1090ES position data on its display. *How many aircraft (Airliners, bizjets?) currently send out 1090ES data? This is for the US, of course. Kirk 66 I see on average about 6-7 1090ES ADS-B aircraft with a simple rooftop antenna in Oakland, CA, USA. Off course, most are international carriers going in and out of SFO. Urs FLARM |
On Oct 23, 7:55*am, " wrote:
On Oct 21, 10:36*am, "kirk.stant" wrote: PowerFLARM is supposed to have the capability to detect and display Mode S 1090ES position data on its display. *How many aircraft (Airliners, bizjets?) currently send out 1090ES data? This is for the US, of course. Kirk 66 I see on average about 6-7 1090ES ADS-B aircraft with a simple rooftop antenna in Oakland, CA, USA. Off course, most are international carriers going in and out of SFO. Urs FLARM Which also brings up another source of info on this - so called "virtual radar", Dave Nadler and I was also talking with me about offline about this so I thought I'd share. There are relatively low cost ADS-B 1090ES receivers available that hook up to PCs and vendors of those products have built closed networks based on those systems where you can see 1090ES based traffic. Those receivers can get pretty impressive ranges (up to hundred of miles) with a good rooftop antenna. The momentum to do all this has been from aviation/technology hobbyist in Europe where there has been early adoption of 1090ES data- out by airliners. There is not full 1090ES data-out carriage requirements in Europe yet and we are many years away from full carriage in the USA. The network of private 1090ES monitoring receivers in Europe is pretty impressive but relatively sparse in the USA. In additon to these closed networks (where you have to buy one of their receiver boxes or at least software to join) is there are also open-network versions of these systems including FlightRadar24 which has sparse USA coverage. But here is what you can do with it... o On http://www.flightradar24.com go to "Jump to Area" and select USA. o You will see some traffic around Washington state, Los Angeles Basin and a few other places. o Click on an aircraft icon to get information about the aircraft and the carrier. If you see the flight there it is equipped with 1090ES data-out so this gives a feel for what airlines, aircraft and flights in the USA are 1090ES data-out equipped. The coverage is very sparse and it is not clear what coverage each location actually has and it is not clear what filtering if any is applied to non-airline flights. The confusing "Radar" labels like KLAX do *not* mean this is a feed from KLAX tower radar, SOCAL approach etc. its just what the private owner of the 1090ES receiver called his receiver station. Here for example are the flights I see right now over the Los Angeles Basin. American Airlines B737-823 (B738) American Airlines Boeing 767-323 (B763) Delta Airlines unknown United Airlines Boeing 777-222 (B772) Virgin America Airbus A319-112 (A319) Virgin America Airbus A320-214 (A320) We are just at the start of this. Europe has been leading with heavy aircraft adoption (look at the Flight Radar 24 maps for Europe) but with the 2020 ADS-B data-out mandate now the USA is finally starting to get going. By 2020 all the airliners, private jets, turboprops, some high performance singles and twins etc. (anybody who flies over FL180) will be mandated to have 1090ES data-out. And I expect many other aircraft owners will choose 1090ES data-out to meet the 2020 ADS- B carriage mandate. I expect some domestic airliners and freight haulers who see some early ADS-B data-out benefits in the USA will adopt within their fleet well before 2020, its just hard to find out exactly their plans. Personally I am very happy that PowerFLARM in the USA gives us this ADS-B compatibility/future path. And there is a virtual radar portal at http://radarspotters.eu/ which links to different products etc. if you are interested in this stuff. Darryl |
On Oct 22, 7:58*am, John Cochrane
wrote: I think the answer to everything is more complexity????? *Adding a 3rd collision avoidance technology is more complexity. *If I was running the the FAA, we'd have a single ADS-B technology period. *That's simplicity. It seems that Darryl has consumed so much Koolaid that he's starting to hallucinate. -- Mike Schumann But you're not running the FAA, the FAA is running the FAA. And the way they are running it, if Flarm or similar devices were to add ADS-B out or operate through the ADS-B protocol rather than low-power direct radio, it would cost them thousands of more dollars, many more amps, plus interminable certification delays. It's not happening; Powerflarm is here and now -- you can see the jets, you get superb collision avoidance with other gliders and towplanes that install it, and if you add a mode-S transponder the jets can see you. It makes perfect sense to separate the "in" and glider-glider box (not certified) from the much more expensive and certified "out" and "jet sees you" box. I just can't understand the fuss. Who is drinking the koolaid here? John Cochrane Amen. The Navworx "simple solution" transceiver draws nearly 1 amp at 12 volts WITHOUT a display, doesn't integrate with any existing soaring computers, doesn't do glider flight path projection that is essential to glider-glider collision avoidance and doesn't directly receive 1090ES data-out signals for the multitude of areas where that's what you need because the ground station coverage isn't designed for the places glider fly. Oh, and it costs $2500 but doesn't include PCAS. So it solves exactly ZERO of the problems that currently matter to glider pilots and, IMO, is likely to lose out to 1090ES in the long run because of the aforementioned regulatory requirements. PowerFlarm plus a Trig 21 is a great way to go because it solves actual problems we have today and PowerFlarm alone is a pretty good improvement overall and adequate if you don't fly near a major commercial airport. Seems simple enough to me. 9B |
On 10/23/2010 3:43 PM, Andy wrote:
On Oct 22, 7:58 am, John wrote: I think the answer to everything is more complexity????? Adding a 3rd collision avoidance technology is more complexity. If I was running the the FAA, we'd have a single ADS-B technology period. That's simplicity. It seems that Darryl has consumed so much Koolaid that he's starting to hallucinate. -- Mike Schumann But you're not running the FAA, the FAA is running the FAA. And the way they are running it, if Flarm or similar devices were to add ADS-B out or operate through the ADS-B protocol rather than low-power direct radio, it would cost them thousands of more dollars, many more amps, plus interminable certification delays. It's not happening; Powerflarm is here and now -- you can see the jets, you get superb collision avoidance with other gliders and towplanes that install it, and if you add a mode-S transponder the jets can see you. It makes perfect sense to separate the "in" and glider-glider box (not certified) from the much more expensive and certified "out" and "jet sees you" box. I just can't understand the fuss. Who is drinking the koolaid here? John Cochrane Amen. The Navworx "simple solution" transceiver draws nearly 1 amp at 12 volts WITHOUT a display, doesn't integrate with any existing soaring computers, doesn't do glider flight path projection that is essential to glider-glider collision avoidance and doesn't directly receive 1090ES data-out signals for the multitude of areas where that's what you need because the ground station coverage isn't designed for the places glider fly. Oh, and it costs $2500 but doesn't include PCAS. So it solves exactly ZERO of the problems that currently matter to glider pilots and, IMO, is likely to lose out to 1090ES in the long run because of the aforementioned regulatory requirements. PowerFlarm plus a Trig 21 is a great way to go because it solves actual problems we have today and PowerFlarm alone is a pretty good improvement overall and adequate if you don't fly near a major commercial airport. Seems simple enough to me. 9B You can argue all of these points ad nauseum, but your credibility goes out the window when you say that PowerFlarm is here and now. It has not been FCC approved, is not available for sale in the US and is not shipping. When it is, go ahead and push it all you want. In the mean time, the Navworx box is shipping. Yes, it may not be the ideal solution; it may not integrate with glide computers; it may draw more power than you want; it may be too expensive. But it is here and now, unlike PowerFlarm. -- Mike Schumann |
On Oct 23, 4:02*pm, Mike Schumann
wrote: On 10/23/2010 3:43 PM, Andy wrote: On Oct 22, 7:58 am, John wrote: I think the answer to everything is more complexity????? *Adding a 3rd collision avoidance technology is more complexity. *If I was running the the FAA, we'd have a single ADS-B technology period. *That's simplicity. It seems that Darryl has consumed so much Koolaid that he's starting to hallucinate. -- Mike Schumann But you're not running the FAA, the FAA is running the FAA. And the way they are running it, if Flarm or similar devices were to add ADS-B out or operate through the ADS-B protocol rather than low-power direct radio, it would cost them thousands of more dollars, many more amps, plus interminable certification delays. It's not happening; Powerflarm is here and now -- you can see the jets, you get superb collision avoidance with other gliders and towplanes that install it, and if you add a mode-S transponder the jets can see you. It makes perfect sense to separate the "in" and glider-glider box (not certified) from the much more expensive and certified "out" and "jet sees you" box. I just can't understand the fuss. Who is drinking the koolaid here? John Cochrane Amen. *The Navworx "simple solution" transceiver draws nearly 1 amp at 12 volts WITHOUT a display, doesn't integrate with any existing soaring computers, doesn't do glider flight path projection that is essential to glider-glider collision avoidance and doesn't directly receive 1090ES data-out signals for the multitude of areas where that's what you need because the ground station coverage isn't designed for the places glider fly. Oh, and it costs $2500 but doesn't include PCAS. So it solves exactly ZERO of the problems that currently matter to glider pilots and, IMO, is likely to lose out to 1090ES in the long run because of the aforementioned regulatory requirements. PowerFlarm plus a Trig 21 is a great way to go because it solves actual problems we have today and PowerFlarm alone is a pretty good improvement overall and adequate if you don't fly near a major commercial airport. Seems simple enough to me. 9B You can argue all of these points ad nauseum, but your credibility goes out the window when you say that PowerFlarm is here and now. *It has not been FCC approved, is not available for sale in the US and is not shipping. *When it is, go ahead and push it all you want. *In the mean time, the Navworx box is shipping. *Yes, it may not be the ideal solution; it may not integrate with glide computers; it may draw more power than you want; it may be too expensive. *But it is here and now, unlike PowerFlarm. -- Mike Schumann I hope most people can work out that your thought process around collision avoidance technology lacks any practicality of foundation in reality. But since this involves saftey I'll keep pointing out the obvious. So something is coming that will meet many of our needs much better than anything else, and especially for glider-glider collision threats will be absolutely better than anything else, but it is not here yet so instead of waiting we should use something that likely will meet very few needs? And still be relatively expensive. And there is unlikely to every be a business case for finishing/tailoring that product for the needs of the USA glider market. And how exactly do you solve the current STC installation requirement? Who will fund the development of the STC approval for installation in gliders? In past discussions with Bill Moffitt, President of NavWorx he seemed a pretty reasonable guy and his impression of PowerFLARM technology for the glider market seemed to me to be pretty positive. So that just confuses me, do NavWorx share you unbridled enthusiasm for pushing their current UAT products into glider applications? NavWorx's UAT receivers have an interesting potential market as FIS-B receivers and their transceivers have an interesting potential market as add-on ADS- B devices for aircraft owners who want to keep their Mode C transponder. I suspect they don't need the distraction of trying to develop products to meet the need of the tiny USA glider market. Darryl |
| Build your own PowerFLARM! | Darryl Ramm | Soaring | 51 | August 19th 10 07:39 PM |
| KDR-510 question (VDL Mode 2 receiver?) | Filip Zawadiak | Owning | 0 | June 30th 04 05:16 PM |
| KDR-510 question (VDL Mode 2 receiver?) | Filip Zawadiak | Piloting | 0 | June 30th 04 05:16 PM |
| KDR-510 question (VDL Mode 2 receiver?) | Filip Zawadiak | Products | 0 | June 30th 04 05:16 PM |
| Question on missing Mode-C | Ray Bengen | Owning | 10 | March 3rd 04 12:59 AM |
