I have a radio question. Glasair 1TD with Icom radio, older headset.
When the engine is running and charging 14.5 volts the radio howls when I transmit. Engine off, battery voltage, no noise. If I put a small screwdriver in the small hole in the headset and turn it down 1/2 turn, no noise. If I then take the headset and plug it in my old Cherokee, it won't transmit until I turn it back up. Are all headsets this voltage sensetive? Or just older ones? Is there a fix? thanks Ed |
In article
, et wrote: I have a radio question. Glasair 1TD with Icom radio, older headset. When the engine is running and charging 14.5 volts the radio howls when I transmit. Engine off, battery voltage, no noise. If I put a small screwdriver in the small hole in the headset and turn it down 1/2 turn, no noise. If I then take the headset and plug it in my old Cherokee, it won't transmit until I turn it back up. Are all headsets this voltage sensetive? Or just older ones? Is there a fix? thanks Ed You need a capacitor between the alternator o/p and ground, to suppress noise. All the aviation supply houses sell noise suppressors. |
On Nov 26, 9:18*am, Orval Fairbairn
wrote: In article , *et wrote: I have a radio question. * Glasair 1TD with Icom radio, older headset.. When the engine is running and charging 14.5 volts the radio howls when I transmit. * Engine off, battery voltage, no noise. * *If I put a small screwdriver in the small hole in the headset and turn it down 1/2 turn, no noise. * If I then take the headset and plug it in my old Cherokee, it won't transmit until I turn it back up. Are all headsets this voltage sensetive? * Or just older ones? *Is there a fix? thanks Ed You need a capacitor between the alternator o/p and ground, to suppress noise. All the aviation supply houses sell noise suppressors. It's not that kind of noise, it's a loud howl when I try to transmit, receives great. It will also howl after I shut down the engine, until the battery voltage drops a little, then it transmits great. Never does it when receiving. Ed |
On Fri, 26 Nov 2010 11:41:37 -0800 (PST), et
wrote: On Nov 26, 9:18Â*am, Orval Fairbairn wrote: In article , Â*et wrote: I have a radio question. Â* Glasair 1TD with Icom radio, older headset. When the engine is running and charging 14.5 volts the radio howls when I transmit. Â* Engine off, battery voltage, no noise. Â* Â*If I put a small screwdriver in the small hole in the headset and turn it down 1/2 turn, no noise. Â* If I then take the headset and plug it in my old Cherokee, it won't transmit until I turn it back up. Are all headsets this voltage sensetive? Â* Or just older ones? Â*Is there a fix? thanks Ed You need a capacitor between the alternator o/p and ground, to suppress noise. All the aviation supply houses sell noise suppressors. It's not that kind of noise, it's a loud howl when I try to transmit, receives great. It will also howl after I shut down the engine, until the battery voltage drops a little, then it transmits great. Never does it when receiving. Ed Lots of radios are sensitive to overvoltage. Try putting a diode or 2 in series with the power lead and see what happens. Most work just fine as low as 10.5 volts or so - so even a good voltage regulator (low dropout) could do the job - but I'd recommend a couple of silicon rectifier diodes - minimum 24 volt and 50% more than the rated current, better yet 50 volt and double the transmitter current. |
It could be the radio side tone feedback causing the noises. I had
noise in my radio(s) when transmitting so it was not alternator related. I adjusted the radio side tone to almost nil and now no more noises and perfect transmission. I know it's distracting not to hear yourself but it solved the problem. |
here is some tips for How to Reduce Radio Interference on a Headset
1- Insert the headset's audio plug into the audio output of an audio device. 2- Remove the battery cover on the back of the noise canceling device. Insert fresh batteries into the battery compartment and close the cover. 3- Insert one end of a mini-jack audio cable into the audio output of the audio device 4- Insert always fresh batteries into the battery compartments and close the covers. Last edited by Elvise : January 22nd 11 at 11:53 AM. |
| Thread Tools | |
| Display Modes | |
| Radio Noise | Bob | Home Built | 6 | January 11th 09 07:11 PM |
| wiring second radio and noise | flps_74 | Owning | 3 | November 4th 08 10:43 PM |
| radio noise | et | Home Built | 4 | September 30th 08 06:43 PM |
| Radio ignition noise. | [email protected] | Home Built | 6 | August 17th 07 06:15 PM |
| Radio ignition noise | [email protected] | Home Built | 0 | August 16th 07 04:46 PM |
