Vario pneumatics
Old December 19th 10, 12:38 PM posted to rec.aviation.soaring
Colin Roney
Default Vario pneumatics
Does anyone have a solution to the problem of having two `flask` varios
fitted with one total energy tube.
I understand, although I may be wrong, that having a tee piece split near
to the panel to provide the two t/e requirements is a `no no`.
Old December 19th 10, 01:39 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
near to the panel to provide the two t/e requirements is a `no no`.
There's an article on the Borgelt site about it:
http://www.borgeltinstruments.com
Select Articles from the menu bar and then Installation from the side
bar. Scroll down to 'Pneumatic' in the 'Good practise hints' section.
This is about 3/4 of the way down the page.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 19th 10, 03:12 PM posted to rec.aviation.soaring
Dan[_4_]
There is an article on TE compensation at http://www.schempp-hirth.com/index.php?id=108&L=1
that also makes recommendations; a good read.
Old December 19th 10, 04:03 PM posted to rec.aviation.soaring
Tim Mara
you will likely get some error in the instruments, most variometers with
capacity flasks are "calibrated leak" or thermister type variometers (heated
wire/air flow). Having more leaks in the system will have some effect on the
actual readings but this leak is rather small for most instruments..actually
pretty amazing that an instrument can read such small airflows and
temperatures to begin with and translate these to instrument indications
when you really think about it! Most sailplane instrument installations do
have small errors (some have large errors!) and the pilots don't even
recognize the errors.....many sailplane variometers are from the start
highly inaccurate..you can't always believe simply because the seller has a
great looking ad and touts all the fine features that the actual instrument
is producing the fine accuracy they might claim...pretty easy today with all
the electronics components for someone to take a collection of easily
available components and toss them in a box and produce something the
appears to be an aircraft instrument! Pilots may tend to see a needle go up
or down and either slow down and circle or speed up and run away...and the
indications are pretty much telling you that you've encountered a higher or
lower pressure and hence all works out....sort of ..
But that said, you can live with some small errors that cannot be completely
corrected.....or use different pneumatic systems to avoid connecting
calibrated leak systems..most newer variometers have adjustments to
compensate for minor errors and electronic TE variometers don't require
connection to TE but may be connected to pitot and static alone and adjusted
for higher accuracy.
If in fact you have one of the older electric variometers with a capacity
flask and a pneumatic variometer like a Winter or PZL then likely your
eclectic variometer is a very old and likely highly inaccurate instrument
now anyway. It's older for sure, no new electric variometers rely on this
technology anymore and so it may be due or overdue to replacement or at
least testing for it's own leaks and errors and even without the errors from
connection with another capacity instrument may never give you totally
accurate indications.
tim
"Colin Roney" wrote in message
__________ Information from ESET NOD32 Antivirus, version of virus
signature database 5715 (20101219) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5716 (20101219) __________
http://www.eset.com
Old December 19th 10, 04:34 PM posted to rec.aviation.soaring
Andy[_1_]
tim
Please visit the Wings & Wheels website atwww.wingsandwheels.com
*"Colin Roney" wrote in . ..
http://www.eset.com
http://www.eset.com
Don't give the electronic flow type varios too bad a rap. In my
opinion the Cambridge MNAV vario was very good. Of course the glide
computer became obsolete when GPS arrived on the scene.
Andy
Old December 19th 10, 05:00 PM posted to rec.aviation.soaring
The PDF version of the Borgelt installation article can be found at
http://www.borgeltinstruments.com/in...stallation.pdf
http://www.soaridaho.com/
"Martin Gregorie" wrote in message ...
org |
Old December 19th 10, 05:57 PM posted to rec.aviation.soaring
sisu1a
Short answer: Move the tee split under the seatpan to avoid crosstalk.
-p
Old December 20th 10, 05:32 PM posted to rec.aviation.soaring
Tim Mara
the M/Nav and even L/Nav and S/Nav were the last of even Cambridges use of
old thermister technology....they also switched to pressure transducers with
all later products
tim
"Andy" wrote in message
(heated
a
instrument
all
up
or
completely
adjusted
from
tim
near
http://www.eset.com
http://www.eset.com
Andy
database 5718 (20101220) __________
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5718 (20101220) __________
http://www.eset.com
NK Vario Bastoune Soaring 6 December 7th 10 02:18 AM
Pneumatics Question jsbrake[_2_] Soaring 24 June 7th 10 02:51 PM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
FS: LX-16 Vario [email protected] Soaring 4 February 6th 08 12:20 AM
WTB LD-200 Vario Romeo Delta Soaring 0 June 4th 04 03:08 PM
