How many landings will aircraft tires hold?
Old January 27th 11, 01:28 PM posted to rec.aviation.homebuilt
Oliver Arend
Default How many landings will aircraft tires hold?
I know the answer is "it depends", but let's say you are in a regular
light airplane (C152, C172 ...) with "real" aircraft tires and you do
normal landings without excessive load, speed or crosswind. It will
still depend on the surface of the runway, but generally, is the
number more on the order of 10s of landings (change rather often),
100s of landings (maybe get through one busy flying season with one
set) or 1000s of landings (last forever until aging kicks in)?
Oliver
Old January 27th 11, 04:04 PM posted to rec.aviation.homebuilt
Ron Wanttaja[_2_]
For my Fly Baby, I'd put the answer at roughly 500-750 landings. I
typically fly for an hour or less, and usually shoot several touch and
goes on each flight. The last set I replaced lasted 200 hours, and they
were used when I got them.
Old January 28th 11, 03:50 AM posted to rec.aviation.homebuilt
Brian Whatcott
Oliver
In the South West, an average owner might need to change a tire or two
less often than 5 or 7 years, except the ozone/UV gets to cracking them
and then its time for more retreads.
Brian W
Old February 21st 11, 03:36 AM posted to rec.aviation.homebuilt
Oliver
It's not the landings that kill tires. It's the braking forces. Pilots
who land long and/or fast will use a lot of brake to try to stop the
airplane, and braking scrubs rubber off real quick even if the tire
isn't "skidding."
Dan
Old February 24th 11, 02:34 AM posted to rec.aviation.homebuilt
On Feb 20, 7:38*pm, Alan Baker wrote:
In article
isn't "skidding."
Dan
Ummmmm.... ...where did you learn this?
I am the Director of Aircraft Maintenance for a flight school. Eight
airplanes. I was also a flight instructor for some time and still hold
a Commercial ticket. When we start teaching short-field landings, the
tires suffer. Ordinary circuit work isn't nearly hard on them unless
the landings are crabbed. 38 years around airplanes teaches one some
things, I would think.
A retired airline pilot told me the same thing: The tires on the big
birds suffer more from braking than the touchdown.
Dan
Old February 24th 11, 05:48 PM posted to rec.aviation.homebuilt
Harry K
Oliver
I often wondered how often the big planes change. I worked in a
faciltiy building agricultural fertilizer applicators (up to 90' wide)
that used what we called "bomber tires". Huge things taken off planes
that I had to trim the tapered bead to a flat one to fit our wheels.
Did hundreds of them. They showed hardly any wear at all.
Harry K
Old February 24th 11, 11:28 PM posted to rec.aviation.homebuilt
Dan[_12_]
Oliver
Harry K
I don't know about commercial, but USAF used to change tires when
wear reached a certain point dictated by mission requirements and
location. If an aircraft was being flown to home station, depot or the
bone yard they's be authorized a one time flight on red threads. Many
times we changed tires that had plenty of life left. I retired in 1994
and things may have changed since then.
Dan, U.S. Air Force, retired
Old March 1st 11, 12:20 AM posted to rec.aviation.homebuilt
RST Engineering[_2_]
If you are operating from a grass strip, the tires will outlast the
airframe.
Clearance on hold, hold for release Hap[_2_] Piloting 17 June 28th 09 02:46 AM
Carrier Aircraft Catapault Hold-Back Bar / Mechanism ? Robert11 Naval Aviation 8 June 24th 06 06:40 PM
Slick aircraft tires Paul Lee Home Built 7 September 11th 04 07:01 AM
Changing *BIG* Aircraft Tires [Was Coalition casualties forseptember] Stephen Harding Military Aviation 9 October 5th 03 07:42 PM
Re unusual landings on Aircraft Carriers Jim Atkins Military Aviation 4 July 15th 03 11:54 PM
