Sailplane data
Old February 8th 11, 09:44 AM
JJ21 JJ21 is offline
Junior Member
First recorded activity by AviationBanter: Feb 2011
Default Sailplane data
Hi all,
I'm currently doing a project on gliders designed within the last ten years and one of the crucial aspects is knowing the mean camber profile for various lift coefficient calculations. I was wondering whether
a) Any modern gliders are using NACA type airfoils?
b) Whether anyone knows what the parabolic equation of the ASG-29 profile?
Any other suggestions would be greatly appreciated!
Thanks
Old February 8th 11, 02:25 PM posted to rec.aviation.soaring
Andreas Maurer
On Tue, 8 Feb 2011 09:44:45 +0000, JJ21
Nope... I'd estimate since at least 50 years...
profile?
If you men the parabolic equation that defines the camber and
thickness distribution of NACA airfoil:
Laminar airfoils that are used on gliders don't use parabolic
equations - their shape is defined by calculating the shape based upon
pressure distribution.
Regards
Andreas
Old February 8th 11, 02:44 PM posted to rec.aviation.soaring
Grider Pirate
On Feb 8, 1:44*am, JJ21 wrote:
Hi all,
profile?
Thanks
JJ21
http://www.sailplanedirectory.com lists the airfoil used for SOME
gliders.
Some of those airfoil sections can be found he
http://www.ae.illinois.edu/m-selig/a..._database.html
Old February 8th 11, 04:03 PM posted to rec.aviation.soaring
jsbrake[_2_]
By "parabolic equation", perhaps the OP means the polar calculation
points? Parabolic is synonymous with quadratic, which is what we use
to approximate our polars for the computers.
Old February 8th 11, 04:07 PM posted to rec.aviation.soaring
On Feb 8, 4:44*am, JJ21 wrote:
Hi all,
profile?
Thanks
JJ21
Airfoil is DU89-134/14. Coordinates are not available to my knowledge.
I'd like to be proven wrong on that.
UH
Old February 9th 11, 07:34 PM
Junior Member
Pretty much looking for a quadratic which can be used to calculate the lift coefficient theoretically using Fourier coefficients.
I can't really think of any other way of calculating the lift coefficient of an airfoil theoretically.
Old February 10th 11, 12:28 AM posted to rec.aviation.soaring
Francisco De Almeida[_2_]
A lot of good people have found more straightforward ways to compute the
lift coefficient, which is in fact very easy to calculate. The maximum
lift coefficient, the drag coefficient, the pitching moment coefficient
are the hard ones.
Perhaps you could consult a standard textbook on glider aerodynamics, e.g.
Prof. Fred Thomas "Handbook of Sailplane Design".
Old February 10th 11, 10:47 AM posted to rec.aviation.soaring
Doug Greenwell
are the hard ones.
e.g.
If you have the aerofoil profile, then Xfoil (freeware from a very
respected aerodynamicist) will give you a reasonable 1st guess at all of
these for 2D flow. XFLR5 extends Xfoil to 3D wings (originally intended
for RC gliders, but should probably* be OK for full-scale sailplanes).
Using Fourier coefficients to calculate 2D (or 3D wing) characteristics,
is a real throw-back to the 50's - useful in a textbook derivation to
give an analytical solution, but no-one does it any more.
Doug
*usual caveats apply - these are not guaranteed to give the right answer,
so use with caution!
Best Looking Sailplane glider[_2_] Soaring 52 November 23rd 09 04:29 PM
Could this be used in a sailplane? Spam Soaring 6 July 5th 09 08:16 PM
Another Sailplane Ben Jeffrey Aviation Photos 2 June 24th 08 08:11 PM
Digital airspace data question -- any FAA data gurus out there? Tuno Piloting 2 December 27th 07 05:06 PM
Flight Data recorders on a 757 - What data? Al Dykes General Aviation 0 January 1st 07 05:09 PM
