Can anyone help with references for glide ratios for basic training gliders, Blanik, K13, Puchatek etc, with full brake or half brake deployed?
The internet is not very helpful for finding this information. A reference of 29 to 1 for a K6 -no brake and 7.1 full brake is about all I can find. Given a Blanik at, say 28 to 1 no brake deployed, would around 8 to 1 full brake and say around 15 to one half brake sound about right? Thanks in advance. |
On 2/14/2011 1:15 PM, Ronald Locke wrote:
Can anyone help with references for glide ratios for basic training gliders, Blanik, K13, Puchatek etc, with full brake or half brake deployed? The internet is not very helpful for finding this information. A reference of 29 to 1 for a K6 -no brake and 7.1 full brake is about all I can find. Given a Blanik at, say 28 to 1 no brake deployed, would around 8 to 1 full brake and say around 15 to one half brake sound about right? I have say, it makes curious: for what purpose do you want the data? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Feb 14, 1:15*pm, Ronald Locke Ronald.Locke.
wrote: Given a Blanik at, say 28 to 1 no brake deployed, would around 8 to 1 full brake and say around 15 to one half brake sound about right? Thanks in advance. Ronald Locke If they're terminal velocity brakes then 0:1 (straight down) is possible without exceeding Vne. Form drag is highly speed-dependent so speed affects the answer a lot. The size of the brakes also matters so it is unlikely you will get a consistent number across multiple types. You'd also need to define "half brake" - halfway out, half the additional drag, half the difference in glide angle, one brake in and one out? Given all the variables I suspect it's possible to fly a Blanik to achieve the glide angles you describe. The tricky calculation would be to estimate the best L ![]() figure out the circumstances under which someone would try to achieve best L ![]() 9B |
![]() Quote:
On Feb 15, 12:27*am, Andy wrote:
I'm trying to figure out the circumstances under which someone would try to achieve best L ![]() Well I know of one case for an L13. The pilot didn't realize the brakes were open so closing them was never on the list of things to try. (No it wasn't me). Agree that the OP needs to better define what data is needed, but it still may not be available. Somewhere in my logs I have data for max achieved sink rates for the ASW-19 and ASW-28. I did tests with full brakes and with full brakes and full rudder slips. It's amazing how quick you can get a glider to come down if you really want to. I found the feeling of hanging on the brakes at 80kts to be quite uncomfortable though and never tried speeds much higher than that. What is more useful to know is how to get the max descent angle while still maintaining minimum safe approach speed. For the 19 and 28, full brakes and full rudder slip is very effective. Try it at altitude first to get used to controlling speed with only pitch attitude as the indicated airspeed may be zero. Andy |
On Feb 15, 10:15*am, Ronald Locke Ronald.Locke.
wrote: Can anyone help with references for glide ratios for basic training gliders, Blanik, K13, Puchatek etc, with full brake or half brake deployed? The internet is not very helpful for finding this information. A reference of 29 to 1 for a K6 -no brake and 7.1 full brake is about all I can find. Given a Blanik at, say 28 to 1 no brake deployed, would around 8 to 1 full brake and say around 15 to one half brake sound about right? I believe there is a legal requirement to be no flatter than 7:1 with full brake at typical approach speed. At one time there was a requirement to be able to do a 45º descent without exceeding Vne (or was it rough air?) The Blanik is much older than the requirement, but would easily meet it. I recall when I was a beginning pilot one instructor had me do a near vertical descent in the Blanik from around 8000 ft. If I recall correctly, it topped out at about 115 knots (well below Vne). That's a 0:1 glide angle. There's also the question of flaps. We practiced landing approaches with full brake and full flap at maximum flap speed (60 knots IIRC). They were really quite steep, perhaps around 2:1 (30º) or even more. When you leveled out the speed washed off quickly so it was actually quite practical. |
At 09:41 15 February 2011, Ronald Locke wrote:
'Andy[_10_ Wrote: ;762804']On Feb 14, 1:15*pm, Ronald Locke Ronald.Locke. wrote: - Given a Blanik at, say 28 to 1 no brake deployed, would around 8 to 1 full brake and say around 15 to one half brake sound about right? Thanks in advance. Ronald Locke- If they're terminal velocity brakes then 0:1 (straight down) is possible without exceeding Vne. Form drag is highly speed-dependent so speed affects the answer a lot. The size of the brakes also matters so it is unlikely you will get a consistent number across multiple types. You'd also need to define "half brake" - halfway out, half the additional drag, half the difference in glide angle, one brake in and one out? Given all the variables I suspect it's possible to fly a Blanik to achieve the glide angles you describe. The tricky calculation would be to estimate the best L ![]() figure out the circumstances under which someone would try to achieve best L ![]() 9B My query is simply related to the different approach angles on final glide to the aiming point during final approach for landing. Obviously different gliders will have different glide ratios for full brake and half brake approaches. Hope this explanation clears up any misunderstanding. -- Ronald Locke So do you want to teach gliding by numbers?? Using airbrakes on finals involves a feedback loop - Aiming point going up the view? Close the brakes a bit. Aiming point disappearing under the nose? open the brakes some more. It isn't rocket science, nor can you define how open or closed the brakes need to be at a specific point. |
speed affects the answer a lot. The Pegasus flight manual claims a glide angle of 5 with the airbrakes fully extended and an indicated speed of 49 knots. Given the history of the Pegasus design the ASW19 is probably fairly similar. [90 km/h = 49 knots is the minimum approach speed - personally I add a few!] |
James Thomson wrote:
Form drag is highly speed-dependent so speed affects the answer a lot. The Pegasus flight manual claims a glide angle of 5 with the airbrakes fully extended and an indicated speed of 49 knots. Given the history of the Pegasus design the ASW19 is probably fairly similar. The Pegasus flight behavior could not be more different (and far better) than the ASW19. [90 km/h = 49 knots is the minimum approach speed - personally I add a few!] -- Michel TALON |
Full-span flaperons as airbrakes? | Bret | Soaring | 21 | March 20th 10 10:39 PM |
Spoilers or Airbrakes - Whats in a name? | ContestID67 | Soaring | 29 | May 20th 08 05:21 PM |
Angles | Maple1 | Aviation Photos | 2 | August 22nd 07 07:16 PM |
Airbrakes Pop Out at 115 kts | ContestID67 | Soaring | 13 | May 10th 05 01:50 PM |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
