SGS 1-34 Seat:
Old February 22nd 11, 05:49 AM posted to rec.aviation.soaring
BruceGreeff
Default SGS 1-34 Seat:
I fitted two, 1" thick, pieces of confor to my parachute. Basically it
is one continuous length from the back of my thigh to the shoulders.
Converts parachute from a lumpy instrument of torture to a slightly
tight armchair...
On 2011/02/22 5:03 AM, Bastoune wrote:
I have a "long" type of parachute. Where does the space foam go?
Between me and the chute or between the chute and the fiberglass seat
pan?
Thanks for the clarification.
Bruce Greeff
T59D #1771 & Std Cirrus #57
Old February 22nd 11, 12:26 PM posted to rec.aviation.soaring
pan?
You want spaceman foam against you. To fill in all the small
imperfections...
Cookie
Old February 23rd 11, 11:23 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
I flew the 1-34 today and with a few adjustments felt comfy for an hour. Would like to have stayed up longer but I was trying to be nice and bring it in for someone else to have a go at it. I did elevate the front of the seat pan a bit, will need to move it up a bit more. I moved the seat back one more notch back and with a foam sleeping bag pad and the seat cushion I was okay. I took the lumbar pad out of my chute, this seemed to make things worse last time. I will probably put a bit more padding in the lumbar area of the seat but the parachute part only made it worse. I am confident that I can get the seat adjusted for a 5 hours flight.
Walt
Old February 24th 11, 12:13 PM posted to rec.aviation.soaring
On Feb 23, 6:23*pm, Walt Connelly Walt.Connelly.
bring it in for someone else to have a go at it. *I did elevate the
front of the seat pan a bit, will need to move it up a bit more. *I
and the seat cushion I was okay. *I took the lumbar pad out of my chute,
this seemed to make things worse last time. *I will probably put a bit
made it worse. *I am confident that I can get the seat adjusted for a 5
hours flight.
Walt
Walt Connelly
Keep working on it Walt.....you can see the difference.....that
leading edge has to come way up, as far as possible short of ruining
something. I have seen some guys fabricate wedge shaped leg pads out
of semi ridgid foam to support the back of the thighs...........I
think at least a little lumbar is good too. I like a big lumbar
support, but some guys like just a bit.
Cookie
Right Seat Learning [email protected] Piloting 18 February 26th 08 02:17 AM
Want To Buy - 2-33 seat belts Sam Discusflyer Soaring 4 December 4th 07 09:12 PM
Bax Seat :was A serious proposal Michael Ware Piloting 16 November 28th 05 10:51 PM
Last Bax Seat Doug Vetter Piloting 6 August 23rd 05 01:34 PM
Pitts Seat Mod Martin Morgan Aerobatics 0 November 21st 03 03:56 AM
