looking for west coast painter
Old April 4th 11, 08:26 PM posted to rec.aviation.soaring
Brad[_2_]
Default looking for west coast painter
I'm pretty sure I am going to have my HP-24 professionally painted.
Can anyone recommend a place within a 500 mile radius of the greater
Seattle area that has experience with Prestec?
thanks,
Brad
Old April 4th 11, 10:15 PM posted to rec.aviation.soaring
Tim Taylor
thanks,
Brad
Why damage a perfectly good glider with Prestec? If the molds were
good and smooth, shoot it with a good 2K polyurethane system. It will
last longer, look better, and add less weight.
Old April 5th 11, 04:11 AM posted to rec.aviation.soaring
Frank Whiteley
thanks,
Brad
Why damage a perfectly good glider with Prestec? *If the molds were
good and smooth, shoot it with a good 2K polyurethane system. *It will
I would imagine there are a number of good shops in the Seattle area.
I would ask about PU shooters on rec.aviation.homebuilt
Frank Whiteley
Old April 5th 11, 05:17 AM posted to rec.aviation.soaring
Frank Whiteley
thanks,
Brad
Frank Whiteley
PU with Teflon, now that's slick. Hadn't heard of that.
Frank
Old April 5th 11, 05:33 AM posted to rec.aviation.soaring
Frank Whiteley
thanks,
Brad
Frank Whiteley
This kind of thread
http://groups.google.com/group/rec.a...b32167f0fe3cff
Old April 6th 11, 07:52 PM posted to rec.aviation.soaring
thanks,
Brad
Given that this will be the first flying prototype, and may well
require some "refinements" as it develops, Prestec finish would likely
be a very appropriate decision.
It's worth noting that the proper prep for painting is much more work
to get surface quality required than that required for polyester
topcoat.
I've done both.
Another voice heard from
UH
Old April 7th 11, 02:32 AM posted to rec.aviation.soaring
Brad[_2_]
thanks,
Brad
topcoat.
I've done both.
UH
Thanks UH.....................I also have Prestec on hand and want to
use it.
I think the blister problem with my Apis, which we painted with
Prestec about 7 years ago is due to having never been
waxed.............yeah, lazy me, now when I open the trailer during
the wet months it's got lots of little blisters, and after flying on a
typical damp spring day looks even worse.
I plan on not letting that happen with the new ship.
Brad
Old April 7th 11, 03:09 PM posted to rec.aviation.soaring
T8
thanks,
Brad
topcoat.
I've done both.
UH
use it.
Brad
I've seen that problem in PU paint. As you describe, they grew and
shrank with humidity. In that case it was clearly contamination
between primer and top coat.
Given typical thickness of polyester top coat, this seems really
weird. I'd have said this wasn't possible, or at least *very*
unlikely.
-Evan Ludeman / T8
Old April 7th 11, 04:00 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
thanks,
Brad
topcoat.
I've done both.
UH
use it.
Brad
I've seen that problem in PU paint. *As you describe, they grew and
shrank with humidity. *In that case it was clearly contamination
weird. *I'd have said this wasn't possible, or at least *very*
unlikely.
-Evan Ludeman / T8- Hide quoted text -
- Show quoted text -
I don't know the cause, but I have seen little blisters form on both
PU and gelcoat when left in a damp trailer. The only way I know to
prevent this problem is to air out the trailer at least once a month
or store the ship and trailer indoors.
JJ
JJ
Old April 7th 11, 07:00 PM posted to rec.aviation.soaring
thanks,
Brad
topcoat.
I've done both.
UH
use it.
Brad
unlikely.
JJ
JJ- Hide quoted text -
This agrees with my experience also.
Usually blisters are where moisture is trapped for a long time.
UH
USS Liberty survivor Phil Tourney to be on Radio Liberty programtoday at 4 PM on the west coast and at 7 PM on the east coast NOMOREWARFORISRAEL[_2_] Naval Aviation 0 September 26th 08 11:24 PM
West coast soaring - where and when? Uros Soaring 14 February 24th 08 01:37 AM
D.C. anti-war rally on C-SPAN today at 8:15 AM on the west coast of US and at 11:15 AM on east coast - President Carter at Brandeis on C-SPAN 2's 'Book TV' today at 12:30 PM (on the west coast and at 3:30 PM on the east coast): [email protected] Naval Aviation 0 January 27th 07 02:18 PM
What causes summer fog along west coast? Andrew Sarangan Piloting 5 July 7th 04 12:48 AM
recommend a good aircraft painter/shop on the NE or East coast Baron Man Owning 8 January 15th 04 05:24 PM
