On Apr 5, 9:26*am, T8 wrote:
Much ado about nothing. I use a digital totalizer called a "bucket". *It has better accuracy, it's faster, doesn't require batteries, can be replaced at any hardware store. To use: Fill glider full, place totalizer under dump port, empty as needed to get to desired gross weight. *Quantitative easing, for gliders. Doubles as a wash bucket. -Evan Ludeman / T8 Doesn't work under an LS6 which dumps under the belly. Wastes water, too. I hook up a digital flow meter to my standpipe and only use as much water as I need. Kirk 66 |
On Apr 6, 5:24*pm, "kirk.stant" wrote:
On Apr 5, 9:26*am, T8 wrote: Much ado about nothing. I use a digital totalizer called a "bucket". *It has better accuracy, it's faster, doesn't require batteries, can be replaced at any hardware store. To use: Fill glider full, place totalizer under dump port, empty as needed to get to desired gross weight. *Quantitative easing, for gliders. Doubles as a wash bucket. -Evan Ludeman / T8 Doesn't work under an LS6 which dumps under the belly. Wastes water, too. I hook up a digital flow meter to my standpipe and only use as much water as I need. Kirk 66 My 20B dumps from the belly and it works fine. Of course, I have Schleicher landing gear. Not knocking the 6, I tried to buy one about a month before I found the 20. Lovely ship. But it's a little skimpy on the landing gear and ground clearance. Point taken for those who fly on planet Arrakis. Here in the Eastern bogs, we generally bitch about too much water rather than too little, a nuisance, not a scarce resource. Good on you desert guys for being responsible citizens. -Evan Ludeman / T8 |
Source for Metric/liters water meter? | John Bojack[_2_] | Soaring | 6 | May 1st 09 04:22 PM |
UV meter at very good price | Eric Greenwell | Soaring | 0 | January 16th 07 10:37 PM |
digital air-speed meter can be used in car? | [email protected] | Home Built | 17 | May 30th 06 02:42 AM |
Water Meter in Liters | Mal | Soaring | 2 | October 26th 05 05:44 AM |
Water Meter in Litres | Mal | Soaring | 9 | September 24th 05 07:45 PM |
