Didn't the US Navy use Skyraiders (AD-2s or -4s, I believe) to successfully torpedo a dam in North Korea during that war? those rice-paper torpedo nets were surprisingly effective during testing, but failed miserably in operational use. Guess the NKs didn't read RAM... They get their info from Channel Only One; "All the news you'll ever get to hear". v/r Gordon ====(A+C==== USN SAR Donate your memories - write a note on the back and send your old photos to a reputable museum, don't take them with you when you're gone. |
Kirk Stant wrote:
nt (Krztalizer) wrote in message ... Torpedos were thought of first, by both sides. So, the Jerries rigged effective anti-torpedo nets in front of their dams, rendering the torpedo threat moot. Enter Barnes Wallace.... Didn't the US Navy use Skyraiders (AD-2s or -4s, I believe) to successfully torpedo a dam in North Korea during that war? Yep. Here's a photograph: http://www.history.navy.mil/photos/i...00/g428678.jpg Apparently they blew off one floodgate and damaged another. The dam, however, remained intact. -Marc -- Marc Reeve actual email address after removal of 4s & spaces is c4m4r4a4m4a4n a4t c4r4u4z4i4o d4o4t c4o4m |
If you watch the 1953? film it pretty much explains the reasoning behind the
bomb, the torpedo nets plus they needed a minimum of 5000lb of high explosives to have a chance of breaching the dams. In an interview given by Wallace he stated that his famous 10 & 5 ton "Grandslam" an Tallboy bombs were originally considered but would only work with a direct hit, any sort of near miss would do no damge because of the water cushioning effect. Interestingly the scale model dam used by wallace complete with test blast damage still exists in the Grounds of the UK Building Research Establishment in Hertfordshire just out side Watford in the UK. Myc |
Mycroft wrote:
If you watch the 1953? film it pretty much explains the reasoning behind the bomb, the torpedo nets plus they needed a minimum of 5000lb of high explosives to have a chance of breaching the dams. In an interview given by Wallace he stated that his famous 10 & 5 ton "Grandslam" an Tallboy bombs were originally considered but would only work with a direct hit, any sort of near miss would do no damge because of the water cushioning effect. Interestingly the scale model dam used by wallace complete with test blast damage still exists in the Grounds of the UK Building Research Establishment in Hertfordshire just out side Watford in the UK. Myc Just a nitpick....... It's Barnes Wallis - Wallace was the guy played by Mel Gibson in Braveheart !!!!!! ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++ Ken Duffey - Flanker Freak & Russian Aviation Enthusiast Flankers Website - http://www.flankers.co.uk/ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++ |
Oooooohhhhh eeeeeererrr, I ave treblle tribble wid my Wallllllllacccceess
Whoops Wallis's. Myc "Ken Duffey" wrote in message ... Mycroft wrote: If you watch the 1953? film it pretty much explains the reasoning behind the bomb, the torpedo nets plus they needed a minimum of 5000lb of high explosives to have a chance of breaching the dams. In an interview given by Wallace he stated that his famous 10 & 5 ton "Grandslam" an Tallboy bombs were originally considered but would only work with a direct hit, any sort of near miss would do no damge because of the water cushioning effect. Interestingly the scale model dam used by wallace complete with test blast damage still exists in the Grounds of the UK Building Research Establishment in Hertfordshire just out side Watford in the UK. Myc Just a nitpick....... It's Barnes Wallis - Wallace was the guy played by Mel Gibson in Braveheart !!!!!! ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++ Ken Duffey - Flanker Freak & Russian Aviation Enthusiast Flankers Website - http://www.flankers.co.uk/ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++ |
"Mycroft" wrote in message ... If you watch the 1953? film it pretty much explains the reasoning behind the bomb, the torpedo nets plus they needed a minimum of 5000lb of high explosives to have a chance of breaching the dams. In an interview given by Wallace he stated that his famous 10 & 5 ton "Grandslam" an Tallboy bombs were originally considered but would only work with a direct hit, any sort of near miss would do no damge because of the water cushioning effect. IIRC, the Paul Brickhill book mentions the 12,000 lb Tallboy being used against the dam at Kembs in Germany; afraid that the sluice gates would be opened and flood the area of the Allied advance, the powers that be despatched 617 Sqn to drain the reservoir first. The bombs were dropped from low level with delayed fuses and succeeded in destroying the sluice gates, for the loss of two aircraft. Jon. |
Just a nitpick....... It's Barnes Wallis - Wallace was the guy played by Mel Gibson in Braveheart !!!!!! I remember that one - his dog was named Gromit, right? ) |
"Emmanuel Gustin" wrote in message ...
"Hamisha3" wrote in message ... Not to take anything away from BarnesWallis but why does a simple torpedo not do the same as the boune bomb, detonate against the dam wall at a pre set depth? I was just reading 'Bombs Gone', an interesting history of British bombs. Chapter 7 (well, I had not reached that) is devoted to the dam-busting bomb, as well as appendices 4 and 5. Gravity dams are very hard to destroy because a small crack will be closed by the water pressure, instead of opened. A large hole must be made. Trials on miniature dams and on a disused dam in Wales indicated that it would take 6,500 pounds of HE exploding in direct contact, of 30,000 pounds exploding at a distance of 50 ft. The replacement of Amatol by Torpex HE later allowed the bomb to be smaller. Still, this was much more than a torpedo could contain: The Mk.XII torpedo contained 545 lb of Torpex, about 1/10 of what was required. The RAF never bothered to properly document a bomb that was modified almost every other day and was used only once, so the best documents are apparently of German origin, descriptions of an unexploded example recovered from Fl.Lt Barlow's aircraft. 'Upkeep' weighed around 3900 kg and contained 2600kg of Torpex, had three water pressure fuses and a time fuse. Backspun at around 500 rpm and dropped 400 to 500 yards from its targt, it bounced four or five times before it hit the dams and sunk against it. One of the side effects of the Dam busters on German FLAK was the instigation of a 5.5cm FLAK cannon that could with one hit bring down a heavy bomber and opperate effectively from short range to medium altitudes with high accuracy and rate of fire. The weapon was to be servo driven and automatically pointed by computer. It had a high rate of fire and low recoil be the action of firing of the cannon while the barrel was still returning to its home position: thus the subsequent recoil would have to arrest the forward motion of the gun as well as overcome the recoil shock. It was nearin completion or entering production as the war ended. |
