Commercial Glider Rating
Old August 13th 11, 01:50 AM
drumflyer drumflyer is offline
Junior Member
First recorded activity by AviationBanter: Aug 2011
Default Commercial Glider Rating
Hi everyone, I'm currently a sport pilot with no other licenses and used to fly gliders a little as a kid when I was stationed in England. I've been thinking of getting my glider rating but had a question about the commercial glider rating. The SSA states:
Commercial Pilots-Glider must be at least 18-years of age, pass a written FAA examination, hold a Private Pilot license with 25 hours of flight time in gliders and 100 glider flights as pilot-in-command, or a total of 200 hours of flight time in heavier-than-air aircraft including 20 glider flights as pilot-in-command, 3 hours or ten flights training in a glider, and five solo flights in a glider and pass a flight test.
Does that mean that one must have a medical? What confuses me is that everywhere else it says Private Pilot-Glider. Am I looking to much into this and they just say private pilot license as a catch all for the different add-ons? The way I've interpreted it is that you do not need a medical to fly as a commercial glider pilot, however sometimes you seem to need to read between the lines when it comes to the FAA. If someone could give me some insight that would be great...or a simple yes or no will suffice
Thanks!
-Matt
Old August 13th 11, 03:28 AM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Thanks!
-Matt
I did a commercial glider add on to a commercial power license and I have no medical. One is not required for any glider rating including instructor. We self certify that we are ready to fly.
Walt
Old August 13th 11, 03:45 AM posted to rec.aviation.soaring
T[_2_]
On Aug 12, 4:50*pm, drumflyer
to fly gliders a little as a kid when I was stationed in England. *I've
commercial glider rating. *The SSA states:
written FAA examination, hold a *Private Pilot license* with 25 hours of
Does that mean that one must have a medical? *What confuses me is that
everywhere else it says Private Pilot-*Glider*. *Am I looking to much
different add-ons? *The way I've interpreted it is that you do not need
seem to need to read between the lines when it comes to the FAA. *If
or no will suffice
Thanks!
-Matt
drumflyer
I presume you have a Sport Pilot, Airplane rating.
You cannot go direct from sport pilot airplane to commercial glider,
unless yo have the prescribe hours in heavier than air, or light sport
aircraft. Complete a commercial glider written exam and complete a
glider practical exam check ride.
If you do not have the required power hours, you will need to complete
a private glider check ride first, accrue the required glider
experience for commercial, and the complete the required commercial
glider certificate requirements.
T
Old August 13th 11, 04:46 AM posted to rec.aviation.soaring
T[_2_]
or no will suffice
Thanks!
-Matt
drumflyer
T
Sorry, I should have added, you do not need a medical in the US.
T
Old August 13th 11, 03:12 PM
Junior Member
or no will suffice
Thanks!
-Matt
drumflyer
T
T
Yes, it is Sport Pilot-Airplane...here I am talking about specific wording and I wasn't even clear myself. Thanks for your replies I appreciate it!
-Matt
Old August 14th 11, 01:44 AM posted to rec.aviation.soaring
T[_2_]
On Aug 13, 6:12*am, drumflyer
'T[_2_ Wrote:
;780159']On Aug 12, 6:45*pm, T wrote:-
used
*I've
commercial glider rating. *The SSA states:-
of
a
including
training
test.-
that
need
yes
or no will suffice
Thanks!
-Matt-
drumflyer-
T-
T
wording and I wasn't even clear myself. *Thanks for your replies I
appreciate it!
-Matt
drumflyer
I just reread 61.123(h), it does say you must hold must have at least
a private pilot certificate. Does not specify in which aircraft. You
may have to complete a private glider certificate before you can
complete the commercial rating.
T
Old August 14th 11, 02:17 AM posted to rec.aviation.soaring
S. Murry
Unless you have military flight time, you will need to obtain a Private
Pilot's certificate before getting your commercial. This PP certificate
can be in any category and class. For example, you could get a private
ASEL, then go to commercial glider. But you must have a private pilot's
license in SOME category before getting the commercial-glider.
In order to obtain the PP certificate, you MAY need a medical (depending
on the requirements for the category for which you intend to get the PP
certificate). However, a medical is NOT required for glider category
ratings, so if you decide to get your private-glider, then
commercial-glider, you will not need a medical.
--Stefan Murry
CFI-G
On Sat, 13 Aug 2011 18:44:30 -0500, T wrote:
On Aug 13, 6:12 am, drumflyer
used
*I've
of
a
including
training
test.-
that
need
yes
or no will suffice
Thanks!
-Matt-
drumflyer-
T-
T
appreciate it!
-Matt
drumflyer
T
Stefan Murry
Old August 14th 11, 02:56 PM posted to rec.aviation.soaring
Cookie
On Aug 13, 8:17*pm, "S. Murry" wrote:
Unless you have military flight time, you will need to obtain a Private *
Pilot's certificate before getting your commercial. *This PP certificate *
can be in any category and class. *For example, you could get a private *
ASEL, then go to commercial glider. *But you must have a private pilot's *
In order to obtain the PP certificate, you MAY need a medical (depending *
on the requirements for the category for which you intend to get the PP *
certificate). *However, a medical is NOT required for glider category *
ratings, so if you decide to get your private-glider, then *
--Stefan Murry
CFI-G
used
*I've
of
a
including
training
test.-
that
need
yes
or no will suffice
Thanks!
-Matt-
drumflyer-
T-
T
appreciate it!
-Matt
drumflyer
T
Stefan Murry- Hide quoted text -
- Show quoted text -
It is possible to get a private glider certificate, and then later the
same day, the commercial glider certificate, if you pass the
tests.........I don't know if any instructors would give the sign offs
for that, or if any examiners would do the two tests...
Cookie
Old August 15th 11, 06:06 AM posted to rec.aviation.soaring
Mike Schumann
--Stefan Murry
CFI-G
used
*I've
of
a
including
training
test.-
that
need
yes
or no will suffice
Thanks!
-Matt-
drumflyer-
T-
T
appreciate it!
-Matt
drumflyer
T
Just because you have a Private Pilot Power license does not
automatically mean that you need a medical. A pilot with a Private SEL
license can fly a light sport aircraft without a medical.
Mike Schumann
Old August 16th 11, 12:48 AM posted to rec.aviation.soaring
Tony V
Yes, *if* you did not fail your last medical.
Tony V.
Commercial Rating Question Dane Spearing Instrument Flight Rules 16 July 5th 06 05:52 PM
Commercial rating? Paul Tomblin Piloting 43 March 10th 06 01:19 AM
Commercial Rating Question Will Piloting 0 December 5th 05 01:21 AM
Commercial rating: Am I wrong here? gatt Piloting 12 November 21st 05 01:35 AM
rotorcraft commercial rating or better rating advice Rick Cook Rotorcraft 0 October 13th 03 05:49 PM
