Low pass
Old August 28th 11, 05:19 AM posted to rec.aviation.soaring
Bruce Hoult
Default Low pass
On Aug 28, 1:13*am, JJ Sinclair wrote:
On Aug 26, 6:01*pm, Bruce Hoult wrote:
On Aug 27, 9:15*am, Mike Schumann
There's a big difference between doing these kinds of maneuvers at a
private strip where you aren't going to kill anyone but yourself, vs.
doing them at a public airport where there's lots of other traffic you
may or not know about who aren't particularly appreciative of having
someone hotdogging in the pattern.
Missed approaches are a standard thing that is practiced by power
pilots all the time. It is true that glider low passes are a bit
faster followed by a steeper climb than Cessna missed approaches, but
they're a very similar speed and climb angle to 737 ones.
So It all just depends on how mixed your traffic is.
I learned to fly Tomahawks at Wellington International (110,000
movements/year), where most of the traffic was in fact 737's,
WhisperJets, A320s plus the odd 747SP/767/777 depending on exactly
which year you're talking about. But there aren't gliders there.
At our actual glider field there is a lot of light aircraft and
helicopter training, plus small turboprops (e.g. Cessna Caravan), plus
a Q300 ("Dash 8") service starting in October.
If you're flying somewhere that's only got single-engine 1950's spam
cans from Wichita or Vero Beach flying around fat dumb and happy then,
yeah, gliders could exceed their expectations.
Bruce,
Would you do a low pass if you knew there was an FAA inspector on the
field? Then try your "missed approach" tale on him?
I certainly can't see any reason why not, if it is conducted as a
practice final glide and intentions are announced on the radio at the
standard 10km and/or 5 km out.
At our club airfield (NZPP) we often had the deputy director of the
Civil Aviation Authority (NZ's equiv of your FAA) doing low passes in
his Discus, until he retired and moved to another city.
Old August 28th 11, 07:35 AM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Quote:
Originally Posted by Dave Nadler View Post
John - While I agree with many of your points...
BOTH of the accidents you mentioned above we
- outside of competition
- by non competition pilots
- by pilots "emulating the big guys"
Points to training, not banning passes...
Thanks,
Best Regards, Dave
PS: Not a new problem. Discussed in my 1987 article:
http://www.nadler.com/public/Nadler_...g_May_1987.pdf
GREAT article. Considering it was written 24 years ago it appears there has not been much accomplished relative to training for the high speed low pass. The more I read the more I understand how really complicated this sport can be and how little I know. The books you mentioned should be part of every pilots glider library.
Walt
Old August 28th 11, 08:33 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default Low pass
Bruce,
his Discus, until he retired and moved to another city.- Hide quoted text -
- Show quoted text -
There are a couple of US regs that could be interpreted either way.
Not flying within 500 feet of people, places or things unless in the
act of landing (your missed approach might work here) and no
acrobatics below 1500 feet where acro in defined as an abrupt maneuver
involving a 30 dergee change in attitude (pull up could be meet this
definition). I saw one top US pilot level off his final glide at 500
feet when the FBO announced there was an FAA inspector on the field.
The accident report from the Idaho crash is posted and it reads like a
botched low pass. He flew down-wind at 75 feet going fairly fast, then
pulled up to an estimated 300 feet, stalled and did a 2 turn spin to
crash. He never got low enough to take advantage of ground effect and
the BG-12 would have slowly bled off his initial speed because of this
and being a good bit more draggy than a glass ship.
Too bad, he probably never knew what was required for a successful hi
speed low pass.
JJ
Old August 28th 11, 08:38 PM posted to rec.aviation.soaring
Mike I Green
Default Low pass
Thanks,
Best Regards, Dave
Great article Dave. Should be required reading at all cross country
camps and suggested reading at Regionals.
MG
Old August 28th 11, 08:48 PM posted to rec.aviation.soaring
Mike I Green
Default Low pass
Thanks,
Best Regards, Dave
MG
Old August 28th 11, 09:19 PM posted to rec.aviation.soaring
John Cochrane[_2_]
Default Low pass
Thanks,
Best Regards, Dave
PS: Not a new problem. Discussed in my 1987 article:http://www.nadler.com/public/Nadler_...g_May_1987.pdf
Your article is still a classic.
Nobody's banning anything here. Just talking about a maneuver, where
the danger points are (mostly the turn after the pass), and responding
to a previous post that wanted to know whether there have been
documented crashes.
John Cochrane
Old August 28th 11, 11:03 PM posted to rec.aviation.soaring
Andreas Maurer
Default Low pass
On Sat, 27 Aug 2011 17:22:45 -0700 (PDT), Dave Nadler
Hi Dave - scary lecture!
I have to admit I was horrified reading your description of all these
incidents and the nescience of the pilots - how have things progressed
since you wrote this article? Did it get better (and why?)...?
Regards from Germany
Andreas
  #28
Old August 29th 11, 01:57 PM posted to rec.aviation.soaring
Tom Claffey
Default Low pass
Very good article Dave!
Here in Australia we have a low level endorsement before low finishes are
allowed at contests [while keeping a 50' rule]
2km finish ring changes things as well, limiting the "need" for low level
over the airfield. After finishing a logical circuit onto the airfield is
needed, I was surprised at some "interesting" circuits at Uvalde by
experienced pilots! A growing average age and experience helps too.
Training for new comp pilots is the key.
Regards,
Tom
Thanks,
Best Regards, Dave
article:http://www.nadler.com=
/public/Nadler_On_Safety_Soaring_May_1987.pdf
documented crashes.
John Cochrane
  #29
Tom Claffey
Default Low pass
Regards,
Tom
Thanks,
Best Regards, Dave
documented crashes.
John Cochrane
  #30
Old August 29th 11, 02:50 PM posted to rec.aviation.soaring
Dave Nadler
Default Low pass
Thanks Tom - Great to fly with you again in Uvalde.
I was surprised Oz isn't yet using a height-limited
finish cylinder (when I flew at Keepit in November).
Led to some interesting finish issues as this encourages
direct approach to landing...
Hope you guys adopt this approach as well !
Hope to fly with you again soon,
Best Regards, Dave "YO electric"
Beech 18 Pass at Sun n Fun - Beech 18 low pass sun n fun 2010 (Custom).jpg Glen in Orlando Aviation Photos 0 April 22nd 10 08:59 PM
L-39 Pass Glen in Orlando Aviation Photos 1 October 10th 09 02:37 AM
Low Pass Conscious Pilate Aviation Photos 1 November 17th 06 12:28 PM
B-52 Low Pass - B-52 flyby.jpg (0/1) Greasy Rider @ invalid.com Naval Aviation 4 June 1st 06 02:56 PM
9,000 TTSN - pass? Potato Chip Owning 11 September 16th 05 06:34 PM
