#21
On Nov 25, 1:36*am, Peter Scholz wrote:
on my ASW24 (CG-hook only) I regularily lock the back-release feature when aero-towing in the alps, due to the high turbulence that can be experienced there. I simply push a cork from an ordinary wine bottle behind the TOST hook, so that the swiveling part of the hook is blocked. Does your tow pilot know you're doing this? They might not be happy. I've flown a belly hook-only glider (Janus) in strong thermals and rotor and never had any problem with the rope back releasing due to going slack. It takes quite a positive backwards pull to make the cage swivel. I don't think the weight of the rope alone would do it. |
On Nov 25, 1:36*am, Bruce Hoult wrote:
Does your tow pilot know you're doing this? They might not be happy. Why not? No Tost nose hook is capable of back release. (And please let's not re-start the discussion about how dangerous it is to aero-tow on CG hooks. In my experience with ASW-19b and ASW-28 it's a non issue so I doubt it is for the ASW-24). Andy |
Am 25.11.2011 09:36, Bruce Hoult wrote:
On Nov 25, 1:36 am, Peter wrote: on my ASW24 (CG-hook only) I regularily lock the back-release feature when aero-towing in the alps, due to the high turbulence that can be experienced there. I simply push a cork from an ordinary wine bottle behind the TOST hook, so that the swiveling part of the hook is blocked. Does your tow pilot know you're doing this? They might not be happy. Yes. They actually recomend it. I've flown a belly hook-only glider (Janus) in strong thermals and rotor and never had any problem with the rope back releasing due to going slack. It takes quite a positive backwards pull to make the cage swivel. I don't think the weight of the rope alone would do it. It's no fun to find yourself released in a rotor with no real place to land out below you. And blocking the cage in an aero tow doesn't hurt anybody, it just makes the CG hook function like a nose hook. -- Peter Scholz ASW24 JE |
Two seat jet self launch video | airshowbob[_2_] | Soaring | 2 | June 24th 10 06:39 AM |
Belgian winch launch video | Frank Whiteley | Soaring | 7 | January 18th 10 02:53 AM |
P-47 cat launch video | pe.rhodes | Naval Aviation | 1 | April 15th 06 10:51 PM |
Balloons maybe a new glider launch method NOT | Mal | Soaring | 4 | December 14th 04 05:19 AM |
AIM-47 missile launch from YF-12A (Blackbird) video. | Scott Ferrin | Military Aviation | 0 | January 9th 04 11:54 AM |
