#21
Aviation Week has had articles on PD engines every so often for at
least the past six years. Walt BJ |
![]() "Gord Beaman" wrote in message ... Bruce Simpson wrote: To give you an idea of the difference (in terms of shock, vibration and noise) -- in a deflagration, the flame travels at just a few meters per second, in a detonation the flame front effectively travels at several times the speed of sound. Yes, the operative word here is 'effectively' because there's actually no defined flame-front at all. As the normal flame front progresses across the firing chambre a certain area of the remaining fuel/air charge starts getting squeezed (and heated by it) till it's internal temperature arrives at it's ignition point then the whole remaining area detonates almost instaneously producing an extremely high spike of pressure which is practically useless against the inertia of the piston/crank etc. This spike quickly punches and burns holes in the piston etc. The big problem with regards to power from a detonation is that it all most always occurs during the compression stroke. During the normal operating cycle the spark is fired to ignite the mixture substantially before the piston reaches the top of the compression stroke, with the normal "slow" burn the flame front hasn't burned far before the piston reaches top dead center and started back down during the power stroke. Maximum pressure is achieved during the power stroke. The ignition for the detonation likely comes from a normal spark event (there are other causes) but the environment in the combustion chamber has put mixture to close to the ignition point and it all -or portions of it- tip over the edge and start burning before the normal flame front gets there. |
"John Keeney" wrote:
"Gord Beaman" wrote in message .. . Bruce Simpson wrote: To give you an idea of the difference (in terms of shock, vibration and noise) -- in a deflagration, the flame travels at just a few meters per second, in a detonation the flame front effectively travels at several times the speed of sound. Yes, the operative word here is 'effectively' because there's actually no defined flame-front at all. As the normal flame front progresses across the firing chambre a certain area of the remaining fuel/air charge starts getting squeezed (and heated by it) till it's internal temperature arrives at it's ignition point then the whole remaining area detonates almost instaneously producing an extremely high spike of pressure which is practically useless against the inertia of the piston/crank etc. This spike quickly punches and burns holes in the piston etc. The big problem with regards to power from a detonation is that it all most always occurs during the compression stroke. I don't think so John, the added pressure from the squeezing of the fuel/air charge by the advancing flame front wouldn't have risen nearly high enough 'before' TDC. During the normal operating cycle the spark is fired to ignite the mixture substantially before the piston reaches the top of the compression stroke, with the normal "slow" burn the flame front hasn't burned far before the piston reaches top dead center and started back down during the power stroke. Maximum pressure is achieved during the power stroke. The ignition for the detonation likely comes from a normal spark event (there are other causes) I doubt this too because there'd be a second flame front from that therefore you wouldn't get the 'instantaneous ignition' of heating an area up to it's ignition point and having it all detonate at once. but the environment in the combustion chamber has put mixture to close to the ignition point and it all -or portions of it- tip over the edge and start burning before the normal flame front gets there. It's true that it ignites before the normal flame front gets there but IMO it has nothing to do with mixture and everything to do with temperature derived from increasing pressure. -- -Gord. |
#24
Hi Bruce, Nice to see you in this group. Did your neighbour successfully
sell the property? regards AL "Bruce Simpson" wrote in message ... On Sat, 28 Feb 2004 17:22:40 GMT, "Ed Majden" wrote: "Grantland" "Grantland" Nope. Pulse-burn. Much less efficient. Symantics! It was a pulse jet! Fiesler Fi-103 (V1) Specifications Engine: Argus pulse-jet 600 pounds of thrust Length: 25' 4" Wingspan: 17' 6" Weight: 4800 lbs. Fully fueled Fuel: 150 gallons of Acetylene gas 1 mile per gallon Range: Approximately 160 miles from launch site Performance: Speed between 360-400 mph Flew at altitude of 2000-3000 ft Average flight time of 22 minutes Armament: 2337 pound war head Not as efficient, but still an early prototype PULSE JET!!! Different principal perhaps! Time marches on and so do design techniques. Sorry but the V1 was not powered by acetylene -- they used very low-grade gasoline. There would be no way to (safely) store sufficient acetylene onboard even if they wanted to use it as a fuel. Acetylene was used for starting in very cold weather but most certainly never as a fuel. -- you can contact me via http://aardvark.co.nz/contact/ |
#25
On Thu, 4 Mar 2004 16:49:57 +0800, "Alfred Loo"
wrote: Hi Bruce, Nice to see you in this group. Did your neighbour successfully sell the property? Yes, but then I shifted anyway -- too many other neighbours. Now I have a *much* better place to make noise -- and it even has an 800m sealed runway :-) -- you can contact me via http://aardvark.co.nz/contact/ |
#26
Bruce Simpson wrote in message . ..
On 29 Feb 2004 18:57:36 -0800, (Eric Moore) wrote: If this PDE research pans out, what would such an engine be used on? A high-speed, high-altitude cruise missile (Something like FastHawk or ARRMD)? An SR-71 replacement (possibly manned, but probably not)? The first stage of a two stage reusuable space launch system? Something else? There are significant problems to using PDEs as a propulsive source. The magnitude of the shockwaves produced is extremely high as are the levels of vibration. If it can't be used as a propulsive source, then what CAN it be used for? A craft using such a power-plant will need some very special attention paid to the acoustic and physical isolation of the engine. |
#28
On 6 Mar 2004 18:07:31 -0800, (Eric Moore) wrote: If it can't be used as a propulsive source, then what CAN it be used for? Right now -- not very much, if the published results are anything to go by :-) Aviation Week has an article this issue about the Air Force Research Laboratory's Combustion Science Branch, which plans to test-fly a Scaled Composites LongEZ sportplane with a four-cylinder PDE in lieu of a conventional engine. Sounds like they think it will work, though it's going to be a loud SOB. And they basically admit that they don't see this as a practical operation: the plane will only make a few flights and nothing cross-country. But it's a start. I think these are the same people: http://www.pr.afrl.af.mil/divisions/...News/news.html -- Tom Schoene Replace "invalid" with "net" to e-mail "Our country, right or wrong. When right, to be kept right, when wrong to be put right." - Senator Carl Schurz, 1872 |
#29
On Wed, 10 Mar 2004 01:31:20 GMT, "Thomas Schoene"
wrote: Bruce Simpson wrote: On 6 Mar 2004 18:07:31 -0800, (Eric Moore) wrote: If it can't be used as a propulsive source, then what CAN it be used for? Right now -- not very much, if the published results are anything to go by :-) Aviation Week has an article this issue about the Air Force Research Laboratory's Combustion Science Branch, which plans to test-fly a Scaled Composites LongEZ sportplane with a four-cylinder PDE in lieu of a conventional engine. Sounds like they think it will work, though it's going to be a loud SOB. And they basically admit that they don't see this as a practical operation: the plane will only make a few flights and nothing cross-country. But it's a start. I think these are the same people: http://www.pr.afrl.af.mil/divisions/...News/news.html I think this is a "proof of concept" configuration rather than a practical demonstration of the technology. Have you seen the ancilliary equipment required to make that engine work -- and despite all the weight and complexity, it's actually *less* powerful than a traditional pulsejet of the same volume/weight. Still, a journey of a thousand miles starts with a single step and I suspect those doing the R&D on PDEs are under some pressure to demonstrate progress so as to justify their budgets. -- you can contact me via http://aardvark.co.nz/contact/ |
#30
On Wed, 03 Mar 2004 09:26:37 +1300, Bruce Simpson
wrote: To give you an idea of the difference (in terms of shock, vibration and noise) -- in a deflagration, the flame travels at just a few meters per second, in a detonation the flame front effectively travels at several times the speed of sound. Basicly it's the difference between low-order explosives like black powder, and high order explosives like RDX... |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Pulse Engines Dead? | robert arndt | Military Aviation | 0 | January 21st 04 05:38 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
