1 glider - 11 waterballast trails
Old June 19th 12, 02:49 PM posted to rec.aviation.soaring
John Galloway[_1_]
Default 1 glider - 11 waterballast trails
http://www.schempp-hirth.com/index.php?
eID=tx_cms_showpic&file=uploads%2Fpics%2FQuin_11st ralig.jpg&
width=1024m&height=800m&bodyTag=%3Cbody%20bgColor% 3D
%22%23dddddd%22%3E&wrap=%3Ca%20href%3D%22javascrip t
%3Aclose%28%29%3B%22%3E%20%7C%20%3C%2Fa%3E&md5
=21b00ee34c627bb243eebb2518add426
Old June 19th 12, 03:26 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
This may work better http://tinyurl.com/ccja5so
Don't tell the "chemtrail" conspiracy guys....
Old June 19th 12, 03:35 PM posted to rec.aviation.soaring
John Cochrane[_2_]
On Jun 19, 9:26*am, Evan Ludeman wrote:
This may work betterhttp://tinyurl.com/ccja5so
11 valves to leak, stick, break, adjust, or at least fill with
chapstick and fiddle with?
John Cochrane
Old June 19th 12, 04:09 PM posted to rec.aviation.soaring
Ron Gleason
John Cochrane
Dave Nadler has some details in his blog here http://www.nadler.com/public/2012_Mi...12_Minden.html
scroll down a few screens.
I think I will get to Uvalde a few days early and buy up all the Plumbers toilet seal and chapstick. Then try to sell back to folks with the Quintuis and Anatares and make some big bucks!
Old June 19th 12, 06:06 PM posted to rec.aviation.soaring
Andrew[_11_]
I wonder how many fill ports it has? In other words the extent of interconnected ballast tanks.
Old June 19th 12, 06:09 PM posted to rec.aviation.soaring
JohnDeRosa
I'll give the glider points for looking cool dumping water. Maybe I
could hire them to spray fertilizer on our grass runway!
- John
Old June 19th 12, 06:11 PM posted to rec.aviation.soaring
Tony[_5_]
- John
i've heard there is a need for heavy airtanker firefighting capabilities out west.
Old June 19th 12, 07:52 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Jun 19, 9:35*am, John Cochrane
John Cochrane
So, John, does this mean you are going to stick with your 27? :-)
ZS
Old June 20th 12, 05:46 AM posted to rec.aviation.soaring
Dave Nadler
I'll ignore the obnoxious comments below.
Hydraulic pressure is a really big problem.
When a glider spins, ground-loops, etc - lots of pressure !
Prototype ASW-22 was lost in a spin test with water - wing exploded.
Another had wing exploded during ground-loop.
Some systems to alleviate pressure rely on partial air in tank - marginal.
New gliders need extreme amounts of water to get to required high wing loading.
So.... Lots of tanks !
All of which means mechanical linkages (multiple wing panels)
get really unwieldy and impractical.
I designed the new dump system requiring:
- quickly field-removable valves for cleaning debris or replacement,
- very high reliability compared to silly servo-based systems,
- absolute minimal mechanical complexity in wings,
- flush with outer wing surface for minimal drag (without silly dangling mylar)
Valves have operated in a test rig 150,000 cycles without problem.
Try that with your silly servos.
If you pump in pond water a valve can jam with debris, small fish, or large fish.
Enough deposits and you need chapstick.
Or, pull it out and clean or replace it.
Significantly better than the alternatives we believe...
Hope that's clear !
Best Regards, Dave "YO electric"
Old June 21st 12, 03:38 PM posted to rec.aviation.soaring
Dave Nadler
Hope that's clear !
PS: Antares 23T has 6 valves per side. An 6th water tank
is possible and required as this glider has no batteries
in wing (like 23E) or fuel tank in wing (like Quintus),
and has reduced weight (sustainer vs. self-launch).
I understand there will be one Antares 23T at Uvalde,
stand by for even better water-dump pictures ;-)
Pulp Fiction, pt 2 - bill barnes air trails 1936 12.jpg (1/1) Mitchell Holman Aviation Photos 0 April 3rd 07 05:34 AM
Pulp Fiction, pt 2 - bill barnes air trails 1935 10.jpg (1/1) Mitchell Holman Aviation Photos 0 April 3rd 07 05:33 AM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
Vapour trails Michael Calwell Piloting 67 December 21st 04 11:07 PM
