Chapstick In Water Dump Valves
Old June 19th 12, 11:53 PM posted to rec.aviation.soaring
Dan Marotta
Default Chapstick In Water Dump Valves
On Sunday, returning from a flight, I pulled the wing dump lever in my
LAK-17a (the tail tank was already dumping) and it didn't feel like both
valves opened. I carried some extra speed through the landing and, after
stopping, the left wing went down. A friend on the ground later confirmed
that only the right wing was dumping.
The wings were full (about 24 gallons on each side) but the LAK handled it
beautifully. My point in writing is that I'd used chapstick to
seal/lubricate the dump valves and, while sealing quite well, it also glued
the valves shut. It took both hands pushing up on the valve from under the
wing to get the stuck valve to open. Today I cleaned both valves and seats
completely of chapstick and applied a very light coating of bee's wax on the
sealing surface of the valves. They work great now (for now)...
YMMV, but I'll never again use chapstick on my dump valves.
Old June 20th 12, 12:10 AM posted to rec.aviation.soaring
Chris Nicholas[_2_]
In the UK, AIUI, we are encouraged to use “Vaseline” – petroleum jelly, applied freshly for each flight. Seems to work for most people.
Chris N.
Old June 20th 12, 01:40 PM posted to rec.aviation.soaring
Muttley
Vaseline is ok for UK type climate, however it will melt in hotter climate.
Got a Tip from an Australian Pilot to use Molykote 111 Compound which worked
really well especially on SH Gliders.
Old June 20th 12, 08:42 PM posted to rec.aviation.soaring
hretting
Leave the Bees alone and go to a hardware store and buy a 'Toilet ring seal'. They too are made of wax (plummers wax) and a roll of white 3m electrical tape that come in a round plastic container.
Empty the tape container and put a 1/4 of the wax ring seal in it, mail me the tape. This amount will last a life time, so give the rest to a street begger.
S-H gliders have a tool to screw into the valve to pull down as one smears the wax into the seat area thru the gap. With a little practice, minimal is use and any dribblets of water can be stopped with little effort.
Every couple of years I clean the seat with a Q-tip and find a spot of wax about the size of a pea will last a racing season. The wax stays good even in the heat.
Never had a valve stick close.
R
Old June 21st 12, 01:16 AM posted to rec.aviation.soaring
Dan Marotta
Great advice! The bee's wax I used was given to me by a friend who received
it when he bought his Mini Nimbus. It probably came from your grandfather's
bees...
"hretting" wrote in message
begger.
in the heat.
R
VALVES More is Better [email protected] Home Built 8 January 13th 09 05:34 PM
LS8 water valves Bela[_2_] Soaring 3 June 30th 08 03:48 AM
Water, water, everywhere, but none for thirsty wings.... Chris OCallaghan Soaring 0 November 21st 04 03:14 PM
Schemp Hirth water ballast dump valves tango4 Soaring 14 September 2nd 04 07:13 PM
Water dump valve rotary seal Bill Daniels Soaring 6 May 10th 04 11:02 AM
