Trig TT21 transponder for sale
Old September 6th 12, 03:31 PM posted to rec.aviation.soaring
Tim Mara
Default Trig TT21 transponder for sale
this is within a very few $ of what I sell new TRIG T21's for.....with
factory warranty!
tim
"Jim" wrote in message
On Wednesday, September 5, 2012 5:27:09 PM UTC-4, K wrote:
On Sunday, September 2, 2012 8:22:36 PM UTC-6, Dave Springford wrote:
Trig TT21 $2050
New in box
The TT21 system is the smallest, lightest, Mode S general aviation
transponder. This two part system, includes an integrated altitude
encoder.
A small control unit mounts in a 57 mm hole in the panel and the rest
of the unit can be mounted anywhere.
contact dave at foxonecorp.com
I am interested in buying this and I am wondering, With this unit being a
Class 2 transponder, What happens above 15,000 feet? I fly in places
where the good days occasionally allow for climbs and some cruising above
this. Thanks
Over 15000 you would want the Trig22. The Trig21 is only certified to 15K.
Of course, who would know?
Old September 7th 12, 05:07 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
being a Class 2 transponder, What happens above 15,000 feet?
The same thing that happens at 15,000 feet. It will do want needs to be
done, but if you will frequently fly above 18,000' outside of a "wave
window", consider the higher power unit.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old September 7th 12, 04:08 PM posted to rec.aviation.soaring
K
email me)
Eric,
Thanks for the link. I never knew SSF had its own website. I mostly fly in Northern UT and the Reno area so 15K on a good day is not unrealistic. I have no desire to fly the high altitude wave you mention. My question "What happens at 15,000" was mainly referring to what is ATC going to see on the scope. If the display on the scope (Or TCAS) tops at 15K then I may need to keep shopping. If this unit will display PA altitudes between 15 and 17K then, for the small amount of time I spend at these altitudes, this unit would probably do.
Just bought a new ship and I am in the process of setting up (Completely redoing) the panel so you guys may have to suffer through my silly questions for awhile.
Kirk
Old September 7th 12, 05:22 PM posted to rec.aviation.soaring
Grider Pirate[_2_]
email me)
Eric,
Kirk * * *- Hide quoted text -
- Show quoted text -
The TC 20 control unit is the same for both the TT21 and TT22. The
altitude encoder is part of the TC 20 control unit.
Old September 7th 12, 05:27 PM posted to rec.aviation.soaring
son_of_flubber
http://www.airplanegear.com/trig/tt2...all-manual.pdf
The installation manual has a more complete technical specification
and a careful reading may answer your question. Other than power output, much of the spec seems identical, but there may be some subtle and important differences.
Old September 7th 12, 11:05 PM posted to rec.aviation.soaring
Dave Springford
The difference between class 1 and 2 transponders is the power output. Class 1 typically around 175 Watts or lower and class 2 250 W.
The higher power of the class 2 for greater transmission distance for the high flyers.
Trig TT21 Transponder ... reports? Grider Pirate Soaring 105 March 29th 18 01:10 AM
Trig TT21 transponder draws only 125 mA! Steve Koerner Soaring 5 March 15th 10 09:59 PM
TRIG TT21 Transponders Tim Mara[_2_] Soaring 12 September 26th 09 02:01 AM
Trig TT21 Transponder receives FAA TSO approval Paul Remde Soaring 12 September 19th 09 02:47 PM
Trig TT21 Transponder Thoughts? jcarlyle Soaring 16 June 23rd 09 04:38 PM
