#11
A properly terminated transmission line is infinitely long from the
perspective of the transmitter. The reason the unterminated spool of coax had nothing coming out the end was due to nearly 100% reflections in the line. "Mike the Strike" wrote in message ... Yes, but all feed lines are lossy and at the frequencies we are using here the lengths of coax are dumb-ass. We don't have an awful lot of signal to begin with, so throwing half of it away is plain stupid. I remember in my ham radio days a friend used an unterminated roll of coax as a dummy load when experimenting up in the GHz range. The signal barely made it to the other end, making a terminating resistor unnecessary! Mike |
On 9/15/2012 6:56 PM, Dan Marotta wrote:
A properly terminated transmission line is infinitely long from the perspective of the transmitter. The reason the unterminated spool of coax had nothing coming out the end was due to nearly 100% reflections in the line. "Mike the Strike" wrote in message ... Yes, but all feed lines are lossy and at the frequencies we are using here the lengths of coax are dumb-ass. We don't have an awful lot of signal to begin with, so throwing half of it away is plain stupid. I remember in my ham radio days a friend used an unterminated roll of coax as a dummy load when experimenting up in the GHz range. The signal barely made it to the other end, making a terminating resistor unnecessary! There should not be any reflections _in_ the line, unless it is improperly made or damaged. More likely, as Mike suggests, most of the power was absorbed along the way by the coax itself, so there was precious little power to be reflected. The coax is effectively "terminated" by the distributed losses that occur in the center and outer conductors, and the dielectric. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
Nope.
As a lab experiment in my college days, I located a break in a very long coax by timing a signal's reflection using an oscilloscope. An undamaged line, terminated in its characteristic impedance will deliver most of its power to the load. Reflections will be minimal. I'm describing an ideal situation which, I know, is not possible. You're describing a poory designed, built, installed, or maintained system which, considering us glider pilots, is probably the norm. "Eric Greenwell" wrote in message ... On 9/15/2012 6:56 PM, Dan Marotta wrote: A properly terminated transmission line is infinitely long from the perspective of the transmitter. The reason the unterminated spool of coax had nothing coming out the end was due to nearly 100% reflections in the line. "Mike the Strike" wrote in message ... Yes, but all feed lines are lossy and at the frequencies we are using here the lengths of coax are dumb-ass. We don't have an awful lot of signal to begin with, so throwing half of it away is plain stupid. I remember in my ham radio days a friend used an unterminated roll of coax as a dummy load when experimenting up in the GHz range. The signal barely made it to the other end, making a terminating resistor unnecessary! There should not be any reflections _in_ the line, unless it is improperly made or damaged. More likely, as Mike suggests, most of the power was absorbed along the way by the coax itself, so there was precious little power to be reflected. The coax is effectively "terminated" by the distributed losses that occur in the center and outer conductors, and the dielectric. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On 9/16/2012 8:17 AM, Dan Marotta wrote:
Nope. As a lab experiment in my college days, I located a break in a very long coax by timing a signal's reflection using an oscilloscope. An undamaged line, terminated in its characteristic impedance will deliver most of its power to the load. Reflections will be minimal. I'm describing an ideal situation which, I know, is not possible. You're describing a poory designed, built, installed, or maintained system which, considering us glider pilots, is probably the norm. "Mike the Strike" wrote in message ... Yes, but all feed lines are lossy and at the frequencies we are using here the lengths of coax are dumb-ass. We don't have an awful lot of signal to begin with, so throwing half of it away is plain stupid. I remember in my ham radio days a friend used an unterminated roll of coax as a dummy load when experimenting up in the GHz range. The signal barely made it to the other end, making a terminating resistor unnecessary! Hi Dan - You are indeed describing an ideal situation; Mike was describing a non-ideal situation. If you make the line long enough, it will absorb all the power before it reaches the end of the cable; for high frequencies (transponder and higher), "long enough" might be only 20 or 30 feet with low-cost cable. Without knowing the specific cable used in the PF antennas, I can't say they are significantly degrading the signal, but shorter is better. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
Hi, Eric,
It appears we're talking the same story after all. When I installed my transponder (Trig TT22) I used some RG-58 that was laying around the airport. It didn't work too well. So I went to an avionics shop and got the right stuff. It worked much better. "Eric Greenwell" wrote in message ... On 9/16/2012 8:17 AM, Dan Marotta wrote: Nope. As a lab experiment in my college days, I located a break in a very long coax by timing a signal's reflection using an oscilloscope. An undamaged line, terminated in its characteristic impedance will deliver most of its power to the load. Reflections will be minimal. I'm describing an ideal situation which, I know, is not possible. You're describing a poory designed, built, installed, or maintained system which, considering us glider pilots, is probably the norm. "Mike the Strike" wrote in message ... Yes, but all feed lines are lossy and at the frequencies we are using here the lengths of coax are dumb-ass. We don't have an awful lot of signal to begin with, so throwing half of it away is plain stupid. I remember in my ham radio days a friend used an unterminated roll of coax as a dummy load when experimenting up in the GHz range. The signal barely made it to the other end, making a terminating resistor unnecessary! Hi Dan - You are indeed describing an ideal situation; Mike was describing a non-ideal situation. If you make the line long enough, it will absorb all the power before it reaches the end of the cable; for high frequencies (transponder and higher), "long enough" might be only 20 or 30 feet with low-cost cable. Without knowing the specific cable used in the PF antennas, I can't say they are significantly degrading the signal, but shorter is better. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
I took one of the little dipole antennas apart today. Easy, once you know that there are two screws hidden under the adhesive pad. Remove the pad to get to the screws. Each element of the dipole has a brass base with coax center conductor soldered to one, shield to the other. Easy to change length to remove the "bundled" excess to minimize line loss.
But, that does bring up a question. I remember years ago that at least for lower frequencies the length of the coax wanted to be multiples of 1/4 or 1/2 wave adjusted for velocity or some such. Is that a factor or worth messing with at 900 MHz? bumper |
I took apart the GPS antenna which has by far the LONGEST excess of cable in the brick PowerFlarm setup. It's a wee bit trickier soldering than on the PF antennas, but if you're inclined it's not a huge task. I removed probably 6' of cable. I left the butterfly display back at the gliderport so I haven't been able to test it, but I'm confident it will work. The shield is soldered to one spot and the center conductor is soldered to a small pad on the PC board. The only trick is the careful trimming of the shield and conductor insulation to match what they did. It's also fairly easy to remove and re-use the strain relief.
Mark |
On Sunday, September 16, 2012 10:27:47 PM UTC-4, Eric Greenwell wrote:
On 9/16/2012 7:18 PM, wrote: I took apart the GPS antenna which has by far the LONGEST excess of cable in the brick PowerFlarm setup. It's a wee bit trickier soldering than on the PF antennas, but if you're inclined it's not a huge task. I removed probably 6' of cable. I left the butterfly display back at the gliderport so I haven't been able to test it, but I'm confident it will work. The shield is soldered to one spot and the center conductor is soldered to a small pad on the PC board. The only trick is the careful trimming of the shield and conductor insulation to match what they did. It's also fairly easy to remove and re-use the strain relief. The GPS antenna cable doesn't carry high frequency RF, so tidiness is the only value in reducing the length. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) Eric, so why do we need a GPS antenna wire if the signal from the satellite magically gets to the receiver without the RF signal first going through the antenna wire :=P I'm fairly sure that the GPS antennas are "active" antennas getting phantom dc power from the receiver but I thought they only had an amplifier; are you sure they also have a local oscillator & mixer to convert the RF to an IF (I guess like an LNB)? Amazing for such a cheap device. |
| Thread Tools | |
| Display Modes | |
| Video of Powerflarm brick in action | Ramy | Soaring | 7 | September 1st 12 01:51 AM |
| Powerflarm Brick feedback | Ramy | Soaring | 7 | August 10th 12 02:02 AM |
| PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 26th 12 12:58 AM |
| PowerFLARM 'brick' progress? | Frank Paynter[_2_] | Soaring | 5 | November 13th 11 08:28 PM |
| Display for PowerFLARM brick | Andy[_1_] | Soaring | 4 | May 10th 11 03:32 PM |
