Transponderz
Old November 2nd 12, 03:36 PM posted to rec.aviation.soaring
Grider Pirate[_2_]
Default Transponderz
I cannot help cringing at the requirement for WAAS. If WAAS reduced
positional error to ZERO, that is still less than a 50 foot (15 meter)
improvement over non-differentially corrected GPS. If 50 feet is a
factor, they're screwing up.... big time. Does requiring a WAAS
capable GPS make sense to anyone? (aside from the FAA!)
On Oct 26, 8:05*pm, son_of_flubber wrote:
On Friday, October 26, 2012 6:39:14 PM UTC-4, Paul Remde wrote:
The bummer is that even though it is possible to connect a GPS up to the
Trig TT21 or TT22 an send ADS-B data out, the FAA says that is illegal.
They say you must use an approved GPS costing $3000+.
A quick list of the approved GPS position sensors and prices
Freeflight 1201 WAAS/GPS Sensor $2,919.00
Freeflight 1204 WAAS/GPS Sensor $6,889.00
Could not find prices for the NexNav sensors:
NexNav MINI WAAS/GPS Sensor
NexNav MAX WAAS/GPS Sensor
Is NexNav shipping these products?
Maybe the price will come down when more than one vendor is shipping approved products.
Old November 2nd 12, 04:21 PM posted to rec.aviation.soaring
Mike C
What Paul said.
The reason I passed on mode S and bought mode C.
Mike
On Friday, October 26, 2012 4:39:14 PM UTC-6, Paul Remde wrote:
Hi,
They say you must use an approved GPS costing $3000+. I wish we could
convince the FAA that they are reducing safety dramatically by not allowing
any GPS to send data to the TT21/TT22.
Best Regards,
Paul Remde
"K" wrote in message
I should add, I have an AEE dipole in the nose about 8 inches from my
feet, but despite 200 watts tested radiated power from the Trig 21, it
does not keep my feet warm...
Ive noticed a marked change in my sex drive with anything past 200 watts..
Seriously, to get back to the OP, I was thinking of a Trig for the ADS-b out
capabilities and the PF for the ADS-B in. This way my set up will not become
obsolete in a few years. Am I correct on this assumption?
Old November 2nd 12, 04:28 PM posted to rec.aviation.soaring
Peter Purdie[_3_]
The factor you are missing is that approved Aviation GPS have an error
detection system, and send a message (which is included in the 1090ES data
out) to confirm the information is reliable. Low cost GPS doesn't.
In Europe, as I understand it, you can egally connect a low cost GPS to a
TT21 and it will be broadcast in the DS-B out, but including a 'do not rely
on this information' message. That's regardless of WAAS (or EGNOS over
here).
th=
e
illegal.
appr=
oved products.
Old November 2nd 12, 04:33 PM posted to rec.aviation.soaring
Dave Nadler
Regardless of ADS-B out capability, you still want
a Mode S transponder, because:
- Mode S consumes less power
- Mode S will not cause a bunch of gliders in a thermal
to become invisible to a TCAS-equipped approaching jet,
as can happen with Mode A/C,
- Mode S can be "de-duplicated" by FLARM, as the transponder
will be identified as redundant with the more-accurate
FLARM information (other FLARM-equipped gliders will
be spared PCAS alarms from your transponder).
Please install Mode S, not Mode C.
You and everybody else will be a lot happier.
Hope that is clear,
Best Regards, Dave
Old November 2nd 12, 06:05 PM posted to rec.aviation.soaring
Craig Funston[_2_]
Hope that is clear,
Best Regards, Dave
Dave,
I'm interested in more information regarding the rendering "invisible" potential of Mode A/C. I have a Terra Mode C available to me for the coming season & the research I did indicated to me that it is visible to TCAS equipped aircraft as long as the AD has been complied with. Is there something I missed in my research?
Thanks,
Craig
Old November 2nd 12, 06:11 PM posted to rec.aviation.soaring
Dave Nadler
On Friday, November 2, 2012 2:05:34 PM UTC-4, Craig Funston wrote:
Dave,
Thanks,
Craig
Yes, read especially the technical notes at the bottom of this page:
http://www.gliderpilot.org/FLARM-Transponders
For any new installation, get a Mode S unit !
Hope that helps,
Best Regards, Dave
Old November 2nd 12, 07:20 PM posted to rec.aviation.soaring
Craig Funston[_2_]
Dave,
Thanks,
Craig
Hope that helps,
Best Regards, Dave
Thanks Dave,
That provided the information I needed.
Craig
Old November 2nd 12, 07:27 PM posted to rec.aviation.soaring
Tony[_5_]
On Friday, November 2, 2012 2:20:30 PM UTC-5, Craig Funston wrote:
On Friday, November 2, 2012 11:11:51 AM UTC-7, Dave Nadler wrote: On Friday, November 2, 2012 2:05:34 PM UTC-4, Craig Funston wrote: Dave, I'm interested in more information regarding the rendering "invisible" potential of Mode A/C. I have a Terra Mode C available to me for the coming season & the research I did indicated to me that it is visible to TCAS equipped aircraft as long as the AD has been complied with. Is there something I missed in my research? Thanks, Craig Yes, read especially the technical notes at the bottom of this page: http://www.gliderpilot.org/FLARM-Transponders For any new installation, get a Mode S unit ! Hope that helps, Best Regards, Dave Thanks Dave, That provided the information I needed. Craig
if you have the choice sure go with Mode S but if the choice is no transponder or mode c, go with mode c!
i happily installed a Microair mode c transponder in YYY this spring and it worked great all season.
Old November 2nd 12, 07:44 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Even though the TCAS function doesn't work, is the approaching jet made
aware there are transponders at that 2-D position, altitude unknown?
What happens when the jet approaches a Mode A equipped aircraft? Is the
pilot made aware of it, even though the TCAS system cannot give him
climb/dive command?
email me)
Old November 2nd 12, 07:53 PM posted to rec.aviation.soaring
Craig Funston[_2_]
climb/dive command?
email me)
Eric,
Not sure if you got a chance to read through the link Dave sent. Good information there. My take-away was that the gaggle problem is one of having multiple Mode C transponders in the same location. That's not a very likely scenario in the Columbia Basin where fly. I'm also not likely to be in controlled airspace so the high rate of interrogation responses isn't as big an issue. Mode C isn't my first choice, but given the choice between no transponder or Mode C in a relatively low traffic environment for the next couple years, I'll take the Mode C and save my pennies for a Trig. At least I'll be visible to jet traffic. I had a close encounter with an A6-E storming through my thermal last year that got my attention.
Craig
